Question about Optoma HD20 DLP Projector
I just got a new Optoma HD20 and only after 1day of use it is not showing HDMI signal, although it is showing VGA signal. Why is this?
Hi miracles4all: I solved HDMI signal issue in my Optoma HD20. In my case it was the lack of contact between the HDMI cable plug male ending and the Optoma HD20 HDMI female port. My 35ft cable plug male HDMI ending was not completely "seating" in the Optoma HD20 HDMI female port. I solved the problem by purchasing a HDMI female to female coupler and adding a 3ft HDMI cable that had a slim male ending. This 3ft HDMI extension cable made better contact to the Optoma HDMI port and the projector was immediately able to detect HDMI signal. Hope this helps you... kaufmanekpr
Posted on Dec 27, 2010
  • precious22 Feb 01, 2011
    Hello Friend,
    Lepo je sli?ati ste imeli najbolj?e telo
    in zdravje danes. I negovanjem, ki imajo v
    stik z vami po tem, ko opravijo svoj profil.
    Mi bo v?e?, da veste, ?e boste mi
    prilo?nost za razvoj, kar je za vas.
    stik z mano (precious10k@yahoo.com)
    dam moj slik in vam povem moj
    Namen uporabe svojega profila.
    Od Precious.
I connected up vga and HDMI cables and power, etc to ASUS desktop. All inputs are without signal. If I set monitor for vga, it says no vga signal. Same if set for HDMI input: no HDMI signal.
I would check your source for why it is not sending signal rather than why the monitor is not receiving. Of course, that being said, is this a new monitor or an old one that could be shot?
Dec 26, 2015 | ASUS Computers & Internet
Why is HDMI input not working?
Apparently, HDMI cables can be finicky. You may have to try different ones to find something the projector "likes".
Sep 01, 2015 | Optoma Pk320 Pk320 Pico Pocket Projector
My projector ew615 just shows black and white screen like you get when you have no signal on your tv - has the lamp blown? but still lit?
the lamp is OK ,If there is a light from the Lens
Signal Board is not work ,it need to be repaired
Have a good day!
We supply original projector parts: lamp, bulb, Lcd, Lens, DMD,
motherboard, powersupply ... with high quality and competitive price.
Jerry China
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Aug 20, 2013 | Optoma EW615 WXGA 3500 ANSI LUMENS 3D...
Optoma hd65- componant signal OK but no hdmi signal found
whats the reason for no display on hdmi to hdmi connection- to the x box display is fine-?
Jun 25, 2012 | Optoma HD65 DLP Projector
Bought a new GA-G41M-Combo but no video signal? It shows that HDMI: No Signal.
You need to try VGA/DVI connector before HDMI. Only after the correct configuration applied to start from HDMI should solve the problem.
Apr 09, 2012 | Gigabyte Computers & Internet
Projector powers up as normal, bulb comes on, displays Optoma logo on screen and menu will show on screen. The issue is that although I have 3 devices plugged into the HDMI port of the device using a HDMI...
There is a source lock and source button I would unlock source lock button and the push source button until you get to your hdmi input you are using. You also may just plug in one input first and once you get the input right play with the multiple hdmis
Aug 11, 2011 | Optoma HD20 DLP Projector
Hi there, i was just wondering that, my hdmi monitor which is goodmans GTVL19W17HD monitor and it has a HDMI slot, but my graphics card doesnt, instead my graphics card has a vga and dvi slot, and if i...
Hi hassy786,
Regarding your question if you will use a converter from VGA to HDMI will it provid High Defenition video?
I believe that it will provdie video converting the signal from VGA to an HDMI connection but I do not think that the video will be High Definition since the VGA is just being converted to HDMI signal and not an actual HDMI but just a converted signal, and it is possible that it may not work properly or the LCD TV may have difficulties recognizing the signal from VGA converted to HDMI.
Thanks for chosing Fixya,
avf110686
Mar 27, 2011 | Goodmans GTVL19W17HDF 19 in. LCD TV
I have an optoma HD20 and it connects using a 1.5m HDMI but as soon as i try a 10m HDMI connection (even with a booster it does not connect) any suggestions welcomed?
Hi kgomer782 I have similar issue. My optoma hd20 signal connection with a 3/6ft hdmi cable is perfect. However, no signal is detected when connected to a 35ft hdmi 1.4 cable. The 35ft cable is indeed working becuase I tested it succesfully when connected to a 1080p HDTV. Did you received any solution to your problem? I wonder if it has anything to do with the HD20 design of the "debossed" hdmi ports that prevents the cable plug from getting completely "seated" in the port? My 35ft cable has a flat square male ending however, the 3/6ft cables have slim male ending that seems to accomodate perfectly in the Optoma's hdmi port design...kaufmanekpr
Aug 07, 2010 | Optoma HD20 DLP Projector
Apple Macbook pro video out to VGA port ("d-sub") on Optoma
There's no solution. it will not connect with macbook pro or any other mac. as on the phone with all technicians and they do not know what to do. I had the unit replaced and still would not connect.
Mar 19, 2008 | Optoma MovieTime DV10 Multimedia Projector
Optoma HD20 DLP Projector Logo
2,569 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
