Question about Gateway FPD2275W LCD Monitor
Lg monitor l194wt
How can I get my LCD monitor open? It has four screws on the back, I removed them but nothing else loosened up. Any ideas?
It's not glued!!!! It's clipped together...and DON'T take out the screws first...
First, turn the monitor upside down and look at its thin edge. See where the grey bezel meets the black case? That's your clip point, all the way around the monitor. The reason you want to start here? This monitor is VERY tight, and there's a good chance you will mar the plastic, so it might as well be in the least visible place.
Next, fit a plastic trim removal tool (you have one of those, right? Right!? :) ) in between the black and grey plastic, halfway along the length of the monitor. If you have difficulty getting it in, run it back and forth until you find a loose point, but you'll eventually have to come back to the tight spot.
Here, there's a little bit of finesse required...you have to pry the grey part (which I will start calling the "bezel") gently upward, not away from the black plastic (which I will call the "case"), perpendicular to it. This will pull a clip up out of its slot. When you feel the clip release, now you can move it slightly away from the case, but don't remove the trim tool. Keep unclipping the rest of that side.
Once you've gotten the hang of it, do the next side. This bezel is particularly tight, so don't start at the edge...you will definitely damage it. Once you've gotten two sides loose, the whole job becomes easier, but still stay patient and careful, because there's a lot of potential for damage.
Now that you've gotten the entire bezel off (and the hard part is over with), hold the LCD in place as you turn the assembly face down onto a soft cloth, like a blanket or comforter. Now you can remove the four screws from the back.
Lift the case off and remove the two screws holding the switch assembly. This will lift off easily.
Lastly, partially remove the silver tape holding the electronics case on the back, carefully remove the connectors (remembering their positions, of course), and you're ready to play electronic doctor. I'm posting this with my newly repaired L194WT. :)
Posted on Mar 05, 2010
  • 87 Answers
Its glued together... ruddy everything is nowadays... you have to take out all screws and use a flat head screwdriver or something and pry it open
Posted on Jun 14, 2008
My L194WT -SF WONT WORK NO POWER USED SAME POWER LEAD ON DIFFERENT MONITOR NO PROBLEM
Hello Steve,
The most common problem with the L194WT monitors is a failure of the power supply board. There are parts called capacitors that fail and can cause the issue you have. Sometimes the power light will just flash, sometimes it takes several minutes to display a picture or even a wavy picture, all of these issues indicate a failing power supply board. These boards can be repaired if you can do a little soldering. The L194WT uses the same power board as the L196WTQ and we have a step by step repair guide with dis-assembly instructions available at http://www.ccl-la.com/blog/index.php/lg-l196wtq-bf-lcd-monitor-repair/ Look over the guide and check your board to see if your capacitors have bulged and need to be replaced.
I hope this helps, if so please rate our solution.
BuddyMc
Aug 07, 2011 | LG L194WT 19" LCD Monitor
Hi, I turned my computer and monitor off as I normally do last night and when I came downstairs this morning to turn my computer and monitor on, my monitor didn't turn on. I pressed the power button on...
You need your monitor repaired or replaced.
Unlike a computer, there is not much troubleshooting beyond making sure it is plugged into a live outlet and turned on which you did already.
Jul 19, 2011 | LG L194WT 19" LCD Monitor
LG Flatron L194WT Monitor. When I plug it in it immediately flashes its LED for a split second and then fails to do anything else. If I try to unplug it and then plug it back in again it often doesn't...
Yes, you may have unstable DC due to bad DC filter caps, that will be the first place to look.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed LG monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Mar 30, 2011 | LG L194WT 19" LCD Monitor
HOW TO CHECK A LG FLATRON L194WT-SF MONITOR FUSE, THE REAL PROBLEM IS HOW TO REMOVE THE BACK COVER
Here are the service manuals: http://elektrotanya.com/?q=showresult&megnev=LG&megnev2=L194W&kategoria=monitor&kat2=all
After removing all the screws and the base, I use thin flat blade screw driver to crack open the case starting at the bottom egde and work your way around, just watch out for any cables attached to the front bezel. The monitor is not made to be easily open up.
Please read my guide so you will know what to look for inside the monitor.
Mar 15, 2011 | LG FLATRON L1919S-SF 19 inch LCD Monitor
I just got my LG L194WT-SF with an older computer and dont know what hapin, but it dont turn on i have try'd difrent power cords but still no power ive seen outher people with same problem but no awsners..
Hi There,
It's used LCD Monitor, right? You can read my Tips about this kind of issue, just click here.
Let me know if there is not clear enough.
regards,
dm
Dec 16, 2010 | LG L194WT 19" LCD Monitor
How to open a 17" LG L194WT LCD monitor
Here are the service manuals: http://elektrotanya.com/?q=showresult&megnev=LG&megnev2=L194WT%20&kategoria=&kat2=all
I usually open it at the bottom edge first and work it all the way around using thin flat blade screw driver.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Sep 17, 2010 | LG L194WT 19" LCD Monitor
LG Flatron L194WT Monitor no power
It can be as simple $5 worth of caps in the power supply.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed LG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://s807.photobucket.com/albums/yy352/budm/LG%20L1751S/
http://www.badcaps.net
May 27, 2010 | LG Flatron L1750S 17" LCD Monitor
L194Wt doesn't turn on when connected to power, no power light-nothing. This monitor connects directly, no transformer in the power cord.
You need to open it up and inspect the AC main fuse, capacitors (with bulging top/seal), burtn parts, etc. see example of failed monitors due to bad caps, lamps, transformers, etc: http://s807.photobucket.com/home/budm/allalbums
Post back as to what you see inside so we can guide you further.
Mar 20, 2010 | LG 22" FLATRON LCD Monitor
Power lite started blinking, i unplugged and waited a bit and plugged back in. Now no lite at all, nothing. Is it dead?
check the cable or replace it if you do that and start blinking clean the memory module by pencil eraser
Jan 02, 2010 | LG L194WT 19" LCD Monitor
Gateway FPD2275W LCD Monitor Logo
512 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
