Question about CDA CI592 Front Load All-in-One Washer / Dryer
When the dryer has finished the machine has water in it
I'm working on this one. I have a C1993 with the same; the drum is not draining or spinning properly to remove excess water before drying cycle. Some advice for the C1993 suggests removing and cleaning the pump as it might be blocked. I'll give it a go.
Posted on Nov 21, 2010
In a samsung yop loadinf HE wash machine, should there be water left under the drum after cycle is finished
Either clogged outlet or if you are running an aux hose to outside sometimes the water freezes causing an ice plug and wont drain .
I’m happy to assist further over the phone at https://www.6ya.com/expert/howard_977676954994c5b2
Jan 23, 2016 | Samsung DV422EWHDWR 7.2 Cu Ft Capacity...
How do I drain the water out of the machine to prepare it for moving?
Is it a washing machine or a dryer?
Dryers are usually not heavy from water.
If it is a condenser type of dryer the water collector can be removed.
If the washing machine has completely finished its last wash, there should not be much water left.
Washing machines are usually heavy because they have a concrete stabilizer block mounted on top of the drum cage.
May 11, 2014 | Dryers
Water building up during the dry cycle and clothes getting wetter
1) Make sure wash cycle is 100% finished (sometimes dryer will start before - usu on synthetic cycle & allows water to continue flowing in)
2) Manually start the dry cycle after you ensure wash cycle is finished and push in the wash cycle button.
Hope that helps! If not, you may need a new control module (I did - hope you don't!)
Apr 19, 2010 | Haier XQG65-11SU Front Load Washer / Dryer
The washer leaked water out the bottom after the wash was finished. It took 4-5 towels to soak up the water. What is wrong with the washer?
you will need to open the machine (front panel - most times its 2 screws on the bottom)
and turn the machine on & look with a flash light where the water come from...is it busted pip , or pump is bad...
good luck
911servicetoday . com
Oct 16, 2009 | Kenmore 98702 Stacked Washer/Dryer
Water constantly in the drum of the washer dryer
It is possible that the inlet valve is sticking,open
Pull the dispenser drawer right out, and see if you can see water trickling in after it has finished.
If you can, then the valve is not shutting off properly, and you will have to replace it.
The other thing you can do is to remove the top cover, and remove one by one the black hoses that go from the valve to the dispenser, and see if you can see water coming through, if you can then replace valve.
The other possibility is that the valve is getting a permanent feed from the board/timer, to check this you would need a meter to test for voltage.
Plz rate my solution.
Thanks.
Jan 16, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Fills with water and that's it
ck the water pump, only if it agitates but doesnt drain. If it completely stops after filling, ck lid switch(should here clicking noise from sw.)
Oct 21, 2008 | Frigidaire FEX831CS Top Load Stacked...
Fabric softner tray is left full of murchy water after wash cycle has finished. Machine is brand new and only been used once. Its a Hotpoint Ultima WDD960 washer dryer.
is the machine got good water pressure cus somtimes little water gets in the fabric soften tay and it dosent flush all the softner out. hope this helps.
Sep 02, 2008 | Hotpoint Ultima WD72 Front Load...
Washer/dryer
open the filter on the bottom of the machine (water will empty out).  Clear any blockage.
Oct 07, 2007 | Ariston Technologies Ariston AWD12 Front...
CDA CI592 Front Load All-in-One Washer / Dryer Logo
236 people viewed this question
Top CDA Washing Machines Experts
NOEL
NOEL
ray gallant
Are you a CDA Washing Machine Expert? Answer questions, earn points and help others
