Question about Netopia (3347NWG-VGX) Wireless Router (3347NWGVGX)
Tried 192.168.1.1 to get in also tried 192.168.1.254 cant gain access to the router to adjust some configs
    Problem Solver:
  • 6 Answers
You do need to find the IP....
Using a Windows Computer.... Get to a C: Prompt...
"Start", "Run" ...in white space.... enter "cmd"
At the C: prompt..... Type "arp -a" and hit the enter key.
Above command will show all IP's on your network.
Posted on Nov 06, 2010
Hello I am trying to to install my new 7550 Netgear router but I cannot access this ip addresses 192.168.254.254. Please help I cannot access this pos lol Thanks Miles
this may be a bit technical ,but stay with me , the address your trying to access is in a different subnet (security reason) the machine your using to access this router has to be in a Ip range of 192.168.254.0
to 192.168.254.253r it will not be able to "see" the device this address is typically used for router config as its not a common used number and so it's unlikely to have any conflicts, however after you config the router , both it and the machines on its network should be set to something in the range of 192.168.1.01 to 192.168.2.254 as this is a more typical range of numbers to use on a small network and should help to eliminate any future config problems as new devices are added in the future
Feb 26, 2016 | NetGear Computers & Internet
I have a Cisco router, series 1800, How can I block sites with this router, can you help me?
You need to create an Access Control List (ACL )
Fist of all you need to get the router to carry out DNS lookup so in config you need to add
Router(config)# ip name-server 1.1.1.1 2.2.2.2
Router(config)# access-list 101 deny tcp any host www.badsite.com eq www Translating "www.badsite.com"...domain server (1.1.1.1) [OK] Router(config)# access-list 101 permit tcp any any eq www ! to allow all other web trafficRouter
Hope this helps
Dec 10, 2010 | Cisco 1800/2800/3800 Series - 802.11b/g...
D-Link WBR-2310 cant access config
So this is only the problem of your Internet Explorer, you are trying to access your Router on its Firmware to configure IP Address to your Games but unfortunately you cannot go on to the Firmware. You got spam by any spyware at this point, all you have to do is use another explorer which are good for opening such program. How about to try Mozilla Firefox or Chrome X Explorer. See what you can do to this explorer to open up your Router. Hope this might help you and good luck for your gaming.
Aug 03, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Cant remember my password to gain access to my router to gain internet.
Should be a tiny button on back, you might need a pencil to press it, just press and hold for about 10 seconds to reset to factory settings
May 27, 2009 | Linksys Wireless-G WRT54G Router
Cant connect my ps3 to wireless internet
you can auto config your network settings on the ps3, make sure you see your wiresless network, if you dont your router is not broadcasting its ssid and you need to activate it by logging into your router from a pc ( in a browser go to "192.168.1.1", username is "admin" password ia "admin" or nothing, unless you set up otherwise)
If you dont remember your WEP/WPA code you can find it under "wireless" then "security" in the router once you have gained access as mentioned above.
If all of above is ok then check your IP on your ps3 in settings, network status (i think havent done it in a while) make note of it and go back to the router as mentioned above. click applications and gaming then dmz, enable dmz and type in the ps3 ip, save settings and perform a 30 second reboot to the router (unplug it for 30 seconds) all should be good!
one last note if you have configured everything and you cant connect or it takes ages to do anything, you may need to reposition the router, mine is on the otherside of the room and is working great =p
Feb 19, 2009 | Linksys Wireless-G WRT54G Router
DWA 552 and 2WIRE HP1000
you dont have router protected (is not yours anymore).to gain control again, you can rest config. but you need your router manual nerby, to help you config. a previous internet provider config. and so on. to reset router config, you press a reset button on the back, until the lights is off/red. then config the router on the router website( writen on botton with default user and passw.(user: admin passw: admin or password) the wan config, Wlan,...
(Use a wpa2/wep encrption level on Wlan config.)
Note: change all router passw every 30 days, or less if necessary.
Jul 24, 2008 | 2wire HomePortal 100W (1000-400026-000)...
How do i connect to my belkin wireless g plus mimmo router to check my logs???thanks...
Using your browser (Internet Explorer, Netscape etc) type the following into the Address bar: http://192.168.2.1
This is the default address for your router. If this does not get you into the configuration try http://192.168.0.1
You may need to know a password to gain access to the config utility.
Mar 11, 2008 | Computers & Internet
Port Forwarding - can't access router management
normaly you can gain entry to the router
via an ip adress you would put into internet explorer
you can get the ip adress from the manual you got with the router
failing having the book then a google serach will tip up the info you need
Nov 10, 2007 | D-Link AirPlus DI-524 Wireless Router
Netopia (3347NWG-VGX) Wireless Router (3347NWGVGX) Logo
57 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
marty morrison
marty morrison
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
