Question about Panasonic KXDT321 Phone
How do check caller ID for Panasonic KX-DT321
SOURCE: Caller ID is not working in India.
For people who have purchased cordless phone in usa and caller id is not working they should purchase fsk to dtmf converter at any local phone shop and caller id will start working.
Here is the article on various frequency used by various countries for caller id.
Hope this will help you out.
Detailed Product Description
There are 3 major caller ID specifications in the world: DTMF, ETSI FSK and Bellcore FSK. When users buy a foreign telephone devices(such as cordless phone, fax machine or computer telephony interface), may encounter the problems of non-match for caller ID standard. This will cause the device unable to display the caller ID. EX220 can solve this problem easily. This product can receive all 3 kinds of caller ID format, and convert to FSK(Bellcore or ETSI selectable) to match foreign telephone's standard.
EX220 has a rechargeable battery inside the device, during idle status, it gets power from the telephone line and recharge the battery, so no need to use or replace battery. Just plug one end to telephone line, and the other to the telephone device.
For example, if you live in Netherlands, Saudi or India, the caller ID standard is DTMF. You purchased a cordless caller ID phone from US(which uses Bellcore FSK standard), or from Germany(which uses ETSI FSK standard). You won't be able to use the caller ID feature. In this case, just get one EX220 and connect it between the telephone line and the cordless phone, your cordless caller ID phone will display the caller's number immediately.
Remark:
1. Telephone sets for UK and Japan standard are not applicable.
2. In some countries, users must subscribe to Telecom for caller ID service
Feature List
Caller ID Format Conversion --- Convert 3 kinds of caller ID(DTMF, Bellcore FSK or ETSI FSK) to ETSI FSK or Bellcore FSK(selectable)
Date/Time Stamp --- The DTMF caller ID doesn't content date/time stamp. User can set up clock of EX201, so each call will be sent with actual date and time stamp
Area Code Setting --- User can set up the area code, so the dial back feature can easily applied
Rechargeable battery powered by line --- Just connect to the telephone line, the built-in rechargeable battery can get power from the telephone line, no need any external battery nor power supply
News
Now, Multi-Line caller ID converter is available.
Posted on Jan 08, 2008
SOURCE: Panasonic KX-TG6051M 5.8 GHz -Caller ID view problem
I have a panasonic KX-TG6051CM 5.8 phone with 3 handsets. After less than a year 2 of the 3 handsets developed the same problem, almost in the same time ( a couples of hours apart). The battery indicator shows low battery and is charging continuously even though the battery is fully charged ( when i swap the battery with my 3rd handset, the battery indicator shows fully charged and works fine ). The handsets were never dropped, never used in a moisture ladden environment ( like bathroom ) and when not in use they were kept in the charger. Any help or suggestions will be much appreciated.
Posted on Mar 24, 2008
SOURCE: panasonic kx-tg6051b instruction manual
It is my understanding that the "b" on the model name only stands for black. I searched for your model with out it and found this link for the manual as a PDF. Hope this helps. Daryl
http://www.circuitcity.com/image/product_documentation/manuals/pan/PAN.KXTG6054B.MAN.pdf
Posted on Sep 17, 2008
  • 30 Answers
SOURCE: How do you turn on caller ID on a Panasonic KX TGA181AL
Is your phone operated off a panasonic system? is so you need a caller id card. if not then you would need to inform your phone service provider that you need caller id. if you have caller id and you do have the caller id card you would need to get a hold of a panasonic tech who could turn on your c.id as long as it is being provided from your phone service and the card is installed.
Posted on Feb 21, 2009
cnavarro
  • 2460 Answers
SOURCE: want to delete caller ID from my Panasonic KX-t7730
This is just a guess, because it works on my 848.
While you are displaying the CID directory, press the TRANSFER button. Repeat as necessary.
Carl
Posted on Feb 25, 2009
How to i turn on Caller ID on my panasonic kx-dt321 phone ? When an incoming caller rings it just says Line 1 . No number is displayed.The 3 other similar phones all have caller ID when someone rings
If I understood users manual which I found via internet,it is digital system for PBX,so it means you can use it 100% if it is programed thru PBX system,so you need to call your IT personel to program it
for you.
Aug 30, 2017 | Panasonic Lands Phones
How do you Set up number of rings on panasonic Kx tg6621?
Go to your phone menu setup caller id service and check the caller list and assign your ringtone for a particular ID in panasonic kx tg6621
Nec sv8100 IPK DTerm phones Nec phones Inlinecom
Jul 10, 2014 | Panasonic KX-T7730 Corded Phone
Incoming caller number not shown, only a "MAIN" is show
What exactly do you mean?. You mean caller ID not showing on other extensions except on operators?
Jan 08, 2014 | Panasonic BTS Panasonic KX-DT321 Black...
Display incoming call icd
As long as this setting is on the lines and if analogue lines a caller I'd card is installed, press TRANSFER while the handset is ringing to change the display
May 15, 2013 | Panasonic BTS Panasonic KX-DT321 Black...
Panasonic KX-TG2235B KXTG2235 Cordless Speakerphone with Talking Caller ID how to stop it
Press MENU button, scroll to Talk Caller ID by pressing up or down arrow keys, then press Select. Choose off or on by pressing the up or down arrow keys, press Save then press OFF to end
Talking Caller ID is covered on page 14 of the manual. The following link is for a download of the manual in pdf format.
http://service.us.panasonic.com/OPERMANPDF/KXTG2235B.PDF?cm_sp=Support-Operating Instructions-_-Model-KX-TG2235B-_-KX-TG2235B Operating Instructions (English)
Feb 01, 2011 | Panasonic KX-TG2235B KXTG2235 Cordless...
Caller ID not functional in Model KX-TG-9331T and 9332T
Do you have the converter that converts your caller id to U.S. caller id?
Mar 15, 2010 | Panasonic KX-T7633 Corded Phone
Feb 20, 2009 | Panasonic Lands Phones
KX-TG 1100SP CALLER INFORMATIONNOT DISPALYED
check page 18 from your user guide (or at "http://phone.manualsonline.com/mdownloads/2a9697eb-f1f9-a434-457a-98ab6de1d9cc.pdf" if you don't have the book), your security code may not be set. good luck!
Feb 26, 2008 | Panasonic KX-TG1100 Cordless Phone
Panasonic KXDT321   Phone Logo
320 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
