Question about Bosch Ovens
Hello. I have an HEV 434350 (in Barcelona). It's suddenly stopped heating. The fan works, the display works. The child safety device seems not to work (I press it for far longer than 4 seconds, and nothing happens). Can anyone help me?
  • Bosch Master
  • 3,463 Answers
Sounds like a faulty oven element, if the fan is wrking o/k, then I suggest you fit a new oven element, usually located at the rear of the oven compartment behind a removeable cover.
Posted on Nov 05, 2010
  • m_strubell Nov 05, 2010
    Thanks for your advice.
    The thing is, neither the broiling element nor the bake element seem to work. Would both pack up at the same moment??
  • Barry Coates
    Barry Coates Nov 05, 2010
    It is possible, but to be sure you need to check if the elements are getting a supply voltage to them.
AEG double oven/grill stopped working
It appears the oven has shorted out. Try checking the breaker box and see if any switches have been flipped. If this is not the case a new oven is in order.
Jan 24, 2014 | Ovens
Lower oven loss of power
I'd check the control switch first, and the wireing and connections.
Sep 05, 2012 | Ovens
Fan oven stopped heating
Is the fan working in the oven if not then check if the clock needs resetting.If the fan is working then it is more likely that the ring element around the fan has failed.Check also if the thermostat light comes on,this is an indication it may be ok.
Hope this helps.
May 25, 2010 | Ovens
Oven has stopped heating up - fan is still working as is interior grill
It seems that the element which surrounds the fan has most probably burnt out,and will need replacing.
Hope this helps.
May 14, 2010 | Ovens
Hello. I have an AEG electric oven which is
It seems like the element around the fan in the main oven has most probably burnt out and will need replacing.
Hpoe this helps,
May 04, 2010 | AEG B1180-4 Electric Single Oven
I can't unlock touchscreen panel
This is an safety features that prevents unwanted oven operation by children.
To set child lock...
Touch and hold STOP/CLEAR or 0,START until LOCKED appears in the display and two beeps are heard. If the time of day was already set, the time of day will return to the display windows. After you touch another.
If the CHILD LOCK was already set and you touched another cooking pad, the word LOCKED shows in the display.
Then you can cancel the CHILD LOCK according the below procedure...
Touch and hold STOP/CLEAR or 0,START pad until LOCKED disappears in the display.
Aftes the CHILD LOCK is turned off, the time of day will return to the display window. The oven will operate normally.
Hope helped with this. Good luck.
Nov 04, 2009 | GE Ovens
C362e fan oven stopped heating up fan still works top oven, grill and hob still work.. Had same problem about a year ago, but suddenly started working again before i could get help.... ???
If fan is working o/k, then it is more than likely that the oven element is causing the prob, I would fit a new one under the circumstances.
Please rate my solution.
Thanks.
Jul 14, 2009 | Ovens
Ovens Logo
107 people viewed this question
Top Bosch Ovens Experts
ashburton
paulcarew
Are you a Bosch Oven Expert? Answer questions, earn points and help others
