Question about Sony ICF-CDK50 Clock Radio
Hi i am trying to find the output voltage of the mains transforma ? 120v in whats the output
  • 10,594 Answers
Mains transformer output volts are 12V AC for Sony ICF-CDK50
Circuit location is T901 and part number is 143591722 .... TRANSFORMER, POWER (US, CND)
Hope these info will help you.
Thanks.
Posted on Nov 05, 2010
Testimonial: "excelent service "
  • peterson290 Nov 06, 2010
    Thanks for the help, I was asked to have a look at it for a firend, he bought it back for the USA to the UK and pluged it in, and blew the transformer, I have replaced the transformer with a 240v with a 12v output and it working again
    Thanks again
    Clive
Hi!
I have the same problem like you had, do you remeber were you find the new 240 transformer that you replace the broken one with?
Posted on Aug 21, 2012
I HAVE AN AC ADAPTOR,… CLASS 2 TRANFORMER FOR OUTDOOR USE THAT NEEDS TO BE REPLACED.. MODEL: KMUA - 240 - 05000- 66UL INPUT: 120V - 60Hz 570mA OUTUT: 24V - 50VA
Amazon has it.
AC Power Adapter 120V input 24V 50W (50VA) output, UL listed
www.amazon.com › ... › AC Adapters
Mobile-friendly - AC 24V Power Adapter; 50W Output (50VA); 120V AC Input; UL Listed; Ivory Color item in OEM box ... 24V20AC 24V AC 20VA Transformer Input: AC 110V / 120V 60Hz Output: AC 24V 880mA
Dec 09, 2015 | Computers & Internet
Onida tv CO21BLKTAG
Check all the components at the main power regulator section. The voltage output from it should not raise more than 109VDC.
Sep 09, 2013 | Televison & Video
I recently bought a U.S. version Nakamichi 600 II cassette console (120V), and I accidently burnt its transformer out by a 220V mains supply. Now I need to replace this burnt out transformer better with a...
To match it with an other transformer, you have to know about its secondary voltages. Try to download its service manual by internet. It will have all details. It will be best to contact any expereienced service technician or to the authorized service center for Nakamichi.
Feb 24, 2013 | Televison & Video
What is the output voltage of the transformer in the system, mine is burnt so i need to change the transformer so i need to know the output voltage
Nominal Output Power (Total) -- 2.3 Watt
On the back of the right speaker where the power cable is connected there is a sticker where you can see the voltage the speakers are using. You should read there 120 V - 60 Hz 100mA.
You will have to use a voltage adapter from 120v to 220v. (found in electronic shops) that maintains the Voltage stability.
Regards,
Tariq Khan
Jan 15, 2013 | Logitech Speakers. S-120
Hi, i have a dream machine sony ICF-c218 by mistak connected to 220v the original transformer is 120V & i also would like know the output voltage of this transformer so that i can change it 220V p
My self sushil from india pl.find the details
yellow-blue is 3.2 VAC
red-white is 4.2 VAC.
Clock is well functioning without frequencies difference error. I think the clock is using crystal for pulses generator instead of AC power supply frequency.
May 22, 2012 | Sony Audio Players & Recorders
No power even if I plug my DVD to power source
Good day.
Follow this procedure for trouble shooting.
  1. Remove the cover of your DVD player.Loosening all screw.
  2. Check the input voltage of the power supply 220v/120v AC.If don't have input supply that comes from the ac cord,replace it.
  3. If you have a input voltage supply comes from the power cord.Check the output voltage of the power supply such as 5vdc and 12vdc.
  4. If the you don't have output voltage from the power supply.Check the fuse if busted,check open/change value of capacitor,check power transistor (regulator)if shorted and leak/bulging top capacitor of the power supply board.If you found any defective parts replace it.
  5. If you have output voltage comes from the power supply.The problem could be the main board,replace it.
  6. If you already done this procedure,test it by power ON the DVD player.
I hope this information will be helpful.Thank you and good luck.
Apr 17, 2011 | LG Televison & Video
Hi, I bought a 1500va APC UPS. Its not charging when connected to the mains power supply. It still beeps and stays on battery. I have set up the transfer voltage and sensitivity adjustment to no avail....
Hi, I am a licensed Master Electrician with 27 years exp.
Need more info. Did it work before? Are you positive your incoming voltage is correct? I will assume all of them things as yes and see what I can think of to fix ya up.
I would connect it to a load and let the batteries totally deplete, like a small drill or something that pulls close to the 12.5vac (1500va). Disconnect the load and unplug it for a minute, then plug it back in and then see if it charges. If it does, leave it alone til it completes charging then put a load on it. It shouldnt charge with a load on it if the battery is already fully charged. Then unplug it from the wall receptacle (main power) and see if it transfers and the batteries take over. If it does it should not charge again. A UPC should only charge when your load is being supplied by the main power, i.e., the UPS is plugged in and not transferred to the battery state.
I hope I have helped with what info I had, if not then get back with me, their are other issues, like internal fusing on the main power supply coming in as well as battery charger internal fusing. NOTE: If you ever replace an internal fuse on a UPS be absolutely sure, without a doubt that it is of the same type as in voltage, ac or dc, and most importantly the amp rating. BTW in case you didn't know, to get the amp rating of something rated in VA, as in 1500va, you divide 1500 (the va) by 120v. (supply voltage) that is assuming it is 120v. if any other voltage just adjust your divisor to match the voltage. 1500va/120v = 12.5 amps. Good luck!
Nov 06, 2009 | APC Back-UPS® ES UPS System
NPS-200PB-73M
SPECIFICATIONS:
Dimensions 5.9"W (150mm) x 3.4"H (86mm) x 5.5"D (140mm)
Special Features Dell Proprietary Main ATX & 6 Pin Auxiliary Connectors
AC Input 100-120V/7A 60Hz 200-240V/3.5A 50Hz
DC Output Voltage 3.3V 5V12V
Total Output Max Load 200W
Regards.
Jul 20, 2009 | Dell - NPS-200PB-73M (NPS200PB73M) Power...
I have a smartlink ESK-108 with no power supply can you tell me what voltage is required thanks?
AC/DC power adapter transformer
AD-051A 120v 13W input AC, 5v 1A output
or
JOD-41U-27 120v 100mA input AC, 5v 1A output
I have the latter and it works.
Apr 12, 2009 | Archtek America ESK-108 8x10/100 Mbps...
Goldstar tv
leak of voltage going to mainboard, the 120v suddenly decrease after a whiloe to zero you mean short circuit. it is not power supply problem as you say that it drops to zero after connecting main board. it clearly indicates that problem in horizontal output section.
Sep 19, 2007 | Sony FD Trinitron WEGA KV-32FS16 32" TV
Sony ICF-CDK50 Clock Radio Logo
499 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
