Question about Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher mod GU2455xts03 stops at number 97 and does not complete cycle.
Dishwasher does not complete cycle
Does it have standing water after cycle? If so you can turn the knob until you hear the water kick into the sink. let it drain this way completely and stop the dishwasher before it starts to add more water. turn the dial or switch to its off location and the let the dishwasher cycle completely to ensure issue is solved. Your dish washer is "short cycling". This usually works 9 of 10 times
Oct 28, 2013 | Dishwashers
Dishlex dishwasher won't complete a cycle. Number 60 shows up and a small flashing line. ??????
Drain pump is blocked. .If you are good with tools you can clean it yourself. Let me know
Mar 28, 2013 | Dishwashers
My dishwasher stopped working, bought within the past few months, it seems like no power is getting to it. I've checked the breaker and all other appliances in house are fine.
Please provide make and model number of the dishwasher along with some indication of the last cycle it completed before this problem occured.
Aug 30, 2011 | Dishwashers
I have a Bosch dishwasher purchased in 1996 or 97. The dishwasher stopped working part way through the wash cycle. The on/off light does not come on. The on/off light does come on, at times, when you...
It sounds like the problem maybe with the door lock circuit. This is a safety feature that is the door lock mechanism, it completes the circuit to allow the dishwasher to run when the door is locked. Reading your trouble note you state the light goes out when you attempt to close the door. Light out means there is no circuit through the door lock mechanism so the dishwasher will not work. Take a look at the lock with the door open, make sure it seats properly, though it maybe opened internally, this would require a professional to fix.
Feb 21, 2011 | Dishwashers
Whirlpool dishwasher mod.ADP80 PC show error F6, feeding water is ok , filters are clean, another solution ?
It would be helpful to know how far into the cycle does the error show up.
Also does it go away when you turn power to dishwasher off and back on.
If you can operate the dishwasher then try in Rinse only and see if it completes the program.
Nov 12, 2010 | Whirlpool Dishwashers
Fault light flashing,
Is it please possible for you to add additional comments in your query about dishwasher problem
1. make and model number of dishwasher
2. are there any fault codes or lights showing up - which ones
3. at what cycle does the operation stop - eg still washing and there is water in dishwasher - is it warm/ cold, rinse is starting (can hear the pump) but stops halfway, rinse is complete but does not dry..
4. how old is the unit
clarification on above will help understand the problem better.
Jan 03, 2010 | Whirlpool 24 in. ADG7540 Built-in...
Dishwasher stalls
If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
May 31, 2009 | Bosch SHU4006 Dishwasher
Whirlpool Dishwasher,serial number 330251002448 wont stop beeping
The main controller appears to be very confused or failed.
To test, fully remove power from the diswasher for at least 90 seconds. Power back on and test. If the same behaviour is seen, the controller card has almost certainly failed. A service call is the next step to repair.
If you reply, please include the model number of your Whirlpool Dishwasher. Good Luck!
Mar 30, 2009 | Dishwashers
Whirlpool GU2400XTP Built-in Dishwasher Logo
66 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
