Question about Fluidmaster INC #B1F09 9" Faucet Connector
The lever must be held all the way down until all water leaves toilet or toilet does not flush and re-fill
  • 21 Answers
Have you recently replaced the fill valve and flapper ?If so make sure they are interchagable and can produce close to the same GPF as original hardware.Fluidmaster has a tall tube that can be cut according to tank depth to accomidate water volume in tanksome times a little more water volume will do the trick.Also make sure flapper is staying open long enough to produce the required results.
Posted on Nov 06, 2010
Jacuzzi toilet
After flush the system must close the hole which lets water into the toilet. If it does not close after flush, it is continuously letting the water thru. Check if it closes after flush and allows tank to fill.
Jul 10, 2013 | Home
Toilet fills with water then slowly goes down
you have a blockage maybe outside in your shores
Oct 16, 2012 | Home
The water level in my Toto Drake toilet bowl is normal right after a flush, but often is very low a few hours later.
The bowl is cracked and is leaking down the drain. You will have to replace it. It may have cracked if the bowl hold-down bolts were overtightened, or the bowl was not able to sit flush (pardon the pun) on the floor. If the bowl rocks when it is first installed, instead of tightening the hold-down bolts, use a couple of tapered shims under the edge of it, then caulk to fill the gap and hide the shims.
Good luck.
Jun 09, 2012 | Toto CST744SLR Elongated Drake Two Piece...
The toilet isnt flushing and water is not filling into the cistern? (at the top) how do i fix this problem??
If I understand correctly, the tank that holds water is not filling up with water.
1) If this is the problem, then you need new toilet fill valve.
Or clean sediment out of existing fill valve by removing and soaking in CLR calcium rust lime.
To replace fill valve:
Look at water supply line coming into tank.
Supply line connects to fill valve.
Buy new fill valve at home center, hardware store, or walmart, or online.
There are two nuts connected to valve. Each nut has companion rubber washer
One nut & washer seal water supply line to tank.
Second nut & washer seal valve to tank.
2) If water tank is full of water, but water does not flow rapidly into bowl when you push flush lever, then your toilet is clogged with sediment.
To solve sediment problem when flush water will not flow rapidly into tank, then buy CLR calcium lime rust.
Pour CLR down into overflow tube located inside water tank.
Make a funnel by cutting off bottom of water bottle, or cut paper cup into a funnel.
Pour cup-full after cup-full of CLR into overflow tube until sediment and CLR are coming out all flush holes located under-rim on bowl.
3) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 22, 2011 | Home
Handicapp Toilet Bowl does not fill - up as high as regular toilet > very small amount of water in bowl after flushing ie> about 10 cuos of water.. JUST INSTALLED IT NEW YESTERDAY...
Wiith all due respect, the Drake toilet is not a regular toilet and doesn't sound the same as a regular toilet when you flush it. It is in the design that allows it use only 1.5 gpf instead of 3.5 gpf. A rather unique thing is that while it is scientifically calibrated to release 1.5 gpf, it does not empty the tank of approximately 1 gallon of water. Therefore if one feels the need for a little extra umph, simply hold down the flush lever when you flush until the tank is emptied.
Aug 04, 2010 | Toto DRAKE ELONGATED HANDICAPPED TOILET...
I have a toto toilet that doesn't start to refill until a couple of minutes after I flush. Any ideas. Thanks.
Several ideas. Start to fill? Have you looked inside the tank to see what's going on? If it just filling very slowly, then you most likely have some calcuim build up inside your flush valve blocking some flow, if this is the case you will have to clean the flush valve. If your flush valve is staying up and the toilet is "running" unitil the float drops. The float (either the arm ballcock style, or newer fluidmaster) is rubbing on either the flush lever or side of the tank, and taking longer to drop to let the water start flowing. I
Jun 23, 2010 | Toto Toilets ST784S 12 Sedona Beige...
Low water level in bowl after flushing
The small black tube that goes into the overflow is used to fill the bowl after flushing. Would check to make sure that water is coming out of that tube at full force or if its coming out at all.
May 11, 2010 | Eljer & Elongated Toilet Bowl
I have to hold the lever of my Eljer one-piece toilet to flush it. How to adjust it?
lift off cover and shorten flapper to handle chain/rubber connection flapper not opening all the way
Apr 11, 2010 | Eljer Toilet Onepiece Canterbury ...
Our Toto bowl does not fill up enough after flushing unless the lever is held down. What do I do to fix it? We have well water and a bit of mineral does build up on the fill tube.
The only adjustment available is to control how full the tank will be for the next flush. The water that runs down into the bowl after flushing comes through the same valve that fills the tank, so the problem (and solution) is entirely with the amount of water that runs into the bowl while the tank is filling. The tank is filling sooner than enough replacement water can run into the bowl. Make sure that the tube (usually a 1/2 inch rubber tube) that runs from the float valve to the pipe that fills the bowl (usually a 1 inch pipe with an open top) is actually delivering all of it's flow down that pipe. If the flow of water being delivered by that tube is slow, you will have to find and eliminate the restriction. You might be able to pull of the rubbber tube off of the float valve and stick a small drill bit (just using your fingers, not a drill) into the fitting where you pulled off the tube.
Mar 08, 2010 | Toto Carlyle 1-piece Elongated Bowl Toilet
When flushing toilet, water spins in bowl but does not flush away. Have used plunger to no avail. Any suggestions?
It's either plugged or the tank isn't filling properly.
If it's the tank then the fill valve in the tank needs to be adjusted. There should be a screw to adjust the float ball. Back the screw out until the fill valve starts to run;let the water run until the tank fills to the fill line then turn the screw back in.Try flushing the toilet. If that doesn't work then the toilet is probably plugged.
If it's plugged you may need to rent/borrow a snake to clear the line.
Oct 09, 2009 | American Standard 2071.016 Heritage One...
Fluidmaster INC #B1F09 9" Faucet Connector Logo
308 people viewed this question
Top Fluidmaster Plumbing Experts
Mack Baxter
Andrew Bugbee
Tom Chichester
Are you a Fluidmaster Plumbing Expert? Answer questions, earn points and help others
