Question about Kyocera Yashica T4 35mm Point and Shoot Camera
Mid Roll rewind on Yashica T 4 after around 13 shots . What might cause ?
How do you rewind film in nikon n8008s
At the end of the roll, press the film-rewind/multiple-exposure button (marked with a roll of film and "ME", at the three-o'clock position on the round pad on the left of the camera. In mid-roll, press that button and the film-rewind button just to the right of the prism simultaneously.
See the illustrations on page 19 of this manual.
Nov 10, 2012 | Nikon N8008 AF 35mm SLR Camera
Is there a manual rewind on nikon n65?
If by manual you mean turning a crank to rewind the film, no. If you mean to do it at a point other than the end of the roll, yes.
To rewind film mid-roll, press the two film rewind buttons simultaneously for approximately one second. The film will then rewind and the frame counter will count backward. The film is completely rewound when the E appears in place of the frame number.
The two film rewind buttons are marked with a red film canister symbol with left-pointing arrows. One is the exposure compensation button next to the control panel, the other is the self-timer button next to the mode dial.
If you need a manual, you can download one from
http://butkus.org/chinon/nikon/nikon_n65/nikon_n65.htm
Jan 21, 2011 | Nikon N65 35mm SLR Camera
How do i rewind the film on the nikon n60?
The camera should rewind the film when it reaches the end of the roll. If it doesn't, or to force a rewind in the middle of a roll, press the mid-roll rewind button with a pointed object. The button is on the bottom of the camera, toward the left end (away from the handgrip), and marked with a roll of film.
Sep 04, 2010 | Nikon N60 35mm SLR Camera
Why is the film automatically rewinding around 15 shots instead of the end of the 24 shot roll? The batteries are fresh.
the roll sensor is not reading the silver code on the film roll.
Open the camera when you have no film in it.
Clean the film roll slot where the "fingers" are.
These fingers touch the case of the film roll to determine the film type, which includes the number of exposures. You nmay have to "adjust" the fingers so that they make good contact with the film roll case.
Look at different rolls of film, notice the silver blocks are different. If the roll has a "dent" on it, it can't be sensed correctly.
Hope this helps!
Sep 15, 2009 | Canon Sure Shot Classic 120 35mm Point and...
Old sure shot - fixed lens, dropped, won't work, how to get mid roll film out?
wait until nite, then go to a dark room, ( bath room or closet ) no lights. remove film then rewind the film canister manually. turn plastic sprocket to the left untile all film is in the canister.
make sure no light is comming from around door.
Jul 31, 2009 | Canon Photography
I just bought a second hand Contax RX but the film rewinding stars automaticaly after 5 or 6 shots, even in a 36 exposures roll. Is it a set mistake? Thanks. Julio
The auto-rewind is triggered when the film advance mechanism detects tension on the film, indicating the end of the roll.
It could be a couple of things causing the problem...
1) The particular roll of film you were using was wound too tight, or has got some moisture in it causing it to stick.
2) If it has done this with various rolls of film, it is likely that the clutch mechanism that detects the film tension is out of adjustment. This is something that a professional camera repair shop will be about to fix for you.
I'm not familiar with this particular model of camera, but there may be a facility to turn off the auto-rewind as a short-term fix.
Hope this helps!
Jun 27, 2009 | Contax RX 35mm SLR Camera
Can't rewind film
It should automatically rewind when the roll is at the end. For mid-roll rewind press both the rewind buttons simultaneously for about 1 sec and the film will rewind.
May 21, 2009 | Nikon F80 35mm SLR Camera
Minolta Maxxumm 4 - rewinding too soon
Hey Pix4me,
I would make sure that the manual rewind button on the back of the camera is not stuck in, or you're not accidentally hitting the manual rewind button. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 06, 2008 | Konica Minolta Maxxum 4 / Dynax 4 QD 35mm...
Kyocera Yashica T4 35mm Point and Shoot Camera Logo
469 people viewed this question
Top Kyocera Cameras Experts
Iqbal Husain
Iqbal Husain
Are you a Kyocera Camera Expert? Answer questions, earn points and help others
