I hear a whirring noise when the refrigerator is running
Try to find out if the noise is inside or outside (under the bottom). If the noise is Inside, that will be the main cooling fan. Could be from hitting ice or a wire, or age meaning it needs replacing. If hitting ice or a wire will need to be cleared by accessing the evaporator section in the freezer. If under the fridge. pull it away from the wall and remove the back cover (screws) use a vacuum if needed an clean the fan blades, (unplug it first). It may still be due to the age, in which case will need to be replaced.
