Question about Miller 228926 PLASMA CUTTER IN-LINE AIR FILTER KIT
The Miller inline filter restricts the air flow to my TD 102 cutter. I was told the machine needs at least 7.5scfm. What is the Miller in line rated at?
3 Suggested Answers
  • 225 Answers
SOURCE: Plasma cutter no cutting
the tech is probably pretty close to the cost of board,but you may have moisture in air that still wont take out the p.c..you have a warrenty on the unit,go to your local welding store and request a new one if refussed tell them you want to talk to the miller salesman which they should have no problem to set up.if not call miller direct in appleton wisc.they are good people.
Posted on Apr 11, 2010
  • 5 Answers
SOURCE: miller plasma cutter spectrum 625
make sure your air pressure is high enough and volume does not drop below minimum.
Posted on Nov 27, 2011
Miller Plasma not cutting properly keeps ruining tips
It may be an air pressure problem. Plasma cutters require a constant flow of air at a certain pressure to work properly. If the compressor can't keep up and the pressure drops it can create problems. Have someone watch the pressure gauge while you're cutting to see if the pressure remains steady. You may need to adjust the compressor pressure switch or you may need a larger compressor.
Hope this helps.
Bob
Mar 27, 2015 | AO Smith Miller / LSI / Home / Nordyne...
Miller 375 x-treme fires about 30 seconds then stops it doesn't stay running, no trouble lights...
Have you watched to see if the pressure light comes on right before shutdown? If so you may need to add a tank right next to the torch base to address the pressure drop assuming your air source is able to deliver adequate volume to the cutter continuously and you currently have more than 25 feet of hose between cutter and compressor. It might not hurt to check the internal filter as well.
Dec 29, 2011 | Miller Spectrum 375 X Treme Plasma Cutter...
Miller plasma cutter spectrum 625
Nov 27, 2011 | Miller SPECTRUM 625 SPECTRUM PLASMA CUTTER...
I have a Miller Spectrum 625. The problem I am having is that after cutting for three seconds the torch quits cutting. Have had it looked at a Miller repair center. They said they cut with it for over...
Hi:
I found similar problem with few customers and one issue (should I said the standard issue) is the source of air. You need a steady pressure and flow of air into the machine. Check your air compressor you will need at least 6 cubic feet per minute (360 cubic feet per hour) and a 90 psi of pressure. Since there is no way to check the flow (unless you have an online flow meter at you air pipe) check the pressure at your air tank (reservoir), if the pressure drops below the 70 PSI then that's the problem; your compressor can't stand the flow. Other than that check your ground clamp and make sure it's making a good contact.
Good Luck.
Sep 15, 2011 | Miller SPECTRUM 625 SPECTRUM PLASMA CUTTER...
Miller plasma cutter not cutting
Hi:
Miller plasma are pretty realiable. Without more details; what you need to do is check the contact tip and the electrode if these ones are won, replace them. If still doesn't work; check your air pressure; main source must give you at leats 90 psi and 9 SCFM of flow,
Good Luck
Mar 12, 2011 | Miller Welding Tools
Spectrum 2050 plasma cutter . Cutter blows air and stops when trigger is pulled no pilot arc or any cutting when trig is released air flows again and stop after 10 sec new tips was working the day...
Check compressed air pressure is in limits otherwise unit will cut out. Try adjusting the pressure up. also make sure the supply pressure is correct as it may not be your plasma cutter at fault.
Jul 30, 2010 | Miller 903777012 SPECTRUM 2050 PLASMA...
Apr 07, 2010 | Miller Spectrum 375 X Treme Plasma Cutter...
I am looking to purchacs a slightly used miller plazma spectrum 375 from a private owner is there any common problems related to this unit that I should look for?
The main thing that can hurt these things is water. If he didn't have a water filter on the line before it enters the plasma it could destroy the unit. If you buy it try it out to see if everything works. When you install it be sure to buy a filter that they sell for these and put it on before the air enters the plasma. Around $400. to $600 to replace the parts when water meets with the components. The filter that Norco Welding supplies sells for these is a toilet paper filter and you need to check it often.
Jul 29, 2009 | Miller SPECTRUM 375 PLASMA CUTTER 903891...
Miller 2050 that will not spark.
This is relative to 3 causes , contol board , pwm board or torch
Feb 28, 2009 | Miller 903777012 SPECTRUM 2050 PLASMA...
Miller 3080 plasma ,won't fire
check groun dconnection on workpiece and where connected to machine>> check reset switch.>
There is a screw in fuse on the back make shure you unplug the machine befor removing any fuse or working on any electrical problem.>>OUCH!
Jan 14, 2009 | Miller 903777012 SPECTRUM 2050 PLASMA...
Miller 228926 PLASMA CUTTER IN-LINE AIR FILTER KIT Logo
Top Miller Welding Tools Experts
Kory Ronning
hubiam
hubiam
Level 1 Expert
John Trevino
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
