Question about InFocus Office Equipment & Supplies
Our projector is shutting down after 5 minutes we have lots of lamp hours left and after trouble shooting tried factory reset. Now in addition to having only 5 minutes of projector time our image is upside down! Help!
How to check the battery power in the ups
Posted on May 30, 2011
    Scholar:
  • 79 Answers
It sounds like the dc power supply on the projector has gone out, I would suggest inspect it and replace as necessary.
-David.
Posted on Nov 05, 2010
The 4100mp dell projector will kick off about 5 minutes after bing turned on. I read somthing about a filter possiblly being cleaned.
hi,
Try to reset the lamp hour of your projector. For that do the following.
1. power on the projector.
2. Press the menu button
3. select lamp settings
4. Select lamp reset
5. Select yes to reset the lamp hour.
OK
Jul 29, 2011 | Dell 4100MP Multimedia Projector
Projector does not stay on more that 10 minutes. Some said it could be the bulb or lamp.
hi,
Its because you projectors lamp have to replaced. It is notifying that you have to replace the lamp. if you wish to use the same lamp then you have to reset the lamp hour timer. it is recommended that you have to reset the lamp hour only after replacing the lamp. do the following for reset you projectors lamp hour.
(1) Press the MENU button to display a menu.
(2) Point at the ADVANCED MENU in the menu using
the up arrow/down arrow button, then press the right arrow button.
(3) Point at the OPTION in the left column of the menu
using the up arrow / down arrow button, then press the right arrow button.
(4) Point at the LAMP TIME using the up arrow / down arrow button, then press the right arrowbutton. A dialog will appear.
(5) Press the right arrow button to select "OK" on the dialog. It performs resetting the lamp time.
ok
Apr 29, 2011 | Hitachi Cpx2510 Projector Cpx2510 Xga...
My benq projector turns on for a few minutes (light and fan going strong), then it shuts down.
if it goes through shut down mode (lamp first and fans run a while), reset the settings to factory default. while you're in the menu, check the lamp hours (under settings). if they're close to 2000 hours, replace the lamp. if the projector shuts down immediately, fans and all, you have a power supply problem. you'll need to replace it.
Nov 30, 2009 | BenQ Office Equipment & Supplies
Panasonic projector keeps shutting off
http://www.youtube.com/watch?v=6jGwB05_gdk
5 minute fix guaranteed
worked for me
Apr 05, 2009 | Panasonic PT-AX100U-EC DLP Projector
Mitsubishi HC900 Projector shuts down after 5 minutes.
You have 1 of 2 possible problems.
(1) You need a new lamp.
(2) You have an overheating problem.
Just a quick couple of notes about your projector. It is a DLP projector (not LCD) and as such the machine as no air filters to clean. It does have air intake and air exhaust grilles, but no air filters to clean. This next part comes directly from the owner' manual for your projector:
When the lamp operation time exceeds 2000 hours*1 *2, the projector automatically shuts off and can’t be used until the lamp is replaced and the lamp operation time is reset.
Your machine is designed to give visual warning messages at 1500 hours used, and 1900 hours used. Did you see any visual warning about lamp life over the past few months?
If you were experiencing an overheating problem, a "TEMPERATURE!!" message would flash up on the screen just before the unit shuts down. If there is no warning, you don't have a heat problem.
If you have a replacement lamp available, install it and reset the lmap hours according to your user manual. If you don't have the manual, google it on the web (it available).
Apr 01, 2009 | Mitsubishi HC900 Multimedia Projector
Shuts lamp dwons as if over heated. Lamp 4200 hours.
You need to reset the lamp hours. Here is the manual to tell you how to reset.
http://www.projectorcentral.com/pdf/projector_manual_2606.pdf
Good Luck and please Rate. FixYa!
Mar 12, 2009 | Panasonic PT-AE700U Multimedia Projector
Viewsonic PJ556d shuts down after 30-60 seconds
My solution sounds dumb, I had the same issue. Took the lamp cover off the bottom. The screws were loose holding in the lamp. Maybe they heat and expand and eventually work their way out and the lamp doesn't make good contact. Just tightened mine up, the unit would power off after 45 minutes prior. Been on now for 5 hours, no trouble.
Sep 15, 2008 | ViewSonic PJ556D DLP Projector
PT-LC50E LCD Projector
With power available at the projector and the lamp off (projector off) - hold the input button on and press the power button on and hold for 5 secs. This will reset the lamp timer to zero.
I wish they could have stuck this in the operators manual.
May 25, 2008 | Panasonic PT-F100NTU LCD Projector
Toshiba TDP S8 projector shuts down suddenly
The reason why the projector is shutting off is so the lamp doesn't explode. It's more of a safety feature on the projector, you can reset the lamp and it might work for another 500hours. If the picture is still pretty bright I can get you the reset procedure, but be warn that when the lamp does eventually blow it could shatter the glass inside, so be careful, it shouldn't hurt the unit.
Dec 09, 2007 | Toshiba TDP-S8 Multimedia Projector
Reset after lamp replacement
benq mp610. press EXIT button for five sec. you see counter hrs. then press AUTO button to reset
Oct 13, 2007 | BenQ (200NSH-LAMP) Projector Lamp for...
238 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
