Question about Fujitsu MHV2040AH (HDF40000IAH) 40 GB Hard Drive
Fujitsu MHV2040AH 40 GB hdd locked by an unknown password. how i can get it back
2 Suggested Answers
  • 699 Answers
SOURCE: i want to upgrade my Fujitsu MHV2040AH 40 GB Hard
Your Fujitsu MHV2040AH is an IDE 2.5" 5400 rpm 40 GB hard drive.
Most Notebooks nowadays will use 2.5" SATA hard drive which is not compatible with IDE.
New IDE are getting harder to find and are therefore in general more expensive to buy than the equivalent SATA
You should be able to update the drive with most 2.5" HDD with either 5400rpm or 7200rpm (faster) with an IDE interface. Common 2.5 IDE capacity would be 120Gb and 250Gb (320GB and 500GB are also available but could be a bit expensive). The important factors are physical size to fit in your notebook/casing and IDE interface. The BIOS support for larger drive can also be a factor but as a rule, worst case situation, a larger capacity drive can always be used at a lower capacity
Hope it helps.
Posted on Dec 15, 2010
Testimonial: "this confirms my research. thank you. "
I want to upgrade my Fujitsu MHV2040AH 40 GB Hard Drive what is the biggest/fastes one i can replace with? i though i found another one but it doesnt have the right connectors. the fujitsu/toshiba site...
Hope it helps.
Dec 15, 2010 | Fujitsu MHV2040AH (HDF40000IAH) 40 GB Hard...
How much is the cost mhv2040ah 40 gb hard drive please mi mail is ppcosio@yahoo.com.mx
Hi
This Neo , it would cost you $40 in Ebay . or
ALLHDD.com the number 718-766-5269 .
the cost is $54 . Check it .
or
Check it in amazon there is 8 stores where you can get it.
Nov 02, 2010 | Fujitsu MHV2040AH (HDF40000IAH) 40 GB Hard...
Password protected harddrive ,how to delete it?
remove the hdd and use external hdd usb device to format in another system
Oct 03, 2010 | Fujitsu MHV2040AH (HDF40000IAH) 40 GB Hard...
My 10 gb fujitsu hard disc is not detected by ide and usb port
Hello, If this is an external drive and your using Windows plug the drive in and open Control Panel, then open administrative tools,next, open computer management then on the left side under storage open disk management. Your drives should show up here identified as letters, C: - D; etc. If your new drive shows up here click it or right click it to see if it needs to be initialized,if it does do so. Go back to My Computer and see if it shows up there.
Dec 12, 2009 | Fujitsu MHV2040AH (HDF40000IAH) 40 GB Hard...
There appears to be an adapter that connects the drive to my Dell Inspiron 6000 laptop. The actual pins are not exposed. Is this in fact an adapter?
Some Laptops 'safe' connection adapters for their hard drives.
The small pins on these hd's are easy to bend and can render one useless.
It could also be a harddrive tray.
Dec 07, 2009 | Fujitsu MHV2040AH (HDF40000IAH) 40 GB Hard...
I dropped my laptop, recovered the hard drive and purchased an identical replacement laptop. When I power up with the old HD I can hear a click-click-click and the laptop doesn't recognize the presence of...
The HDD is damaged.
No, it is not possible to transfer the disc to another HD case. First, HDDs are assembled in clean rooms because minute specs of dust can ruin the disc; Second, the disc has addresses on it that correspond to the firmware on the drive
Nov 06, 2009 | Fujitsu MHV2040AH (HDF40000IAH) 40 GB Hard...
Finding ata_piix
If you don´t find it on the Fujitsu homepage, ask manualfox, the are specialists in finding software drivers.
May 29, 2009 | Fujitsu MHV2040AH (HDF40000IAH) 40 GB Hard...
How to unlock or to replace the board
Maksiza, I had a customer who would had their harddrive locked. It was a DELL machine, using a travelstar drive, we called DELL verified they were the owners and they gave the master hard drive password to the hard drive and it worked beautifully. Call Samsung with the machine serial number/tag number/asset number whatever and they should have it if not try fujitsu. http://www.samsung.com/products/notebook/index.htm# http://www.fujitsu.com/us/services/computing/storage/hdd/contact/index.html The Fujitsu site looks better. Good Luck, Tim p.s. Of course we called DELL after 10 hours of searching.
Feb 09, 2007 | Samsung Spinpoint MP0402H 40 GB Hard Drive
Fujitsu MHV2040AH (HDF40000IAH) 40 GB Hard Drive Logo
222 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
