Question about KitchenAid Kitchen Ranges
How do you turn on the kitchen aid superba electric oven, I'm trying to bake a cake...please help
  • 77 Answers
Check the manual, or your 8 yr old.
seriously though if you have an auto set use it and the oven should go to 350. otherwise push bake and set temp then push start if you have that button. hope the cake comes out good.
Posted on Jun 14, 2008
My kitchen aid electric convection oven (superba series) is not maintaining it's temp. I do not believe the fan is turning. My oven has only one baking element on top.
You do have a lower element. On convection ovens they are usually covered. If you look in the bottom of you oven you should see it is elevated in a rectangular metal cover. You should be able to slide it forward and lift it away to expose bottom element.
If visual inspection shows no signs of burn out on it then you will have to test to see if it is getting power.
Can you tell if the top element is working for sure?
Sep 28, 2014 | Kitchen Ranges
Kitchenaid superba stove baking element does not heat
There has to be a baking element. Find it and replace it.
Aug 19, 2017 | KitchenAid Kitchen Aid Superba Series...
Oven does not heat up when we try to bake.
no element ... there is an ignitor, u might need service prob worth repariing, if not turn if gas unplug and remove inside cover on bottom and get acess to ignitor,, u can find one locally or online at sears or u dont have to get the kithenaid part it is only more expensive it could be a 12400035 or an sgr403 depending if its a round or square ignitor those are less expensive... hope this helps let me know
Apr 08, 2010 | KitchenAid Superba® (KTRP22KRWH) Top...
KitchenAid Oven Temp.- Bottomside of Pizza or Cake stays uncooked
I have a 2yo Kitchenaid oven, and my advice is first, don't use convection for cakes or pizza. Use the thermal oven. For pizza preheat to 500 degrees, then put the pizza on the lowest rack, and bake for 7-8 minutes.This way the bottom browns, and the top doesn't get broiled from the top element coming on during the bake cycle.
As for cakes, again place them on the low rack so that they get bottom heat. I keep my eye on the oven and when the broil element comes on I stick a piece of foil over the cake until it goes off. Otherwise it will set the top and the cake won't rise as much. Even doing that cakes don't rise as much as they did in my old oven, and they brown too much on top.
The convection oven does a good job of cookies, and the broil mode is okay.
I wish I hadn't bought this oven, but I didn't know about the upper (broil) element coming on during the bake cycle until I'd had it for awhile, and it was too late to return it.
If anyone's shopping for an oven, ask questions, and don't get one that maintains the oven temperature by activating the broil element when baking.
Jun 24, 2009 | KitchenAid Architect ® II KEBS208S...
How to set the temperature on the KitchenAid Superba oven/convect
A separate oven thermometer is absolutely necessary in baking. Something similar to this would be cheap and easy.
Or you could go for a digital one with a probe.
Apr 08, 2009 | KitchenAid Architect Series KEBC107KSS...
Most ovens normally turn on the top assembly that works as the broiler to bake in order to help bake it more evenly.
Feb 16, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Kitchen Aid superba (electric oven)
you will need electrical meter. Take unit out of hole remove back plate( unplug or turn breaker off first). Turn power back on set temp for bake check leads to element. If no voltage replace control
May 27, 2008 | GE JBP69 Electric Kitchen Range
Just not workin
maybe a loosing wire. move the stove , disconect power and take the cover and look for a loosing wire at the bake element or a burning bake element
Apr 22, 2008 | Kenmore 96213 Electric Kitchen Range
GE electric oven
If this is a fan oven, make sure the fan has not become clogged or has stopped rotating.
Oct 07, 2007 | GE JSP26 Electric Kitchen Range
Kitchen Ranges Logo
258 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
