Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
My calculator will not come on or show anything on the screen. I have replaced the batteries.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
If this doesn't do it, please reply to this post and we'll go from there.
Posted on Nov 05, 2010
How do I reset my TI-86 after a long period of no use.
Every time you change batteries this will happen to you. First press 2nd then press and hold the down arrow. Hold until their is no black in the background but you can still see the numbers on the screen.
Sep 05, 2014 | Texas Instruments TI-86 Calculator
I was currently using my TI-83 and the screen started showing these crazy symbols. I decided to change the batteries however; the screen now just comes up black or still show crazy symbols. It still...
hi..
this may caused by internal errors. ICs in your calculator must have died.
i think your calculator meets its end of days.. how long you being using this calculator.
Mar 26, 2011 | Texas Instruments TI-83 Plus Calculator
How do I get the calculator to turn on again? The display doesn't show anything. Batteries checked okay. Thanks. Adolf
First, try adjusting the screen contrast. Turn the calculator on (or at least press the ON key). Hold down the C key and repeatedly press the + key to darken it.
If that doesn't do it, try reseting the calculator. Turn the calculator on. Hold down the C key and press the GTO key.
If that doesn't do it, use a thin pointed object (unfold a paper clip or use a sewing needle) and press the reset hole on the back of the calculator.
If that doesn't do it, the calculator may need servicing (or replacement).
Mar 22, 2011 | HP 35s Scientific Calculator
When I on the calculator, it does not show anything.I changed the battery, it doesn't work either.
If this doesn't do it, please reply to this post and we can go on from there.
Dec 15, 2010 | Texas Instruments TI-84 Plus Calculator
Hasn't been used for a while and now won't turn on...changed batteries
Very likely that the screen contrast changed after the replacement of batteries.Some times screen becomes too dark or too dim.
If it does not seem to turn ON that may be because screen is too dim that you cannot see anything and cannot be sure it is ON.
To darken the screen:
  1. Press the ON button
  2. Press [2nd] key and release it.
  3. Press and HOLD the Up Arrow.
  4. Keep at it until screen starts showing something.
Jun 24, 2010 | Texas Instruments TI-84 Plus Calculator
Calculator won't do anything. Screen won't even come on and I replaced all the batteries. Worked fine one day and then wouldn't work the next day
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible. Does that do anything?
Apr 17, 2010 | Texas Instruments TI-84 Plus Calculator
Where is the constant factor key on a Canon P170-DH?
How to do constant multiplication or division on the Canon P170-DH calculator
This process actually requires fewer keystrokes than other calculators. Basically, just do the first problem
and then do the next items with just the next number and the EQUAL key. For example,
*** Constant Multiplication ***
2 (multiply key)
10 (= key)
(The answer 20 shows on the screen. Note, the 2 is still stored as a constant without doing anything, just continue)
4 = (shows the answer 8 on the screen)
20 = (shows the answer 40 on the screen)
100 = (shows the answer 200 on the screen)
*** Constant Division ***
10 (divided by key)
2 =
(shows the answer 5 on the screen, the 2 is still stored as a constant without doing anything, just continue)
100 = (shows the answer 50 on the screen)
500 = (shows the answer 250 on the screen)
4 = (shows the answer 2 on the screen)
Feb 26, 2010 | Canon P170-DH Calculator
I do not see anything on the screen. I replaced
First try turning the calculator on and then pressing the 2nd key. Hold down the "up arrow". If the contrast has been turned down, this should turn it up.
If that doesn't work, could be that your calculator needs to be reset. Take out the internal battery located right above the 4 AAA batteries behind a small door with a screw. Leave all batteries out for about 8 hours. Reassemble and hopefully you can turn it on. If this doesn't work, you might replacing the internal battery. Hopefully one of these solutions will work.
Aug 06, 2009 | Texas Instruments TI-86 Calculator
Cannot find the constant key for multiplication
This process actually requires fewer keystrokes than most other calculators. Basically, just do the first problem
2 (multiply key)
10 (= key)
10 (divided by key)
2 =
Also note! There is no K visible on the screen to indicate a constant is set.
Nov 17, 2008 | Canon P170-DH Calculator
Black screen
http://www.xnumber.com/arch3/arch3/000006ef.htm
Oct 03, 2007 | Texas Instruments TI-81 Calculator
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
20 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
