Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
My garage door opener does not shut when i use one of the remotes. the only way it will shut is when I push the wall button and hold it untill the door ia all the way down. whats the solution?
    President:
  • 3,197 Answers
Check the door sensors. They must be pointed at one another and the small light on each one must be lit and not flickering. Tweak them a bit. If you cannot get both lights to come on you have a bad sensor.
Posted on Nov 05, 2010
The garage door will open with the remote but will not shut with the remote and the light blinks you can shut the door by holding the button on the wall until it completely closes. This is a 3 door garage...
If the main light flashes 10 times when the door reverses it is a door sensor problem. Make sure the sensors are pointed at one another and the small light on each sensor is lit and not flickering. If you cannot get both lights on you have bad sensors.
Jul 16, 2010 | Sears Craftsman LiftMaster Chamberlain...
The garage door will only go down if I hold the button attached to the wall down until the door is completely closed. It will not go down with the remote control in the car . This started last week. Also I...
HOLDING DOWN THE WALL BUTTON OVERRIDES THE SAFETY EYES.
WHEN HOLDING IT DOWN MAKES THE DOOR CLOSE PROPERLY THE PROBLEM IS IN THE SAFETY EYES.
ARE BOTH LEDS ON? - CHECK FOR A LOOSE OR BROKEN WIRE.
ARE THE EYES WIRED CORRECTLY?
ARE THEY AIMED AT EACH OTHER?
Jul 15, 2010 | Sears Craftsman LiftMaster Chamberlain...
My craftsman 1/2 hp garage dood does not close when it's cold out (with either a push on the remote or a single push from the wall). I have to hold the wall button in until it's completely down. When I do...
Make sure the brackets for the sensors are tight and the small light on the sensors is not blinking ever so slightly. You also might try shading the sensor so that the sun is not shining directly into the lens.
May 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: My craftsman 1/2 hp garage dood does not close whe...
If the main light flashes 10 times when you try to close the door it is a sensor problem. Make sure they are not flickering ever so slightly and that they are not loose on their brackets. Tweak them a little bit.
May 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have 2 liftmaster 3245. The hand held remotes were working fine then stopped. I replaced the batteries and turned of all electrical/RIF close by. Still not working. Both cars operate the doors with no...
You need to reprogram the remotes by briefly pushing the learn button on the garage door opener until it flashes once, then release the button on the garage door opener.
Now press the remote button once until you hear the garage door opener click, now press the remote button once again and the remote should be programmed to work for that garage door opener.
DO NOT press and hold the garage door opener learn button for more than 10 seconds or you'll erase all programs and have to relearn all the remotes, including your car ones.
Hope you found this very helpful and best regards.
Aug 06, 2009 | liftmaster Chamberlain Garage Door Opener...
Garage door wont work with remote
If the small light in your wall control is blinking it is in the lock mode. Press and hold for 3 seconds the button with the icon of a lock. This will toggle the lock function off.
Aug 04, 2009 | Sears Craftsman LiftMaster Chamberlain...
My Craftsman 139.53879 remote won't learn the code of my 1/2 HP craftsman receiver type 132C2105-3B. I followed the directions to push the transmitter button and hold the receiver button down until the...
I have no idea what a 132C2105-3B is but try this. Hold the button down on the remote and then press and immediately release the smart/learn button. If the remote is the correct one for your opener it should work.
Jun 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opening/closing problem
Could be a bad wall button or a smashed wire.
Anytime a door opens and/or closes by itself, or remotes work intermitantly I look for a smashed wire between the motor unit and the wall button or a bad wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation and activate the door or interfere with the remote.
Loosen the staples with a small screwdriver and slide the wire about ½ inch to move any areas of thin insulation away from the staples.
The second thing would be a bad wall button or a remote with a sticking button.
Or a remote in someone’s purse that gets the button pushed by other stuff in the purse.
The test is to disconnect the push button wires at the power unit. If the self operation / interference stops you have located the problem. If you reconnect the wires and disconnect the wire at the wall button this will tell you if the problem is the wire or the button.
HOPE THIS HELPS
Jan 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberplain Garage Door Opener problem
IF U HAVE TWO EYE,SENSORS ON EACH SIDE OF THE DOOR SEE IF SOMETHING IS BLOCKING THE EYES OR SOETHING IS COVERING THEM, OR THEY ARE OUT OF ALIGNMENT, ONE SHOULD SHOW GREEN, AND ONE RED EYE, GOOD LOCK
Jan 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears craftsman garage door opener
Jul 13, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
22 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
