Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
The cl;icker works to open/shut door inside garage but not out side...signal weak...new batteries...whaT TO DO
    President:
  • 3,197 Answers
Some things to check.
Limited range of your remote controls could be related to radio frequency interference that comes from something in your home or in the surrounding environment. Certain electrical devices can radiate interference; this could be almost anything that is plugged into an electrical outlet.
Please keep in mind that the device can be brand new, or can be an item that has been in use for quite a while. Also, the item may continue to function properly as far as you are able to tell. The only problem with the item may be that it has started to broadcast the interference, with no other symptoms noted.
Some devices are more likely to generate interference than others. This includes TV cable, cable amplifiers, surge protectors, fluorescent lights, battery charging devices (power tools, golf carts, etc.), anything that utilizes a timer (sprinkler systems, lights, alarm systems, etc.), and a myriad of others. If the problem seems sporadic, we can safely assume that the device responsible for the interference is only being operated during these times. Again, please keep in mind that the age of the device does not determine if it is capable of broadcasting unwanted interference. Any electrical device can be the source of the problem.
Posted on Nov 05, 2010
All of my remotes used to work from a distance, now you must be pulled right up to with 5 feet of the garage door to use the opener. Any idea why?
Hi Jackie.
It sounds like your batteries need to be replaced in your garage door opener, they are too weak to open your garage door at a distance. Hope this helps.
May 21, 2017 | Building Materials
Garage door opener remote does'nt work when the garage door is shut
Probably you have a weak battery in your remote transmitter. When the garage door is closed it requires a stronger signal. Open the remote and replace the battery.
Oct 20, 2012 | Home Security
Have a liftmaster keypad entry. Will not open garage door from outside but will close from outside?
Sounds like a weak battery. A weak signal made even weaker by the thickness of the door.
Jan 13, 2011 | Sears Craftsman LiftMaster Chamberlain...
My wireless remote keypad stopped working. I changed the battery and it worked to get the garage door down but not up. The key pad is about 7 years old.
It sounds like your keypad is going bad and has a weak signal. It can operate the opener with the door open but with the door between it and the receiver it can't.
May 30, 2010 | Sears Craftsman LiftMaster Chamberlain...
The garage door will close fine when you enter the code on the pad, but will not open when you use the code on the pad.
The problem you have is a weak signal that is not strong enough to penetrate the door. Make sure the battery is good. If not the battery then a new keypad will be needed.
May 05, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door keypad will close garage door but will not open it any suggestions?
If your hand remotes work okay and a new battery doesn't help the keypad it is time for a new one. Sounds like a weak battery though.
Apr 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
My remote only works after i open the garage from
Make sure it has a good battery. If that isn't the problem it could just have a weak signal.
Feb 14, 2010 | Sears Craftsman LiftMaster Chamberlain...
Can enter code on keypad to lower garage door, however keypad just "flashes" when code is entered to raise door
If your other remotes are working normally I would suspect first of all a weak battery in the keypad. Secondly the keypad could be getting weak and the closed door blocks enough of the signal to cause your problem. An open door lets the signal through. Normally during the time the keypad is flashing you can hit 'enter' again to reverse the door if it is closing or stop the door if it is opening.
Oct 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster wireless keypad closes but won't open the door
If you are sure the battery is good you have a bad keypad. The signal strength is so weak it will not penetrate the door.
Aug 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Our remotes do not work when the garage door is closed, but they do work to shut the garage door when it is open. help
There are two possibilities here. One is the remotes batteries are weak and need to be replaced. The other is the receiver is going bad. If new batteries don't increase the range of the remotes then you will need to replace the logic board.
Aug 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
57 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
