Question about Epson Stylus Photo R300 InkJet Printer
Status Monitor 3
Cannot install "Status Monitor 3" software, therefor cannot see if & which ink cartridge is running out of ink.
I have tried FAQ but solution "get ink tab" on printing preferences window not available to me. The ink levels are all shown in grey colour
In reply to SOLUTION #1 by Basti i have vista and have forced it to work with this status monitor 3 software i will post how i did it now.
First i downloaded the status 3 monitor so that i could fiddle with the programs and files inside from this link here
http://driverscollection.com/?file_id=24410
Ill skip right to the part on how to fix it you extract the file you just downloaded open the folder it went to right click E_SIINS2 with a bandaid icon goto properties then click compatibility at the top of the new window that opened check the box run this program in compatibility mode for: then in the drop down box below that windows xp (service pack 2) also i checked at the bottom run this program as an administrator and boom it worked i can see my ink and everything.
Posted on Dec 06, 2008
  • SpeedBullet2
    SpeedBullet2 Jan 12, 2009
    Oh forgot to mention run this file to install the status 3 monitor STMSETUP.EXE
  • Anjeloe Victor
    Anjeloe Victor Aug 08, 2013
    Is it availabe for Epson Stylus C45?
    Genius:
  • 1,447 Answers
Which operating system are you using VIsta or XP? Vista doesnt support status monitor 3 yet, epson's developing an update for vista still. If you have XP, email me or keep me posted so that i can help you with it. Thanks!
Posted on Jun 14, 2008
How could i know if my printer runs out of ink?
Your Printer's Status Monitor tells you when the ink in your ink cartridge is about to run out. However, the Status Monitor is not always accurate. If, you turn off the status monitor, the only sign that will tell you that your ink has run out is that if your printout has white streaks or lacks the other colors.
Nov 16, 2010 | Epson Stylus 680 InkJet Color Printer
How to reset ink counter for a epson R230
The page counter cannot be set back to 0.
The ink levels on your computer is automatically checked and displayed through the Status Monitor
If any of the ink cartridges installed in the printer is broken, incompatible with the printer model, or improperly installed, EPSON Status Monitor 3 will not display an accurate calculation for the amount of ink remaining in any of the ink cartridges. Be sure to replace or reinstall any ink cartridge indicated by EPSON Status Monitor 3.
Sep 27, 2010 | Epson STYLUS R230 InkJet Photo Printer
Unable to operate epson stylus office B40W Vista due to blockage of printer by epson status Monitor 3
EPSON Status Monitor 3 displays detailed information regarding the following:
1.Current Status:
2.Ink Levels:
3.Ink Cartridge Information
Please follow the error message prompt, seems like that you need to replace the cartridge for the printer.
If this doesn't work for you, please comment and let me know, and I will be more than happy to assist you to further resolve your issue.
Sep 26, 2010 | Computers & Internet
Replace ink cartridges
1 - Open the top lid 2 - Open the ink cartridge carrier 3 - Shake the ink cartridges 4 - Unpack the ink cartridges 5 - Remove the yellow tape from each cartridge as you get ready to install it, but not before 6 - Install each color cartridge into its corresponding color slot pressing down all the way until it "clicks" 7 - Close the ink cartridge carrier 8 - Close the top lid
At this point the printer should charge its ink cartridges. Let this finish before using your printer.
Hope this helps!
Feb 18, 2010 | Epson Stylus Multifunction Inkjet Printer/...
How do I know WHICH of the ink cartridges is out?
I found this on the Epson Web Site. If you find this information helpful, pls rate me.
You can download the Reference Guide with pictures and all.
http://files.support.epson.com/htmldocs/r220__/r220__rf/index.htm
Windows
You can check the amount of ink remaining in the ink cartridges using EPSON Status Monitor 3 or the progress meter. Refer to the sections below for details.
EPSON Status Monitor 3 Access EPSON Status Monitor 3 in one of the following ways.
  • Double-click the printer-shaped shortcut icon on your Windows taskbar. To add a shortcut icon to the taskbar, see the section below.
    font26.gif See Monitoring Preferences
  • Open the printer software, click the Maintenance tab, then click the EPSON Status Monitor 3 button.
A graphic displays the remaining amount of ink.
Pls rate me. Thanks and Good Luck.....
Feb 09, 2010 | Epson Stylus Photo R220 InkJet Printer
Is there a workaround for using alternate brand ink cartridges in my Epson CX9400Fax printer? I have been using off brand cartridges in nthis printer for a while now but I just put in a black and it shows...
You might want to try disabling the status monitor software that is installed with your printer driver.
To do this you
  • Locate your printer in Printers & Faxes
  • Right click and choose printing preferences
  • Choose the "Maintenance" tab (top right)
  • Locate the "Speed & Progress" button and click it
  • Tick the "Disable EPSON status monitor 3" box
  • Click on OK and then OK on the previous box
You should now find that any computer generated nags screens leave you alone.
This doesn't always work but it's definitely worth a try... Also worth considering that you have bought or been mis-sold cartridges that are not compatible with your printer... It does happen.
Hope that helps.
Martin
Sep 29, 2009 | Epson Office Equipment & Supplies
The red light has come on to replace the ink cartridg, i only use black ink then i tried to reset and the red light is still on and it will not print. the colour cartridges are about 3 years old???????...
Check status monitor? See difference of chip reach ink out and not recognized. Reset chip that ink level reach ink out. Also check chip connector at ink tank and at chip itself. Plug ink tank securely. Check status monitor again. If still not resolved, try to use anither chip.
Aug 18, 2009 | Epson Stylus C86 InkJet Printer
Canon Pixma iP1800 Ink Monitor won't work
Have you enabling ink status monitor? Find the resetter at indoreset.blogspot.com. For clening the waste ink u must open the case first. wash the waste ink pad.
May 29, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Epson C60 Stylus Status Monitor Does Not Work On Windows Vista
I ve been having the same problem with my Epson 1290 and Windows Vista! It works fine but I cant get the status info on my ink levels. Its so annoying when u run out of ink the LED on the printer goes on but you dont know whick cartridges to replace! I hope Microsoft and Epson get this sorted out because it so annoying and I end up spending more money on inks than needed! I read someone had similar problem, installed the 1290 M driver (via Vistas set drivers) but it didnt work for me!
any other suggestions?
Apr 18, 2008 | Epson Stylus Photo 1290 InkJet Printer
Can't use compatible ink
You need a chip-resetting tool.
Or use the printers software utilitie changing ink cartridge, some printers insist that you go into your printer software/program. to inform or communicate with the printer, that you are changing a Cartridge. then the printer, will move the printhead to the desired position, to remove the cartridge.
When the new cartridge is installed, the printer is set to look for new changes. make sure you,ve inserted the cartridge fully into it,s slot ( holder ) push until you get a slight click.
If you,ve disabled Status monitor, then your printer cannot output the Cartridge Status. ( empty-Full )
mike @ Compurepair.
Feb 25, 2008 | Office Equipment & Supplies
Epson Stylus Photo R300 InkJet Printer Logo
1,562 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
