Question about Bernina Sewing Machines
Bernina 1000 designer Has had cotton jammed in the bobbin area and now the needle wont pick up the bobbin thread. looks like the timing is out. how do I adjust the timing.
  • Bernina Master
  • 7,365 Answers
It has to be taken to a repair shop for the timing to be fix, they have the tools needed
Posted on Nov 05, 2010
My 532 wont pick up cotton from bobbin
First, install a brand new needle. Used/worn/bent needles will sometimes fail to pick up the bobbin thread.
Make sure the bobbin is installed correctly in the bobbin case.
If it still will not pick up the bobbin thread, most likely the machine is out of time (the needle arrives at the incorrect time to intercept the bobbin thread). Take it for service or search the internet for web sites or videos dealing with sewing machine timing.
Sep 03, 2016 | Sewing Machines
When thread cotton. Cotton don't pick up bobbin cotton please help bernette65
Be sure to use a brand new needle. A bent/damaged needle may have difficulty picking up the bobbin thread.
Verify that both upper and bobbin threads are threaded correctly. If so, and it still fails to pick up the bobbin thread, most likely there is needle/hook timing issue. Take it for service.
Aug 19, 2016 | Sewing Machines
Deco Bernina bobbin jammed, now bobbin won't work
remove bobbin and reinsert. Re thread needle . Make sure the right size of needle for the material. And check that there is not a wad of fluff under the feed dogs.
Best wishes
Aug 22, 2014 | Bernina Sewing Machines
My Bernina Deco 340 does not pick the bobbin thread but keeps saying the top thread is broken
Check the needle timing. Go to bernina on the web and download the service manual for your model. The eye of the needle should be at the pick arm of the bobbin case Too early or late and it will miss the cotton.
May 30, 2013 | Sewing Machines
12 wt thread
12 wt thread generally will not work well in the bobbin...
"Aurifil 12wt Thread
Aurifil 12 wt thread is ideal for hand quilting, big stitch hand quilting and machine quilting. 12 weight thread creates a more defined and often primitive look. It's great for designs that use a longer stitch length if using a machine. When machine quilting with 12 wt thread, use 40 wt in the bobbin, increase your stitch length, lower your tension, use Topstitch size 90 needles and stitch slowly."
May 08, 2017 | Bernina Activa 140
Needle will not pick up bobbin thread (Bernina 830) despite tightening handwheel therefore no stitching. Have cleaned bobbin mechanism and have checked and rechecked bobbin threading. Have tightened
Make sure needle is inserted with the scarf(small indentation above needle eye) to the back and fully inserted. Otherwise it could be out of time which would require a technician.
Jul 10, 2012 | Bernina Sewing Machines
The needle thread will not pick up the bobbin thread
It looks right but its not. Try looking on the internet for threading instructions. The bobbin winds in two directions, I have never saw a Bernina but I have 2 new machines and the thread goes in and then threads back to the left. Its hard to describe. But if the bobbin isn't right it will not pick up the thread. Write to Bernina for instructions. There are websites that have the directions for free.
Nov 18, 2008 | Bernina Virtuosa 160
Bobbin thread not being picked up
This unfortunately sounds dismally like a timing problem. When a sewing machine makes a sudden mechanical stop as when a needle is bent slightly and hits the needle plate, sometimes the other machine bits revolve along further causing the needle to be introduced into the hook either to early or to late to catch the thread.
To test this, remove the thread, the needle plate and and the bobbin case. Replace the needle with a brand new one. Yes, again. Revolve the machine by hand via the balance wheel and watch closely as the needle goes into the hook region allow it to it move down and then just start to move up. If the tip of the hook is not pretty close to right behind the needle than it is more than likely a timing problem.
If the tip of the hook is behind the needle in the scarf (the slight hollow on the back of the needle) than it is not timing. Thread the machine normally like it is and watch what happens as you manually turn the machine via the balance wheel. The thread should catch and be pulled around the hook and let go.
Try this and then either you figured it out the problem or contact me again. Either way please vote. Thanks
Mar 02, 2008 | Bernina Virtuosa 160
Sewing Machines Logo
312 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
silly01
Level 1 Expert
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
