Question about BenQ SP831 Projector
My church has a BENQ sp831 digital projector. When you power on, it acts like it is going to start up ( bulb comes on and projects BENQ image ) but then suddenly fans kick on and it shuts down. Will not stay on more than 60 to 90 seconds. Bulb doesn't have more than 150 hours on it. It sounds like more than one fan kicks on or that it ramps up rapidly. Please help. Thanks
5 Suggested Answers
Gigatech
  • 259 Answers
SOURCE: Christie DS+60 projector turns off spontaneously
Here is a list of error codes for your unit:
12 Software bug. Contact dealer/factory.
13 Flash memory corrupted. Download new software.
14 Engineering only programming is complete. Call Christie, replace TIPM.
15 Attempting to download code without being in boot mode
16 Invalid interrupt. Power off/on. If it persists, contact dealer/factory.
17 Forced boot mode. Keys held down too long.
18 Attempting to program boot mode without jumper
LAMP FAILURES
21 Lamp compartment too hot
25 Lamp 1 not installed
26 Lamp 1 Interlock: door open, lamp not installed
27 Unable to turn lamp 1 ON
28 Lamp 1 shut off unexpectedly
29 Lamp 1 driver overheated
2A Lamp 1 driver operation error (e.g. too hot can’t start)
2C Lamp 1 driver UART communications failure
30 Lamp 2 not installed
31 Lamp 2 door open
32 Unable to turn lamp 2 ON (unknown reason)
33 Lamp 2 shut off unexpectedly
34 Lamp 2 driver overheated
35 Lamp 2 driver reports operation error (e.g. too hot can’t start)
36 Lamp 2 driver UART communications failure
37 Lamp Watchdog Tripped – Unless lamps turn on again after 3 minutes, assume software hung.
Posted on Feb 26, 2009
  • 3 Answers
SOURCE: BenQ PB8220 DLP projector - lamp button continues to flash after bulb replacement
Hello!
After 2 years I finnaly solved the problem. There was a flaw in the lamp´s temperature circuit. A technician disassambled my BENQ PB8253 unit and fixed the problem. Charged me US$ 75.00. I´m in Brazil.
Hope this can help.
Posted on Sep 14, 2009
heathgr
  • 442 Answers
SOURCE: my projector won't project anything.
Disconnect all inputs to the BENQ and power on. Do the lights come on as per normal operation. Does the lamp come on when the power button is pressed. Does anything show when the menu is selected.
Posted on Aug 20, 2011
SOURCE: BENQ w10000 makes noise and
hi sir, whether you cecked the color wheel? because once the color wheel motor with issue, make noize too.
Posted on Oct 04, 2012
Suddenly, benq mx511 has white pixels showing up....multiplying every day...now the projected image consists of 50% snow.
It probably has the same DLP chip as my Mitsubishi television. The mirrors in the chip set get stuck and create the white spots. There is no way to fix this other than replacing the DLP chip.
Feb 04, 2013 | BenQ MX511 3D Projector
To whom it may concern I am writing this letter on behalf of the Elim Seventh Day Adventist Church, George, South Africa. We have the BENQ MP610 Digital Projector. We are running a series of...
You have to contact BENQ with the required code numbers to get an unlock code. No one else can issue an unlock code.
Contact BENQ in your local country by going to their web pages.
Nov 19, 2010 | BenQ MP610 Multimedia Projector
The screen image has a series of vertical lines that appear then disappear at irregular times
Normally this is loose connection of main board with the DMD assembly.
Need to remove main board and Refit.
Samir
Oct 13, 2010 | BenQ SP831 Projector
Bluish image appearing on screens
It sounds like the projection lamp is beginning to show its age. How many hours of use does the unit have on the bulb? The bulb are typically rated for about 800-1600 hours of use before they go bad. The bluish image on the screen image is a typical tell-tale sign that the bulb is going to need replacing.
Most of your better projection units will have an internal time counter of the bulb life from the time the unit is first used or when a bulb is replaced. Check to see if your unit has this feature, if so it will show you on the screen display what is the total number of hours on the bulb and the estimated remaining hours of life.
Be aware that the replacement bulbs are NOT cheap and usually will cost you several hundred dollars, I have seen bulbs for professional projection units used for large convention/presentations have bulbs costing as much as $500.00 USD.
One other last thing to check is to clean the lens of the unit both inside and outside. To clean the inside, you will need to remove the bulb (be sure to wear a rubber glove as the oils from your skin will cause the lamp to blow, (causes a hot spot)). Then using a cleaning wipe, just as one used for cleaning microscopes or glasses, wipe the lenses. The discoloration might also being caused by dirt and oils on the lenses.
I hope this shed some light on your church's projection problem.
Sep 19, 2009 | Panasonic Office Equipment & Supplies
I have an Mitsubishi X490U Multimedia Projector - it hangs inverted in our church auditorium. The image on the screen looks okay with bright images projected, but dark images appear to look green...
This unit needs a new Optical block, most likely more than a new projector
check out projectorsuperstore.com for a replacement
by the way, your $10,000 projector only has 2600 lumens, a new/refurbished unit will have 4000 lumens for less than 25% of the cost of your unit
Jul 11, 2009 | Mitsubishi X490U Multimedia Projector
Sharp XGE3500 Projector won't stay turmed on
the power supply is starting to go. the caps are drying up. if there is a large drain of power (like striking the lamp), it'll shut down.
Mar 02, 2009 | Sharp CLMPF0046DE10 Projector Lamp for...
I have a second- hand dell 3100MP projector which I use during church services to project songs and other material. Recently it has been showing a predominalty green image , particularly when showing...
sir
the lamp is not at problem, but the dlp engine is at fault, u may have to replace it.since u bought it 2nd hand,it is not worth changing the same as it will cost u more than ur buying price.when u plan to buy ur next projector, make sure u buy a new one as it will come with a fresh lamp & manufaturers warranty on the unit & at 4000 / 5000 hours of projector usage is guaranteed!
Jan 05, 2009 | Dell 3100MP Multimedia Projector
Benq mp6100
If this problem happen with a particular laptop then I suggest that you you change the setting of the laptop you are using. Go to Start=>Control Panel=>Performance and Maintenance=>Power OPtion=>Power Option Propreties=(click on Hibernation Tab and uncheck Hibernation box).
While on the Power Option check the time on the SYSTEM HIBERNATION.
Good luck
Dec 25, 2007 | BenQ MP610 Multimedia Projector
CRACKED
The Stress of impact on the imaging forming unit that is directly behind the projection lens has a flat glass surface. If it is cracked the stress cracks would project with any image because they are on the same plane as the image
Nov 22, 2007 | BenQ MP610 Multimedia Projector
BenQ SP831 Projector Logo
139 people viewed this question
Top BenQ Office Equipment & Supplies Experts
Tom Chichester
Marvin
Marvin
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
