Question about IBM Lenovo ThinkPad T400 7417 Notebook
I cant bypass the fingerprint logon because i erased it, so how do i go straght to the windows login
Bios fingerprint reset
In Windows, in the settings section of the Fingerprint Control Center, uncheck Replace windows logon with fingerprint protected logon. In the Fingerprint section uncheck the Power-On Security section if the user has fingerprints enrolled there. You do not need to uninstall the software unless you wish to.
Oct 03, 2013 | Lenovo Computers & Internet
Tip
Forgot or Lost Windows 7 Password - Useful Solutions You Need to Know
There are many situations in life and work which may lead to or cause password lost in Windows 7. Luckily enough, there are several useful solutions that can be used to reset Windows 7 password, for whatever reason you cannot regain access to your computer. Following are listed 6 effective methods that you can make full use of to bypass a lost Windows 7 password.<br /><br /> <img src="forgot-password.jpg" /> <br />1. <b>Perform <a href="http://www.recoverwindowspassword.com/windows-7-password-recovery.htm">Windows 7 password reset</a> with an administrator account</b>. Users of administrator accounts have full control over the Windows system. They are permitted to install software programs and hardware drivers while entitled to reset password of another user accounts(including other administrator or standard user or guest accounts password). So if you forgot a user account in Windows 7, you can try to reset it through an accessible Windows 7 account with administrator permissions. It's the easiest way.<br /> <br />2. <b>Resort to Commercial Windows password recovery tool</b>. Considering the actual needs of Windows 7 password recovery when one failed to log on computer, some software providers also offer various commercial Windows password recovery tools fully compatible with Windows 7. Here we highly recommend you try Windows Password Breaker if you <a href="http://www.recoverwindowspassword.com/">forgot Windows password</a> and needed a password recovery tool, which can help you create a bootable password recovery CD/DVD or USB flash drive to reset lost password in a few minutes.<br /> <br />3. <b>Seek for free Windows password recovery tool</b>. In addition to commercial software, free Windows password recovery software out there can also help you recover a lost password in Windows 7. If you want to recover Windows 7 password without charge, Ophcrack and NT Offline Password & Register, the most popular recovery software, may be your best choice. <br /> <br />4. <b><a href="http://www.recoverwindowspassword.com/reset-windows-7-password.html">Reset Windows 7 password</a> with Installation Disc</b>. If you have a Windows 7 installation disc, it's not a big problem for you to log on your computer again if you get its password lost. Just insert the installation disc in computer and boot to the recovery options to do Windows 7 password reset. What's more, a system repair disc that also enables you to access the recovery options. But the repair disk need to be created in advance, before your password is lost.<br /> <br />5. <b>Use Windows 7 password reset disk</b>. A forgotten Windows password can be easily reset with a password reset disk, you also need to create a password reset disk for your Windows 7 account in advance(before you lost password). Please note that many users <a href="http://www.recoverwindowspassword.com/reset-windows-7-password.html">forgot Windows 7 password</a> without having created a password reset disk. If you don't have one, please start to create one right now, you will need it some day. <br /> <br />6. <b>Bypass a lost password with Fingerprint logon</b>. Nowadays password is not merely limited to letters, numbers and symbols. It can also be your fingerprint. In Windows 7, fingerprint logon can be easily enabled if you are lucky enough to have a laptop or computer with a biometric sensor, such as a fingerprint reader. If the fingerprint logon enabled, it is easy for you to bypass a forgotten or lost Windows 7 password.<br /> <br />If you have lost your Windows 7 password, select one method of the above which adapts your conditions to reset your password. At last, i recommend you to create a password reset disk when you set a Windows 7 log on password, it's a feature in Windows for one to easily reset a lost password. <br />
on Jan 27, 2011 | Computers & Internet
Does Hiren's 15.6 erase fingerprint lock?
No it doesn't.
If you press Ctrl - Alt -Del you maybe able to get a password login box, and if you are lucky the administrator password may not be set and you can just press Enter.
If these solution do not work the the onlt option is to re-install Windows or install Linux such as Ubuntu.
Mar 11, 2013 | Computers & Internet
I have an ibm t43 laptop that got fingreprint protected, how do i remove the protection
Thanks
Mar 27, 2011 | IBM ThinkPad T43 Notebook
I have HP pavilion laptop. When I reopen the laptop after sleep mode it shows user (administrator) locked. I give the user password, but it's not working. It's showing password incorrect. Is any one there...
This document pertains to the HP TouchSmart tm2-1000 Notebook PC series.
The fingerprint reader login window is not detected when the notebook resumes from a Standby, Hibernate, or powered off state. Additionally, a password cannot be entered because the flashing login window defaults the cursor to the start of the entry field.
Download and Install Fingerprint Reader Driver
To resolve this issue, download and install the latest Validity Fingerprint Sensor Driver for Microsoft Windows 7 .
Any use?
Dec 27, 2010 | HP Pavilion dv9000z Notebook
Note book locked on password and i cant open the notebook
Please check when you get the password, if you get a password after the Dell logo before the Windows logo then its the BIOS password. - You need to contact Dell for the same.
If you get the password after the windows logo - windows logon password, then you need to specify the windows version for trying to bypass the passwords.
Dec 25, 2010 | Dell Inspiron 1545 Notebook
HAVEA TOSHIBA LAPTOP WITH A FINGERPRINT IDENTIFIER TO OPEN WINDOWS, WANT TO CHANGE THE FINGERPRINT TO MY DAUGHTERS. HOW DO WE ACCESS THIS?
dentifying the fingerprint readerA fingerprint reader provides extra security for the PC. The VeriSoft Access Manager by Bioscrypt uses the fingerprint reader to identify the user, and controls access to Windows or other secure systems. Instead of typing a User ID and password, you can move your finger across a sensor to logon or start commonly used applications. Verisoft Access Manager can manage all of your different secure accounts and the required user names and passwords by recognizing your fingerprint.On HP notebook PCs, the fingerprint reader is a small metallic sensor located near the keyboard or display. By swiping your finger perpendicular to the metallic sensor you can logon to the PC, a network, or open a program. c00897920.gifBefore you can use the fingerprint reader, you must set up the fingerprint reader by registering your fingerprint with the Access Manager. Set up the fingerprint reader To set up the fingerprint reader to recognize a user, the user must have a logon account on the PC and the account must have a password. Multiple users can be registered for the fingerprint reader if each has their own user account.
  1. In Windows, double-click the VeriSoft Access Manager icon c00897921.gif in the notification area of the taskbar to open the My Identity window. Alternately, click Start > All programs > Verisoft > My Identity .
  2. Click Log On to open the VeriSoft Logon Wizard. Click Next to begin.
  3. Enter the User's Windows password in the Password field on the Introduce Yourself page, and click Next . If you have successfully logged on to Windows, click Finish to close the wizard.
  4. Click Register Fingerprints on the My Identity window, to open the VeriSoft Logon Wizard. Click Next to begin. c00897922.gif
  5. Select a finger shown on the hand graphic, and then slowly swipe your finger across the sensor. One of the squares below the hand graphic will change color when the scan is accepted. A message displays if the scan is not accepted.
  6. Swipe the same finger across the sensor again until all four squares change color, then clickNext to register the finger print. If you need to start over during the fingerprint registration process, right-click the highlighted finger on the screen and then click Start Over .
  7. If prompted to register a second fingerprint, click a different finger on the hand graphic, and then repeat steps 5 and 6.
  8. After using the Registration Wizard to registered at least 2 fingers, click Finish .
  9. To set up the fingerprint reader for a different Windows user, log on to Windows as that user and then repeat steps 1 through 8.
After registering your fingerprint you can log off and then use your registered fingers to log on to Windows. Using Fingerprint reader before registeringIf you swipe your finger across the fingerprint reader before it is set up, the Access Manager opens a logon wizard window and prompts you for informa
Feb 03, 2010 | HP Pavilion DV5234US Notebook Laptop
How to use password instead of fingerprint to logon
How to disable fingerprint reader
Nov 12, 2009 | Microsoft Computers & Internet
How do i bypass novell login if i am off of the novell tree or network? i am using version 4.91 on windows XP.
There should be a check box saying 'Workststion Only'
Check that and logon with the windows username and password, not your novell network login.
Nov 07, 2009 | Microsoft Windows XP Professional
Microsoft Fingerprint Reader
If a screen popsup requiring user input is it possible that the screen you are referring to is getting shot down by a popup blocker?
Sep 23, 2007 | Microsoft Fingerprint Reader
IBM Lenovo ThinkPad T400 7417 Notebook Logo
144 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
