Question about HP Pavilion dv6000z Notebook
Dv6 Pavillion gives 3F0 error and will not boot up, saying an OS needs to installed on the HHD, but the laptop will not acknowledge that a HDD is installed.
  • 621 Answers
Sounds like you need to start from scratch and format then complete reinstall. You will need to boot from the Windows CD and see if that recognises the HDD. If you have information on that HDD which you need you will have to remove the disk and plug it into another PC as a second hard drive and copy what you need. Cheers from Scott and plz vote
Posted on Nov 05, 2010
HP Pavilion laptop - HDD issue?
very possible a hdd issue
you can get solid state hard drives ( far superior to disc hard drives) for around $90.00 for 125 gb
sshd drives have no moving parts , are much faster in start up and can get more data stored than a disc hard drive
KIngston brand are very reliable and can be got from the net--e-bay
Install one and use the os win 8 disc to install the os into the computer
if you don'y have a disc , you can install from the web and use the activation code you have for the disc
on installing the sshd, you will need to go into bios and change the boot from hhd to cd or external hard drive
that puts the os on to the new sshd and when that iscompleted you can then go back into bios and change to boot from external ( disc) to sshd
Sep 25, 2016 | HP Computers & Internet
Hdd not on boot list
Have you tried a cold start, unplug, remove battery, hold down on/off button for 10 seconds, replace battery, plug in try to start normally. If that fails open your laptop, remember to remove battery, and Re-Seat, remove and replace the HDD. If that fails take the HHD out and have it checked by a qualified Tech. You can get devices to connect your HHD to another computer via USB, mine is a ULTRA USB 2.0 to IDE/SATA Cable Adapter. Then you can verify if in is dead.
Nov 04, 2012 | Packard Bell Computers & Internet
HP recovery disks don't boot!
Sounds like you need a windows vista operating system disc. The recovery discs set your system back to factory settings like when you first brought it home from the store. But to me, the system is bloated with all the software and trial junk that you don't need. If you can get your hands on a Vista Operating System Disc, then do a clean install from it. Just make sure your Certificate Of Authentication (COA) sticker is readable so that you can activate the vista once you've got it loaded. If you can't get your hands on a system disc, take it to a computer repair shop, I would think you could find one that will load the operating system for $60 or less.
Mar 15, 2012 | HP Pavilion dv6-1030us Notebook
Sony VAIO VGN-NW240F/B sometimes will boot up normally and reports a controller / hhd error. It will stay on for a while and shortly thereafter it will go dark and display operating system not found.Reboot...
reformat HDD reload OS; i.e. windows then restart
your computer is saying that the hard drive can no longer find the operating system as it is corrupted
Nov 06, 2017 | Sony VAIO VGNNW240F Notebook
HP dv6-2110 won't boot up- 'Hard disk does not exist' I've had my lap top for just over a year. Its been working great! Was fine all sunday morning, then when i came to turn it on to use...
If the battery of the HP laptop is not in a good condition, sometimes booting problems might happen. To remove any static charges accumulated in the battery, you would have to remove the battery and press the Power button for about 25-35 seconds. Then reset the battery. Even after this, if your laptop is not booting up then you could perform the battery calibration and press F8 key to boot in safe mode.
Jul 27, 2011 | HP Pavilion dv6000z Notebook
My dell inspiron 1525 has a black screen with a white cursor showing
First, I want to know if you sees the Dell logo after turning on the laptop? If yes then this is no boot issue.
1. Immediately run the PSA. Make sure laptop is off. Press and hold down the Fn key, while holding down Fn key press the power button at the same time just once. Once the Dell screen loaded you can now let go of the Fn key. Check if the PSA will run short test for the LCD, RAM and HDD. When full color displays on the screen just press Y. PSA will continue. Just take note of any error code will appear on the screen such as 0141, 0142 and 0146 these are HDD failure errors which means HDD needs replacement. If the test says no errors found then proceed to step 2;
2. Try restarting the laptop once you see dell logo then keep tapping F8. Select last known good configuration. Press enter key. Just wait and check if laptop will load Windows. If not then, restart laptop keep tapping F8 try to select safe mode check if it will load Windows. If not then prepare the Windows OS disc the one came with your laptop.
3. While laptop is on insert the Windows OS disc. Restart the computer. On the Dell screen keep tapping on F12 to show boot menu. In the boot menu select CD/DVD ROM Drive. Press enter then keep tapping on space bar until it will say Windows loading files, please wait.
4. In the User Interface it will show you some options to select. Once the Install screen comes up look on the lower part select Repair Your Computer. If will ask you to do Startup Repair, please do start up repair. If fails try the System Restore. If fails then step 5;
5. If you have important files in your HDD then back up your files first. After backing up of files you can now install the Windows OS. Here is the process in installing the Windows OS. Insert the Windows OS disc, restart the laptop, keep tapping F12 on Dell screen, on boot menu select CD/DVD ROM Drive.Install the Windows OS. Just complete the installation.After the installation install the laptop drivers.
Dec 10, 2009 | Dell Inspiron 1525 Notebook
Reinstalling
Hard drive has bad sectors on it which is why its giving you that message even though you can go thru the restore. Normally going thru the system cd and then the recovery cd should bring you into windows with the device drivers installed.
Dec 10, 2009 | Acer Aspire 5520-5156 Laptop
After fdisk and format of hdd install of os freezes after 2min. when it says windos is starting, tried differant versions of windows does the same thing!!!! Please help!!!!!!
PXE media failure means the system is trying to boot via Network card not your hard drive. When you performed fdisk then formatted the disk, you might have not selected an active or logical partitioning to support the OS. Run the PSA diagnostics by holding the Fn button before turning on your computer. If it gives you an error, it means your HDD has gone bad and needs to be replaced. If it freezes during the the loading of files during the installation, it means that your RAMs are bad because the windows loader dumps all the information to the RAM chips. If it does hang during the installation of files, two points of failure are to be looked upon, the RAMs and the HDD. I recommend you reset the BIOS to the factory settings as to reset the boot priority so it does boot to HDD first, not to any of the bootable drives available on your computer.
May 15, 2009 | Dell Inspiron E1405 Notebook
HP Pavillion won't boot
has windows been registered.
if so your gonna have to reinstall windows.
make sure os disk is in cd tray ..boot up...choose install (not repair) sys check says os already installed continue install or repair...at this point choose repair..this way any files or downloaded programs wont be lost.
Jan 10, 2009 | HP Pavilion dv9000z Notebook
HP Pavilion dv6000z Notebook Logo
2,098 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
