Question about Dell E173FP 17" LCD Monitor
Monitor cuts out after a few minutes - Dell E173FP 17" LCD Monitor
    Problem Solver:
  • 4 Answers
Sounds to me like a power inverter. Fix it yourself with the parts found on Ebay at a cheap cost to yourself. The entire Dell E173FP 17" power inverter is selling for $29.99 plus shipping.
The fix can be found at: http://syscon.wordpress.com/2007/07/13/dell-dell-e172fpb-lcd-backlight-repair/
Cheers and good luck!!
Posted on Nov 05, 2010
Monitor Screening is cutting off. I'll turn it off for a few seconds and back on...Screen comes back and then cuts off after a few minutes
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 27, 2011 | Samsung SyncMaster 2493HM Monitor
Monitor cuts off
This could be the result of a few different things. If you haven't checked, click start, control panel, performance and maintenance, and power options. In this box, there should be numerous setting possibly pertaining to your specific problem. Also, ensure your cpu fan is running. A failed cpu fan will make your monitor turn off. Additionally you will have to make sure your power supply isn't bad. The easy fix is the first of the issues though.
May 26, 2010 | E-Machines eMachines Monitor E15T4
Compaq WF1907 monitor keeps going to sleep every couple minutes..
Sounds like the backlight may be on its way out.
Put a large font single word onto the screen in a high contrast such as white on black. Get the monitor near a window if possible, and the next time the monitor seems to go off, see if you can still feintly see the image using natural light.
The backlight can be replaced, but it is somtimes so expensive, it's easier to buy a new monitor.
How old is it?
Apr 30, 2010 | HP Compaq WF1907 Monitor
E machine monitor turns itself off and on
The same thing happened to me today. I was just sitting in my room then i hear a click and the cpu is on it stays on for a while then cuts off. It then cuts on and off with few seconds in between. It then stays in that way cutting and off for about a minite or two and then cuts off completely. A few minutes later it starts again. Also in the time it its off it will not turn on by pressing the power button. Sometimes it completly boots up by itself and then shuts itself down. If I shut it down manually while its on it'll turn itself on immeditaly after. What's going on! Will the warranty cover it? Do I need a new computer?
Feb 01, 2010 | E-Machines eMachines Monitor E15T4
Asus Monitor boes blank and comes back after power recycle
1. You can see images on the screen for a few minutes. That means there is nothing wrong with your computer.
2. When your screen goes blank, if you disconnect and then reconnect the monitor, it shows fine again for a few minutes before going blank (or dim) again. That means the problem is not with you video card.
3. It always shows the image after reconnection for exactly a few minutes before going blank again. yes? this means that there is nothing wrong with your cable.
Conclusion: Sorry, but you do not have many options. I bleieve that the problem is with your monitor that's going bad. Its far cheaper to get it replaced than to repair it.
Oct 04, 2009 | ASUS MW221U LCD Monitor
My monitor is not displaying after few minutes when it starts
Connect the monitor to the VGA-output port of any laptop.
Does it work for a few hours, or just a few minutes?
If it works for hours, then your computer's video-card is the problem.
If it works for just a few minutes, then it's time to replace the monitor (it's too expensive to get a qualified technician to try to repair it).
Jul 16, 2009 | LG Computers & Internet
I have a dodge truck and the ac works good and
ac pressures are ok, is the return pipe as drier sweating?, if not recharge system, if so you have a problem your fin sensor not reading evap temp, scan tool would be nice to monitor temp, but easy to get at , behind glove box, held in by a rubber gromet, also jump cycling switch on drier to see if it runs longer then 5 mins,possible charge again. GOOD LUCK RDJRP
Jul 10, 2009 | 1999 Dodge Ram
Emachine Monitor comes on a few minutes and cuts back off
I have the same problem and I think its the circuit board on the power on button and blue led. I unplug the board when the monitor is on and then the monitor stays on and works OK.
It don't make any sence it is only 3 parts switch led connector
anybody else run into the problem
Mar 29, 2009 | E-Machines eMachines Monitor E15T4
IBM T40 2373 display cuts off.
When it cuts out can you still see the display very faintly or does it just go completely black?
Mar 10, 2009 | IBM ThinkPad T40 2373 Notebook
Dell E173FP 17" LCD Monitor Logo
274 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
