Question about Toshiba SATELLITE A10 A15 A20 A25 A35 A40 A45 SATELLITE PRO M15 SERIES 15 INCH XGA LCD DISPLAY -LQ15 (LQ150X1LHC3B) CD-ROM Drive
Keyboard settings fouled up
Toshiba Satellite A10
I just replaced a shorted systems board with a used board. All other hardware and the software are unchanged, except for adding an additional memory card.
It now boots WindowsXP OK, but several of the letter keys act as single-key shortcuts to various Windows dialog boxes. Any ideas on how to reset this? None of the language settings, etc. change it.
Another issue is that a DAQ Card used to interface to an instrument now causes the laptop to freeze when inserted. Problem occurs whether the card is inserted before booting or after.
Any help would be greatly appreciated.
Thanks,
Brent
  • brentlewis Jun 17, 2008
    With regard to the keyboard problem, removing the CMOS battery on the Toshiba Satellite A10 laptop did not work to reset the CMOS. I have since read a comment that said this does not work on laptops.
    Is there another way to reset the CMOS, or other suggestions on how to fix this keyboard problem?
    Novelist:
    Champion:
  • 210 Answers
I suggest you update the bios to cure both the issues your having....!
Cheers
Posted on Jun 17, 2008
    Genius:
  • 2,035 Answers
Please check for any dirt on the surface and replace the keyboard on the laptop and click here
, IF this did mot work you can use the USB keyboard and mouse if these suggestion did not work:
Good luck...........
    Genius:
  • 3,422 Answers
On the motherboard there is a small watch battery. Remove this battery along with the main ATX cable from the power supply. Hold down the power button to fully discharge the system. Wait 2-3 minutes then reinstall the battery and plug in your system. Your reset is now complete,.
This is another way:
Since some motherboards have a 3 pin jumper by the battery. Lets say that the jumper is on pins 2 and 3. Remove the jumper while the machine is OFF and place onto pins 1 and 2. Power on your machine for a minute. (Note: Your system will not POST). Shutdown your machine and put the jumper back to pins 2 and 3. Your reset is now complete
Goodluck,
Please don't forget to rate or accept the solution.
    President:
  • 2,712 Answers
Have you replaced the motherboard with another similar board, or is the chipset different? Also make sure that the chipset meets the requirements for the DAQ card..
As for the keyboard, make sure that the contacts on the connector interface between MB and KB are clean and dirt free.
Apart from that, the only thing I can think of is that the repalced board may be defective..
Posted on Jun 15, 2008
  • Swilin Sampson
    Swilin Sampson Jun 17, 2008
    you will have to flash the BIOS
  • 790 Answers
Hello brentlewis !!
About the single key shortcuts , can u just try reinstalling the keyboard drivers!! It might help u in resetting it as i know !!
And for the DAQ card try connecting to other slots ..
Regards
Smilemaker.
Posted on Jun 14, 2008
    Guru:
  • 1,894 Answers
Are the keys removable in your keyboard? if so try removing and cleaning it
    Master:
  • 638 Answers
I will answer you in a movement.
  • 1 more comment
  • hemant somaiya
    hemant somaiya Jun 14, 2008
    remove the cmos battery then restart then reinsert.then see how it works.
  • hemant somaiya
    format it properly for your laptop problem.rate this solution as fixya.
  • hemant somaiya
    try running a maintanance on ur drive on which u hve loaded ur operating system.any more help required let me updated about it.
Laptop keyboard mouse not working
Toshiba has released a few different advisories related to its Satellite line of laptop computers having keyboard problems. Remember that damage caused by liquid or physical damage is not usually covered by warranty.
Bios Fixes
On Satellite models 1955-S801, 1955-S802, 1955-S803 and 1955-S804, the BIOS (system utility setup program) had trouble reading the firmware for the wireless keyboard. BIOS version 1.40 repaired this problem. The BIOS flash program can be downloaded from the Toshiba website. http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=kc&externalId=286356xml&sliceId=&dialogID=124900040&stateId=0%200%2084585964 b> Satellite 1955 Text Anomaly b> Toshiba reported a strange, software-specific problem between the Satellite 1955-S801 and S803 computers and Microsoft Word and Excel. Users who held down the shift key for more than five seconds while using the arrow keys would see their highlighted text disappear. The only provided solution was to use an external keyboard attached with a PS/2 connection or to release the shift key if pausing while highlighting in those programs. General Troubleshooting for Satellite Keyboards b> For general concerns about the keyboard -- if it doesn't appear to be working -- try these few steps. Use the keyboard before Windows loads: hit F1 on the first screen that appears after turning the system on. If they keyboard works here, it's probably a Windows problem. Try attaching an external keyboard; if it works, the internal keyboard is likely broken.
Toshiba Laptop Mouse Problems
Some symptoms that occur with Toshiba laptop mice include jumping and vanishing pointers. These situations have occurred after software upgrades have been made. The problems can often be solved by following basic mouse troubleshooting methods. Overall, Toshiba laptop mice contain the basic functions characteristic of the USB variety.
Function b> The mouse device is used to move, open, delete and otherwise connect with items available on and through the computer monitor. In Toshiba laptops and many others, the mouse pad replaces the point and click USB mouse device. This enables the mobile computer laptop to be more compact, portable and ready to use. b> Features b> The mouse pad on a Toshiba laptop is located in the middle, directly below the keyboard. The control buttons, both primary and secondary are situated below it. The primary key, on the left, represents the left-click button on an USB mouse device. The secondary key on the right represents the right-click button on an USB mouse. This button is used to pull up the short menu of an item after selecting it. Update Keyboard Driver b> Many Toshiba mouse issues can be solved by updating the driver. The driver enables the mouse to function properly. Update the keyboard driver first to increase mouse and keyboard device compatibility. To complete this task, click "Administrative Tools," accessible from the Start menu. Next, click "Computer Management," and then select "Device Manager." Click the "Keyboards" expansion node to bring up the list of installed hardware, and then right-click on the keyboard that is in use. If the "Update Driver" option is available, click on it. Otherwise, select "Properties," go the "Driver" tab and press "Update Driver." Device Manager is a useful tool to update, rollback or uninstall incompatible drivers. b> Update the Mouse Driver b> Update the mouse driver by following most of the instructions in the above section, "Update Keyboard Driver." However, after selecting "Device Manager," click the expansion node next to "Mice and other pointing devices." Select the current mouse device in use and right-click on it. If the "Update Driver" option is available, click on it. Otherwise, select "Properties" and go to the Driver tab and press "Update Driver." b> Check BIOS Fixes b> Some older Toshiba laptop models require BIOS (Basic Input/Output System) fixes. Most of the downloads are available from their website. Since, the BIOS chip is the liaison between the hardware and software, any issues should be addressed promptly. Symptoms, such as erratic mouse behavior or the pointer disappearing, are signs of a need for a BIOS fix or driver update. b> Compatibility b> Toshiba and most Microsoft Windows products are compatible. This is vital when it comes to updating necessary drivers needed for continual operating system function. The service packs they approve of are listed on their website. Hope this helps.
b>
Dec 26, 2012 | Toshiba Satellite L850-BT2N22 Customizable...
Computer will not turn on
Toshiba Satellite PSAFGU-00L002 is also known as Toshiba Satellite A215-S7437.
http://www.superwarehouse.com/Toshiba_Satellite_A215-S7437_Notebook/PSAFGU-00L002/po/1506166
Power Button Board, for the Toshiba Satellite A215 series of Notebook PC's,
http://www.zkarlo.com/selected-zkarlo-part/power-board-p3326.php
The A215 series is just a fancier version of the A200 main series.
This is a pictorial disassembly guide for the A200/A205 series,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-1.htm
Follow Steps 1 through 17. You can click on any photo to enlarge.
1) Remove ALL power to the laptop. Remove the AC adapter (Charger) and Battery.
2) Use a multi-compartment container for the various screws you will remove. Label each compartment for the area the screw/s come out of.
If no multi-compartment container is available, you can substitute with a clean egg carton.
Label each egg holder.
SOME screws look VERY similar to other screws. DO NOT mix them up.
3) Follow Anti-Static Precautions.
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
It would be best to buy, and wear an ESD wrist str-ap, and have the alligator clip attached to a good ground source.
(I connect to an unpainted surface, of the metal frame of an open, empty desktop computer case)
{Electro Static Discharge. One example of an ESD wrist str-ap,
http://www.radioshack.com/product/index.jsp?productId=2103245 }
This is a link to a free Service Manual, for the Toshiba Satellite A215 series of Notebook PC's,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-toshiba
Scroll down a little to the subheading - Satellite A10. (A10 is in blue)
Scroll over, and click on the blue - A215
The service manual is in PDF file form. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name { A215 } it may take up to 30 seconds, before the first page comes up.
The page number box is at the top of the PDF file, to the right of the Down Arrow. The Zoom In, and Zoom Out icons, for viewing size, are to the right.
The Bookmarks Menu is to the left.
Page 179 starts the replacement procedure for the Function Button Board.
In the Bookmarks menu it is;
A) Left-click on the + sign to the left of - Chapter 4 Replacement Procedures
B) Scroll down, left-click on 4.20 Function Button Board
Display Assembly, Strip Cover above Keyboard, Keyboard, and Top Cover, need to be removed in order to access, and replace the Function Button Board.
You can click on each individual area, Keyboard (Page 152), and Display Assembly (Page 155)
Removal of the Top Cover is covered in Display Assembly.
From your diagnoses of the problem, I also concur with Function Button Board replacement. (Power Button Board)
Would appreciate if you would post back with your findings, in a Comment.
Regards,
joecoolvette
Jan 15, 2012 | Toshiba Satellite Computers & Internet
Some keys not working
if the keys r not working its not software problem its hardware problem and it can only be set to right in shops
Jan 05, 2011 | Toshiba Satellite A10 Notebook
How do I remove the hard drive in Toshiba SatellitePro A10 EN? (Removing the plastic cover exposes only the end of the hard drive. I'm reluctant to just start pulling on it!
  • The original Toshiba Satellite Pro A10 HDD is fitted into a Toshiba Satellite Pro A10 Hard Disk Drive cradle - Toshiba Satellite Pro A10 HDD caddy.
      • Gently remove the cradle from the laptop, yes pull on it
      • Unscrew the original Toshiba Satellite Pro A10 Hard Disk Drive & remove it from the cradle.
      • Screw the new Toshiba Satellite Pro A10 Hard Disk Drive into the cradle & refit the cradle into the laptop.
      • Re-install XP or Vista
          Aug 21, 2010 | Toshiba Satellite A10 Notebook
          The m and caps lock keys on my Toshiba satellite
          Bad keyboard. This series have a higher frequency of keyboard problems because ... well .. the keyboard cable got folded by design. Just replace it. The A40's uses the same keyboard as a A10, A15, A55, A60, A64, 1400, 1405, 1410, 1415, 2400, 2405, 2410, 2415 ... and many others. A new replacement keyboard should run about $20 on eBay.
          Replacing the KB is easy: lift up the power button board above the keyboard, remove the three screws holding the keyboard down, then remove the keyboard connector cover panel, and you'll be able to disconnect the keyboard.
          Oct 11, 2009 | Toshiba Satellite A40 Notebook
          HOW DO I CHANGE CD/DVD DRIVE IN A TOSHIBA SATELLITE P105-S6114?
          You can use the Toshiba Satellite guide for removing and replacing the DVD/CD-ROM drive or the keyboard. On this model you have to remove the keyboard in order to remove and replace the DVD/CD-ROM drive because the optical drive securing screw is located under the keyboard. Always start laptop disassembly with removing the battery or you can damage the system board if you accidentally touch it with a screwdriver and shorten traces. Removing the keyboard strip is not very difficult, use your fingers to release the plastic latches. If you want to replace the keyboard, do not forget to unlock the connector on the system boar before you pull the cable.
          Sep 21, 2009 | Toshiba Satellite Pro A10 Notebook
          Toshiba Satellite a105-S2716 keyboard doesn't work. Soda spilled on it. External USB keyboard does work. How do I fix it?
          I think your Toshiba got grounded or short circuit inside. Better also to use USB Keyboard, it works.
          Aug 18, 2009 | Toshiba Satellite A105-S2716 Notebook
          Technical help
          http://www.drivershq.com/Drivers/Toshiba/Satellite/A10-S167/4183/9941/10569/Drivers.aspx and http://www.soundcard-drivers.com/drivers/162/162947.htm for the sound and networking..do look at the toshiba site for the display driver..or you can run windows update or a software called driver detective..
          Oct 29, 2008 | Toshiba Satellite A10-S167 Notebook
          Toshiba SATELLITE A10 A15 A20 A25 A35 A40 A45 SATELLITE PRO M15 SERIES 15 INCH XGA LCD DISPLAY -LQ15 (LQ150X1LHC3B) CD-ROM Drive Logo
          177 people viewed this question
          Top Toshiba Computers & Internet Experts
          Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
