Question about HP L1706 17" LCD Monitor
When you turn on your monitor there is no signal no image nothing ? what im going to do? i press ON button then there is no green light its stay black no such as no power
  • 11,361 Answers
Outlet is OK for sure? Otherwise you may have dead power supply with blown fuse or bad DC filter caps. You need to look inside and inspect those parts first.
This is what it looks like inside: http://s807.photobucket.com/albums/yy352/budm/HP%20L1706/
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV, Monitors, Caps : http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Posted on Nov 06, 2010
Green power light comes on goes off then on again stays solid, moniter says no signal, mouse lights up, and three red lights on key board flash then nothing why?
If the monitor power light is on or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor needs replaced.
Nov 21, 2012 | eMachines EL1852G-52W
Monitor will not stay on
Generally Monitors have a single light in fron pannel, with dual mode colors as Green and Orange.
Green: Everything is OK .
Orange: Everything is OK, except it is not getting
any signals from computer or other source.
Try with any other monitor with your CPU, it may happen that CPU actually not providing any signal to Monitor. Try checking the "NUM LOCK" button on and off, whether it makes the light on keyboard to flash on or off.
If NUM LOCK is woking OK, there is surely some problme with your monitor and you need to get is checked physically with an engineer.
Jan 21, 2010 | Westinghouse 22" Widescreen LCD Flat Panel...
Lg Flatron 17" monitor turns on you see the green light then
it's prb.. your video card not the moniter if a moniter goes from green to yellow " standby" it's prb the computer not the moniter
Dec 27, 2009 | LG Flatron L1715S 17" LCD Monitor
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
ViewSonic LCD Monitor Went Blank
It is probably a bad INVERTER and / or backlight fluorescent bulb.
Jul 02, 2009 | ViewSonic Computers & Internet
Problm with viewsonic va712b
sounds like the operating mode is at a frequency or refresh rate that is outside the viewsonic operating specifications when in normal mode. possible solution: in safe mode access control panel, system, devices (hardware) and look for display. do a right click and uninstall. repeat right click and "scan for hardware changes". That might reset the monitor operating modes but it also gives you a chance to reinstall drivers. If this does not work, try other monitor crt/lcd to see what happens.
May 29, 2009 | ViewSonic VA721 17" LCD Monitor
Monitor goes black but the green light stays on. I turn the power button off and then back on and it comes back on. It may stay on for a few seconds to several minutes.
Check to see if the image is Dimmed. Chances are the power supply on the FPD is either dead or not supplying power to the back lights.
Your problem is the back lights are not being powered. There is a signal going to your FPD because the power light remains on green, but the back lights are what helps support an image from the Front Panel Display.
The only way to fix this is to open it up.
If its got 3 boards inside((logic-->video, Inverter, Power)) The problem is the Inverter. Replace it.
The inverter is the board that supplies power for the backlights to turn on. The backlights
provide a light.for the LCD Panel(provides color and is the logic. ... similar to a projector.
If its got 2 boards inside ((Logic-->video, Power)) The problem is the power supply. The inverter is embedded onto it.
Simply replace the part with a known good one, and you got a spanking new monitor.
Sep 18, 2008 | Computers & Internet
HP desktop monitor problem
hi try this ,,,
  1. Ensure the video cable is connected (and connected to the correct video port).
  2. Turn off the monitor using the monitor's power button and then restart the monitor.
  3. Cycle the power on the monitor as follows:
  4. Turn off the monitor. The power light on the monitor should be off. Leave the computer turned on.
  5. Unplug the power cord.
  6. Wait 5 seconds.
  7. Plug in the power cord.
  8. Press the power button on the monitor to turn on the monitor. One of two things happens:
    1. The image from the computer displays on the monitor and you can use the computer again. This indicates that the monitor was unable to detect that the computer had awakened from suspend mode. Turn the monitor off when it is not being used or disable suspend mode. For some computers, updating the BIOS corrects these types of suspend problems.
    2. The power light on the monitor comes on but the screen displays one of the messages again. The monitor is not receiving a video signal from the computer that it can detect and use. Continue using these steps to adjust the Windows display resolution to the Monitor's native (default) resolution
    3. Connect the monitor to another computer that you know is working to determine if the monitor should be serviced or replaced:
      • If the monitor displays an image from another computer, you know that the monitor works. Troubleshoot the video connection and graphics adapter on the computer.
      • If the monitor remain blank when connected to another computer, the monitor signal processing hardware may be bad. The monitor should be repaired or replaced.
      hope it will work for u .. little_angel
Apr 30, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
HP L1706 17" LCD Monitor Logo
81 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
