Question about Endless Summer 1501 Patio Heater
How is the propane fitted to the heater - Endless Summer 1501 Patio Heater
  • 1,711 Answers
In the heater base should find the gas hose with the gas valve on the end. Plug on the valve on the propane bottle and turn it on.
Posted on Nov 06, 2010
Reddy heater 75 125000 propane heater. Fan comes on, have spark, smell propane and still won't fire
There are couple possible reasons your unit refuses to fire; some units tjis big have to be level, this is a saftey feature bulit in if it is not level, it will not fire, ( it believes it has been tipped over), the smell of propane could also mean it has a leak on your line connection ( bad fitting, not sealed properly), finally check the temperature sensor may be bad and need replacing......
Jan 21, 2017 | Reddy Heating & Cooling
Can a natural gas sterlinge heater be changed over to propane
yes but you just have to change the ventura which is only a fitting to either make the intake smaller or bigger , I forget which but it is an easy fix , good luck
Dec 10, 2014 | Heating & Cooling
After running for a few minutes, my bottle top heaters start flaring and burning irregularly. The same thing happen when I hooked it up to another heater. Also when I turn the gas off it takes a lot of...
Are the propane tanks fitted with a pressure regulator?
The propane gas regulator is one of the most important parts of a propane gas system (or a compressed natural gas system as well).
The purpose of the regulator is to control the flow of gas and lower the pressure from the tank to the appliance(s) in the gas system.
The regulator not only acts as a control regarding the flow and distribution of propane (or CNS) but also as a safety barrier between the high pressure of the tank and the end use appliance(s).
Without it, you can cause serious damage to the appliance's gas valve and create a disaster- fire or explosion.
Nov 30, 2013 | Mr. Heater Model MH12TS - Single Tank-top...
Can a Pentair minimax NT that is fitted for natural gas be retrofitted for Propane use
Probally the easyest convertion on the market. Where your gas line comes in the heater the line loops up over and down. There are two unions on this at the base of the loop. take these apart and their is a washer in one and you replace it with the Propane washer and put back together.
Sep 01, 2010 | Pentair Minimax NT Heater
What kind of propane cylinder do I need for a table top heater
u use the same tank that fits a b.b.q. a 30 lb it fits in the bottom
Feb 01, 2010 | RTO Bernzomatic Brushed Nickel Patio...
I have a dyna pro propane heater model rmc-fa100dep,will not stay lit. I took it apart. I think I need a new thermocupler. Any idea where I can get one?
YOU SOUND LIKE YOUR ON THE RIGHT TRACK,, I USE GENERIC ONES THAT FIT IN WATER HEATERS OR FURNACES THE SALE THEM AT THE HARD WARE STORE FOR AROUND $10.00 USE YOUR IMAGINATION TO MAKE IT FIT, PRETTY EASY, GOOD LUCK LEAVE FEED BACK THANKS
Jan 17, 2010 | Desa International ALL-PRO® SPC-85 Utility...
How to change gas orfice to propane glass smokes up. soot
Is this unit originally set up for natural gas? If so, the burner oriface and the gas valve need to be retro-fitted to propane. This is something only a qualified service technician should attempt as an incorrect retro-fit could cause an explosion resulting in someone getting hurt or even killed.
Nov 09, 2009 | Empire Hight Efficient Direct Vent Wall...
Dyna glo ventless rmc50 ngt
All gas heaters can be converted from one type of gas to another, be it natural or propane. The problem is getting the orifice retrofit parts that fit that particular brand. If the manufacturer doesn't make them, then you are left with no choice.
Mar 12, 2008 | Heating & Cooling
Endless Summer 1501 Patio Heater Logo
67 people viewed this question
Top Endless Summer Heating & Cooling Experts
Paul Carew
Craig Butler
Craig Butler
Are you an Endless Summer Heating and Cooling Expert? Answer questions, earn points and help others
