Question about Fahrenheat Electric Hydronic Baseboard Heater, 240 Volt
I am installing a new PLF series Baseboard heater with a marley T1 thermostat on the end. The baseboard heater has one green wire with nut, which is the ground. Also has a black and red wire connected with a nut on one side and on the other another black and red wire connected with a nut. The thermostat has one single red with another single red on one side and one single black with another single black on the other. and a single green which would be the ground. I know that the red and black wires are the hot wires, but my question is which of the reds and or blacks do I attach with the ones that are on the heater or does it matter? thanks Lablover
hotuna
  • 288 Answers
SOURCE: How do I wire up a F2544 baseboard heater with a single pole themostat
It sounds like you are not getting the correct voltage for the heating element. If you wired a single pole thermostat, and its a 220v unit, then it will not get hot enough, like you are saying. If its a 220 heater, you need a 2p2t thermostat. The parts supplier will know what this means.
Posted on Mar 20, 2008
SOURCE: marley md26 line voltage thermostat
The Black Wires from the md26 are your load(the heater) and the red lines are your line(power). The lines are also paired up on the thermostat with a red and black on the left and are red and black on the right. In the actual heater connect the black to the black wire and the white to the white and connect the grounds. In the thermostat connect the black from the heater to left side black( remember there are pairs left(black, red) right (black, red) and the white to the right side black connect the black from your power to the left side red and the white from your power to the right side red. Should be ready to go.
Posted on Nov 19, 2008
  • 333 Answers
SOURCE: 220 POWER TO BASEBOARD HEATER
copy and paste this link into your browser and it will help you. http://www.qmarkmeh.com/Develop/prod_pdf/2500wiring.pdf
Posted on Dec 03, 2008
  • 92 Answers
SOURCE: dimplex baseboard heater wiring
no does not matter but you must have a ground leg
Posted on Feb 24, 2009
SRF518
  • 232 Answers
SOURCE: Marley Hydronic baseboard heater not turning on
on the one that don't work use a clamp around ammeter and see if you are drawing current. no current, the heater element is shot!
Posted on Oct 23, 2009
My electric baseboard heaters make a pinging sound which drives me nuts when I am trying to sleep! Any suggestions other than changing the unit? Thanks
Electric baseboard heaters heat by radiant heat. This mean the heater is heating the metal of the heater first which causes expansion of the metal. This will cause popping metal sounds becouse it is heating up. When it kicks off, by the thermostat, it starts to cool which causes contraction of metal. This will also cause noise. Most all base board heaters I have installed and worked on does this. Sorry there is little to nothing you can do. :)
Jan 25, 2011 | Marley HBB1004 Electric Baseboard Heater
Hello Fixya Guru ! I am in the process of installing several Marley PLF series 2000 watt/ 240 volt electric "Hydronic" baseboard heaters. I am using 10/3 bx with a 30amp breaker. To my...
You are correct that these heaters use a two-wire 240 volt supply, and the neutral is not needed.
2000 watts = 240 volt x Amps ==> Amps = 8.3 amps
30 amps x .8 safety factor = 24 amps
24 amps / 8.3 amps = 2.9 heaters per 30 amp breaker (3 heaters should be okay)
More info, pls let me know.
Charlie
P.S. Where does the 2880-watt number come from ?
P.P.S. There has to be a ground bus-bar in the panel -- if it's a main panel (not a sub-panel) the ground buss and the neutral buss are connected in the panel. Could you clarify what you have in the panel.
Jan 11, 2011 | Fahrenheat Electric Convector Baseboard...
I have a large room in my basement where I would like to install four Marly 58" baseboard heaters to work off one thermostat. The units are rated at 1250 watts each for a total of 5000watts. I plan to...
Using the equation I = P/E where "I" is Amps, "P" is Watts, and "E" is voltage, we find that your 5000w circuit will have an Amperage of 20.83. A 22 amp tstat will work, it will just leave you no room for surges. I would suggest splitting the baseboard and using 2 thermostats. Hope this helps
Aug 10, 2010 | Marley Electric Hydronic Baseboard Heater,...
Electric Hydronic Baseboard Heater, 240 Volt: WHEN I TURNED ON MY ELECTRIC BASEBOARD HEATER THER...
My PLF504 detonated this morning (11-25-2010). It worked fine for two years then BANG. Room was lit by flame coming from center (left to right) of unit. I wrote Marley asking them to honor the 10 year heater element warranty. Also, no burnt wires at thermostat connection, no dust bunnies on the fins. Source of fire was the fluid filled encapsulated heater core. Thank God, circuit breaker tripped and wall was tiled.
May 17, 2010 | Fahrenheat Electric Hydronic Baseboard...
I'm replacing a non-hydronic electric baseboard heating unit with a Fahrenheat hydronic one. My old unit was 240v using 2 conductors plus bare ground wire. The fahrenheat (PLF series) unit's instructions...
Hello. The red and the black are the hot wires. Therefore, connect one of your conductors to the red and the other conductor to the black. Use wirenuts. The bare ground wire should be solidly attached to the new unit's green wire using a wire nut.
Regards, Joe
PS: please rate my answer. Thank you.
Jan 06, 2010 | Fahrenheat Electric Hydronic Baseboard...
Oct 23, 2009 | Marley Electric Hydronic Baseboard Heater,...
I need to know how to wire the thermostat to the 30" Fahrenheit baseboard heater
if its 240v your line in to the thermostat is two hots (black and white, white in 240 is no longer nuetral and must be marked as hot) and a green/bare ground from the panel, these usually connect to the reds on the double pole thermostat. the load out is usually two black wires which are then connected to the black and white wires of the baseboard unit.
Aug 21, 2009 | Marley Heating & Cooling
Marley md26 line voltage thermostat
Nov 08, 2008 | Marley Electric Hydronic Baseboard Heater,...
Open Questions:
Need wiring help with Fahrenheat PLF754 240V baseboard heater with Fahrenheat PT2DS double-pole thermostat Open kimono - I know enough about electrical wiring to be dangerous. I have a Fahrenheat PLF754 240V baseboard heater and a Fahrenheat PT2DS (also known as Marley T2) double-pole integrated thermostat that and the heater isn't working. My power supply is a single cable with white, black, and red wires. I traced the supply line back to the circuit panel and found that the red and black wires terminate on a DP-40A breaker. The white wire is grounded. The heater has 2 red wires exiting a center tube at the end of the heater where the thermostat goes and 2 black wires exiting a small cut-out near the top of the same end. There's also a green ground wire from the heater. The thermostat has 2 red wires on the left top and bottom, 2 black wires on the right top and bottom, and a green ground wire. An electrician friend of mine (since left town) installed the wiring, heater, and thermostat for me. It worked fine for about 1 year and then stopped working. I'm trying to troubleshoot the problem but don't have any documentation on how this thing should be wired or how I might isolate the problem to the thermostat, heater, or both. I did verify that the power supply is good. Everything is currently wired as follows: Black power supply to black thermostat (top) Red power supply to black thermostat (bottom) One black heater to red thermostat (top) Other black heater to one red heater Other red heater to red thermostat (bottom) Green heater to green thermostat White power supply not connected - just wire-nutted Can anyone confirm this is the correct wiring for this configuration and, if not, what it should be? If this is correct, how best to isolate the problem? Thanks!
Dec 06, 2012 | Fahrenheat Electric Hydronic Baseboard...
See all Fahrenheat Electric Hydronic Baseboard Heater, 240 Questions
Fahrenheat Electric Hydronic Baseboard Heater, 240 Volt Logo
180 people viewed this question
Top Fahrenheat Heating & Cooling Experts
butch welch
paulcarew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
