Question about Hampton Bay 24002 Ceiling Fan
Hampton bay fan noise
Humming how to oil?
  • 20 Answers
The fan does not need to be oiled. The bearings are what manufacturers described as "permanently-sealed", which means that they're designed such that they don't require oiling. The manufacturers recommend against oiling, and if you really wanted to do it, you'd have to be an expert, because there is some very complex disassembly to be done, which requires specialized tools.
HOWEVER...
The problem is not related to oil. A lack of oil does not produce a hum. If a fan's bearings are low on oil, the sound generated is a scraping or brushing sound. A hum, on the other hand, is an electrical sound. All fan motors hum to some degree -- the cheap made-in-China ones, like in your Hampton Bay fan, hum more than others. There are some steps you can take to reduce the hum:
* If you are using the fan with a solid-state control (i.e. a dimmer), that will cause the fan to hum. These controls are dangerous when used with fans, and a fire can result. You should have a qualified person remove the switch immediately and replace it with either a regular on/off switch OR a discrete-speed (i.e. 3-speed or 4-speed, rather than variable-dimmer) switch. Specially-designed ceiling fan switches such as this are available at your local Home Depot or Lowes. You could also use a remote-control system.
* If you have a remote control or other speed control system, make sure that the pull-chain speed control on the fan is set to the "high" position (highest speed possible) and left there.
* Make sure that all the screws are tight -- this includes screws which hold up the fan's mounting bracket, hold the blades onto the fan, and hold any applicable glass onto the light kit.
* Even if you don't have a speed control, the motor will still produce an electrical hum -- and the blades, which are physically attached to the motor, serve as mechanical amplifiers -- they take the tiny electrical hum and amplify it just like the big brass funnel speaker on an antique gramophone (record player) takes the tiny vibrations of the needle on the record and amplifies them to a comfortably audible level. High-end fans have a rubber flywheel attached to the motor between the blade holders and the motor unit -- and since rubber doesn't transmit vibrations well, this effectively deadens the sound. Your fan doesn't have one of these, but you can effectively replicate the noise-dampening effect by putting rubber washers between where the blade holders touch the bottom of the motor AND between where the screws which hold the blade holders onto the motor, meet the blade holders themselves. This will completely remove the path along which the sound vibrations can flow to the blades, and thus your hum will stop.
I hope this helps you! If you have any other questions, or need clarification, please ask!
Posted on Jun 17, 2008
Hampton Bay 52" Oil-rubbed bronze
If it's a Hampton Bay light kit, it should be no problem putting it on their fan.
Sep 04, 2011 | Hampton Bay 52 In. Ceiling Fan, San Tropez
My Hampton Bay runs too slow on high speed and makes slight hum.
hello,
the fan could have a weak coil that is ability to run fast or the capacitor is leaky, if found to be bad replace with a new one of the same rating..
Hope this will help...
May 31, 2010 | Hampton Bay 60 In. St. Regis Fan, Ancient...
Fan wasrunning heard aloud humming noise now the fan stopped
you could be lucky and the bushes have worn out. else its probably burned out.
AndystUK
Sep 02, 2009 | Hampton Bay 48670 Flemish Pewter Finish...
Hampton Bay fan bearing noise
its not the bearings sounds like you need to level the mount and that scraping it the fan blade mounting plate hitting the side of the 'case' that surrounds the motor assembly ive never heard of bearings in the motor going or needing lubrication other than what factory placed in them...remember Hampton Bay is the Yugo of electric appliances too
Aug 03, 2009 | Hampton Bay 24002 Ceiling Fan
New ceiling fan . Motor has humming noise.
Return it while it is still under warranty.
May 16, 2009 | Dryers
Noisey fan
use WD-40 w/ straw spray every hole you can find
Dec 18, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Hampton Bay San Marino 36" Ceiling Fan
18 gauge is a little light... should use 14. Are you sure it is a hum, or is it possibly the fan resonating due to imbalance of the blades. Watch to see if the fan is oscillating when it runs. Also, does changing the speed affect the frequency of the hum. If this is the case, you have to balance the blades using metal shims.
Sep 20, 2008 | Hampton Bay 36 In. San Marino in Brushed...
Celing fan making noise, how to oil
HOWEVER...
Apr 30, 2008 | Hampton Bay 24002 Ceiling Fan
Hampton Bay 24002 Ceiling Fan Logo
1,165 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
