Question about Bissell Lift-Off(R) Revolution(R) Turbo Upright Vacuum
Bissell 12 amp model 6850
The rotating silver peg that spins the belt on my model 6850 bissell 12 amp upright is not spinning. What can be causing it, and can I get in there to fix it?
  • Anonymous May 23, 2009
    i cannot even figure out how to put the belt on
    President:
  • 1,673 Answers
That would be the motor shaft, if it has power to it and is froze up, you will have to replace the motor.
Posted on Jun 17, 2008
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
Is the beater brush on the Bissell Helix NOT to spin on bare floor setting?
Hey Tony! The brush does continue to rotate when using the vacuum on the bare floor setting.
Feb 02, 2013 | Bissell Cleanview Helix Deluxe Bagless...
Bissell PowerForce Turbo: The motor spindle becomes very hot while spinning, causing the new belt to burn and break. Is this because the motor is overheating?
Something is preventing the brush roller from turning even though it seeems to be OK when not in contact with the floor. The motor shaft is spinning on one spot of the belt, causing the heating, the smell, and eventual belt failure. I have had brush rollers that appeared OK but proved to have pet hair jammed between the end caps and the roller itself causing rotation to be very difficult
Jan 14, 2013 | Bissell 6594 PowerForce Bagless Upright...
Brush roller not spinning. belt, spindle okay. roller taken out and cleaned, no thread. replaced but no dice. ???
Use only BISSELL Style 10 Replacement Belts (#32074) in your BISSELL PowerForce Bagless.
  1. Unplug cleaner from electrical outlet.
  2. With Rotating Floor Brush removed from vacuum cleaner, grasp old Drive Belt and remove from Motor Pulley. Discard old Drive Belt.
  3. Place new Drive Belt over Motor Pulley and stretch other end over Rotating Floor Brush in the space between the bristles.
  4. Place ends of Rotating Floor Brush down into slots on sides as shown.
  5. Turn Rotating Floor Brush by hand several times in the direction of Motor Pulley. If properly installed, Drive Belt will center itself on Rotating Brush.
  6. Reposition Brush Cover and snap back into place. Check to be sure all three latches are secured.
  7. When you turn on the vacuum, do you see the motor that spins the belt spinning at the bottom? If not, it sounds like you may have a burned out motor.
If suggested solutions do not correct the problem, call:
BISSELL Consumer Services 1-800-237-7691
Monday - Friday 8 a.m. - 10 p.m. ET
Saturday 9 a.m. - 8 p.m. ET
Jun 01, 2011 | Bissell 6594 PowerForce Bagless Upright...
The bar that the belt sits on wont spin and smells like its burning when you turn it on. Is the motor out?
No, it is not the motor, it is a bad belt or something is jammed causing the belt to slip...
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Sep 26, 2010 | Bissell 1699 ProHeat Clear View Upright...
The brush won't spin - but the silver stem it on is spinning
The belt may look fine but it is stretched. The silver stem is the motor shaft. Replace the belt with a genuine one by model #. It will be 20-30% smaller. Check that your brush roll turns freely by hand. Pop the nylon caps off the end to remove hair and thread.
Aug 10, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Bissell carpet cleaner brushes won't turn
Make sure you have released the handle, as if you wanted to push the machine forward. If the handle is locked upright, the brushes do not spin.
If they still don't spin, you may have a broken belt. Look carefully at the base, on each side. As I face the front of mine, on the right side of the machine, a small belt goes around one brush and a small cog wheel. On the left side, a larger belt goes around both brushes. If either belt is broken, the brushes will not spin. This can happen if you let gunk build up inside the clear plastic side pieces or around or above the brushes. It's very important to constantly be cleaning your Bissell. The belts can be ordered online and replaced. See your owner's manual.
Sep 17, 2008 | Bissell Carpet Cleaner Powerbrush Deep...
Bissel Cleanview II (bagless 12 amp)
Greetings from GoVacuum.com,
What it sounds like is that your belt has either broken, or has been stretched to a point where the brushes won't spin. What you'll need to do is turn the vacuum cleaner upside down and turn on the vacuum. Are your brushes spinning at all? If your brushes are spinning, when you put the machine on the carpet, does the brush stop spinning, or slow down noticeably?
If either one of these happen, you'll need to replace the belt. Most Bissell uprights will use Bissell Style 7,9, and 10 belt (3 styles, 1 belt). The best way for you to find out what belt your machine takes, is to refer to your owners manual. You may also email me your model number, and I'd be happy to ship you the correct belt.
http://www.bissell.com/images/UserGuides/PT.pdf
The instructions on how to replace the belt are also diagrammed and explained at the above link.
There is also a troubleshooting page on page 14.
Please email me if you have any further questions, I'd be happy to answer any question you may come across.
GoVacuum.com
chris.jones@govacuum.com
Aug 19, 2008 | Bissell 6594 PowerForce Bagless Upright...
Bissell Lift-Off(R) Revolution(R) Turbo Upright Vacuum Logo
171 people viewed this question
Top Bissell Vacuums Experts
Roger Potts
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
