Question about Nokia N95 Cellular Phone
Back light on my nokia N95 doesn't work even after replacing the screen
  • 203 Answers
Kindly go to near by nokia store,....and solve the problem
Posted on Nov 05, 2010
My nokia n95, screen just lights up & makes noise. u can call & recieve calls but nothing on screen except white back ground???I down loaded new face book has been updated & loaded google....
Hi you will need to replace the flex cable running from your main board to the screen, if this does not work then it is a Software issue and will need to be flashed with latest firmware, good luck
Aug 22, 2011 | Nokia N95 Smartphone
N95 slider problem . LCD goes blank on sliding . it appears that there is problem in Strip. do u get separate strip or it comes alongwith slider....
No the Slider strip doesn't come separately because the strip is merged permanently to a circuit that has your earpiece ,light sensor,and front camera you cannot seperate it in any manner because the only unlockable part over there is the LCD screen .i would recommend you to get your phone serviced from nokia care only because the strip is the most important part in a slider .. even if you get a local strip installed from a local mobile repair center it wont last for a month ..even i had the same problem 4 months back ..because quality of the strip matters .......
Dec 28, 2010 | Nokia N95 Cellular Phone
Hi, I have 2 year old N95.Had black screen problem. Changed to a new display. Still it is not working. All other light back works but no flash light.
Problem may be with the display strip which connects the screen and the board, replace the strip and try.
Regards, Kesav
Mar 04, 2010 | Nokia N95 Cellular Phone
N95 Nokia Screen light
goto light setting and enable ur back light
Aug 18, 2009 | Nokia N95 Cellular Phone
No display, Phone boots without video and with limited functions
You can try a software update by downloading the Nokia Software Updater from the Nokia web site. Do this even if it is the same SW version.
*******MAKE SURE YOU BACK UP YOUR DATA 1ST ON PC SUITE*********
If this does'nt work then it is a mechanical problem. Will need to go into a service cnter to get repaired, Should be covered by the warranty, taking it back to the place of purchase
Feb 06, 2009 | Nokia N95 Cellular Phone
Can't see a thing on screen
hi sir
please remove the battery and memory card.. and after inserting the battery first for saffer side go to tools>settings>phone> restore factory setting . after restart insert memory card it work,s sir..
if doesn.t work mite memory card may be corrupted..
Sep 01, 2008 | Nokia N95 Cellular Phone
Back Light
First, check that the something is actually displayed :
Turn off the phone then put it on charge.
Check to see if the NOKIA logo appears even if the display is unlit. (try angling the display towards a sunlit window).
Having charged it, try to turn it on.. Do you detect the vibration the phone makes when starting up?
If nothing is displayed but you get that vibration I suspect that the display is somehow damaged and you'll need to look at replacement.
You local nokia centre should be able to provide you with a quote for the repairwork otherwise if you're confident opening it you might be able to replace the screen with one obtained from here for example:
http://www.accessorylink.co.uk/search.asp?Action=search&Keywords=N95
Aug 26, 2008 | Nokia N95 Cellular Phone
Nokia N95 Lcd Screen
there are several repair shops out there who give a free quote.......I bought a replacement off ebay and it was dud....go to the experts!
Aug 21, 2008 | Nokia N95 Cellular Phone
Nokia n95 screen problems
Try a hard reset on the device. Pull the battery out whle the device is on. Then put back in.
If that doesn;t work, try reloading the OS.
Jun 02, 2008 | Nokia N95 Cellular Phone
Nokia N95 Cellular Phone Logo
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
270rexton
270rexton
