Question about Watches
I have a Coleman watch # 40-876. the indiglo doesn't work. i put in 3 new batteries. yes there are 3 batteries and there is a small light of some sort on the top of the watch and this watch is in my opinion, very well made, its for work, rugged activities. jeff seidel
5 Suggested Answers
  • 3 Answers
SOURCE: Timex Expedition, beeps very quietly and indiglo doesn't work.
To clarify... Replace the cover with the arrow on the back pointing directly at the stem. The Indiglo backlight, alarms and chimes should all work when the back cover is in this position.
Posted on Aug 18, 2008
SOURCE: keeping time and indiglo light not working
check to make sure the button is making contact with the circuit board. It may need to be adjusted. Try and manually make contact with the copper contact. If it lights, then just adjust the tab.
Posted on Feb 10, 2009
  • 7 Answers
SOURCE: can't put (back) back on my timex indiglo
I used to work with jewelry. !!BEWARE!!
This method is for face crystals that are completely FLAT! Any convex crystal will shatter without proper tools!!!
Any method of putting the watch cover back with the watch remotely near water/moisture is a mistake. The watch will rust sooner or later.
So if you don't want to pay a jeweler five dollars to put it back on, this is what I did to my sister's watch cover when I could not snap it back.
I took my cushy 1/4 inch mousepad to a vise. You may not have a vise. If you don't, stop reading now and take the watch to a jeweler --one who replaces batteries.
Inside the vise jaws, I used a 5 inch square piece of wood, then my cushy mousepad, then the watch facing the pad, then the back in the right place for restoring.
!!!!NOTE: Not having the back in the right place will smash the stem and damage can/will result!!!
To push the back on, I picked a 12 point socket out of my socket set that was the same DIAMETER as the watch back and placed it CENTERED behind the back.
Recapping, inside vise:
  • small board
  • cushy mousepad (to avoid scarring and crystal breakage
  • watch crystal facing mousepad
  • watch back in correct position
  • ratchet socket the same diameter as watch back centered behind cover
Slowly I positioned all these items with minimal pressure. Then when I was sure that I was ready (and prepared to hear the crystal break) I put as little pressure closing the vise that I could. The I heard a snap, and to my relief, it was the back going in!
I DO NOT RECOMMEND THAT YOU DO WHAT I DID. People with broken watch crystals become very IRATE when "all it needed was a battery"!
A screw clamp would also give adequate pressure. Any unsupported direct pressure over the crystal will shatter it!
Hope this helped.
Good luck!!!!
Posted on Aug 27, 2009
SOURCE: Help me find a Coleman Watch model # 40-876
thedevilman666@gmail.com i have that watc h and i am willing to sell it'
Posted on Aug 11, 2010
Might light no longer works, had battery checked and it is fully charged. Please advise
the indiglo of your watch is probably busted, you had to replaced its dial. the the battery has been checked but not the watch by a new battery? try to check the watch by a new battery. if still not lighten up check the connection of the button it probably cannot connect the connections of the light. i hope this advise will help you a lot.
Sep 08, 2011 | Timex 2D421 Stainless Steel Perpetual...
Hello, I just bought a Timex Acqua with Indiglo
Depending on when you bought your Timex, you shouldn"t need a battery just yet, your Timex came with a good battery. Look under the stem (winder) for a small piece of plastic that is not allowing the stem to go all the way down, remove that piece of plastic and push the stem down and your Timex will start. Or if your Timex has buttons, look for a tab of plastic on the back cover, this tab of plastic is keeping the battery from (ground) a complete circuit remove this tab of plastic to start your Timex. Changeing the battery while fairly easy, you"d need jewelers screwdrivers and of course the new battery, Best Bet, look for a small watch repair shop in your area for the battery change.
Aug 18, 2010 | Timex 2J611 Watch
The light was fading on my Indiglo Timex watch but it was still keeping good time, so I had a new battery installed by a Walmart employee. The light now works on the watch but the watch stopped keeping...
mcdevito75 here, Your Timex watch is most likely an Indiglo meaning light, The battery supplies power to to Quatz mechanism for time keeping and for the light. There is a very good possibility that 1 or 2 of the contacts between the battery and the Quatrz mechanism were lost during the new battery installation. While you can"t rule out that the Quartz mechanism and or the light may be wearing down, you still have to suspect the battery even a new battery, look for a small watch repair shop in your area and try another battery, let the jewler know of your watches problem so he / she can properly install the battery and ensure the contacts between the Quartz and the battery are being made.
Jul 07, 2010 | Timex 27191 Wristwatch
Display disappears when Indiglo is pressed
That means your watch has two batteries - one for the movement and another one for INDIGLO. It may have just one battery, but in this case INDIGLO is taking up too much power. Replace the battery and you will be sorted. Rate me, plz.
Feb 19, 2010 | Timex Watches
I have a timex HRM. The indigo light just stopped working. I've had it for 3 weeks. There is a faint light on the edge, but it doesn't illuminate the face. Everything else works normal. Any ideas?
Check out if your watch has second battery for Indiglo function. It is quite common for Timex watches to have two batteries - one for movement and another for Indiglo.
Jan 21, 2010 | Timex 27191 Wristwatch
After about two years, my indiglo night light function stopped working. The watch is still working, keeping time. Will changing the battery fix the indiglo problem?
Definitely, battery change will solve the Indiglo light problem. Many of wristwatches has separate battery for Indiglo function, but my advise is to change them both at once - will be cheaper for you.
Rate me, please.
Sep 01, 2009 | Timex 2J611 Watch
Timex T49271 Expedition Indiglo button dead?
There is no separate battery for the indiglo,maybe indiglo circuit is lose or defected already,just open the watch and check for lose connection.If happen the circuit is tight and still not working then replace the indiglo circuit.
Hope it may helps you;
Regards
VOTIT
Mar 23, 2009 | Timex Expedition 40141 Wristwatch
Timex indiglo. Indiglo feature died.
The indiglo technology is time limited (it dims over the years with use) and cannot be repaired - have you had the watch a long time? if so, I'm afraid it's time to get a new one. Sorry!
Dec 30, 2008 | Timex Watches
May 04, 2008 | Timex Expedition 40141 Wristwatch
Watches Logo
81 people viewed this question
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
