Question about Sony BRAVIA KDL-40W3000 40 in. LCD HDTV
TV went completely black with only the green power light on steady.
Check that your 'input' button is on the right setting.
Posted on Nov 05, 2010
Steady blinking green light on Mitsubishi LCD model LT 55164
I also have a Mitsubishi LT 55164 with blinking green status light...does nothing else...reset does no good, also tried to reload software with no difference. Replaced power and inverter boards button stop the same. No obvious bad components on boards. Help! Anyone ever actually fix one of these?
Aug 29, 2015 | Mitsubishi LT55164 55 in LCD TV
No power output or display.green standby light flashes.
Sounds like either a blown mainpower fuse or the thermal fuse for the power transformer. If the protect circuit was kicking in, the display would light up, but then turn off with a red blinking light. the green light with no display means the transformer is not getting power.
Dec 31, 2013 | Denon Avr-1610: 5.1 Ch A/V Home Theater...
Precision T7400 power supply sounding an alarm
Did you open the case on your computer? It may have an open case alarm which is a small switch typically located near the edge of the cover you removed. Make sure the case cover is completely installed, then see if the alarm goes off.
Feb 28, 2013 | Dell POWER SUPPLY Power Supply
Hi i purchased a 32 in. lcd tv on black friday and know i went to turn it on and it flashed and know the red and green light stay on when u power it on
Disconnect the power completely. Wait 15 minutes. Plug back in. Turn on. If it doesn't clear, use your warranty.
Jun 16, 2011 | Emerson Televison & Video
Red power light and buzzing sound with red lamp light.
My Sony lost its picture and had a flashing light. Unplugging for 36 hours solved the problem.
Mar 29, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Mitsubishi 65" model # ws-65511
The steady green blinking led is due to the DM not completeing the boot Cycle. You can get the repair kit at the following link which contains the replacement Capacitors and step by step detailed instructions so you can do the repair yourself. Very inexspensive Kit
http://servicemanuals.vstore.ca/product_info.php/pName/v21v19-mitsubishi-dm-repair-kit/cName/repair-kits
Mar 02, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Black screen sound ok
Have you tried unplugging the power for a few seconds and plugging it back in?
Aug 28, 2008 | Proscan 19LA25Q 19 in. LCD Television
No picture, no sound, power light steady green
First: Check the power outlet. Check it with a good lamp so you know you are getting power to the set.
Secondly: Check the power cord. Wiggle it around the molded ends to make sure it is not open inside the molded portion of the plugs.
Thirdly: If you know for sure the set is getting power and still no indication at all (you should be getting some little light on the front panel; standby indication) then there may be a fuse on the back panel or just inside the back cover (you will have to remove it; after unplugging the power cord) that needs replaced.
Fourthly: After all these checks if you are getting nothing, you may have some failure inside that is very serious. Normally we do not recommend serious repairs to a set over 4 years of age. This is because the set is likely to develop some other problem soon after the repair is made; further, the repairs are getting more expensive day by day while the price of new sets is coming down dramatically. Lastly, the new sets have better picture, longer lasting circuits and better features.
Hope this is a good solution for you.
thanks for your questions.
Aug 25, 2008 | RCA HD52W56 52" Rear Projection HDTV
Sony BRAVIA KDL-40W3000 40 in. LCD HDTV Logo
64 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
