Question about Refrigerators
When the freezer defrosts it partially melts the ice cubes, the ice builds up between the inside back and the outside back. This ice gets hit by the fan making an awful grinding noise water leaks out of the bottom of freezer onto the floor. and the bottom of the inside of the freezer fills up with ice. This happens at least once a week and we have to take it all apart and clean out all the ice and start over,and hope we are home to hear it grinding the next time and shut it off. It is only 1 yr and 5 months old and started doing this just as the 1 yr. warranty ran out.
  • maggierose Nov 21, 2010
    Sorry, just got back to my computer. The brand is Conservator by Crosley. Model CRSE234JB2 and the Serial # is 4A91701705.
  • Refrigerators Master
  • 1,711 Answers
What is your model and brand
Posted on Nov 05, 2010
I have a sharp 4 door sharp sj-f65ps. The ice builds up in the freezer and the fan makes noise as it hits the ice, ice cubes melt and the temp goes down, i have been defrosting manually every week....
You need to figure out which component in the defrost circuitry is bad. Either defrost element, defrost thermostat or defrost timer/control If the element and thermostat show 0 resistance it's the defrost timer/control board
Jul 22, 2015 | Sharp Refrigerators
Freezer side not cold enough, similar temperature as Refrigerator side
It could be many things. My first guess would be the defrost. The coil that gets cold in your freezer builds ice on it and the only way to get the ice off is to run a heater near the coil long enough for the ice to melt. All freezers have something built in to defrost and domestic are typically just an electric heater on a timer. When your freezer stops working again, you may want to pull open the panel of your freezer and see if your coil (a heat exchanger that probably looks a lot like your car radiator) is covered in ice. If it is, it could be the timer or the actual heater that is bad.
Nov 12, 2013 | Refrigerators
I have an LG LFC21770 refrigerator and have noticed a build up of ice on the back wall of the freezer section. Yesterday, when I opened it to get some ice - the ice was frozen but had obviously melted...
If the freezer fails to defrost you get ice building up at the back of the freezer.
The defrost cycle relies in a thermistor transducer to detect the ice build up and to turn on the defrost cycle. The water usually then drips down to a tray under te fridge and then gets evaporated away.
Hopefully you only have a problem with the thermistor and not the defrost circuitry,
This is hard for a repair man to diagnose as when you call them out to your fridge it will be impossible to diagnose if the freezer is totally packed with ice.
And if you let it defrost totally it will be hard to diagnose as they may not be allowed to use freon to cool the transducer.'
So if you call someone in to check this you need to know if the ice build up will be a problem for them .
Youtube has several videos on this situation .
Apr 21, 2017 | LG LFC21760 Bottom Freezer French Door...
The Fridge of my Rangemaster SXS Fridge Freezer is freezing up
You probably have one of the following problems: A failed defrost system, meaning the defrost timer and/or element has gone out and your evaporator coil is frozen over; you are low on freon and this too will cause your evap coil to freeze over until the freon drops so low all cooling stops; . Unless you have gauges, a licence to buy freon and service valves (or a buddy with such) you are limited to what you can do. Here is my advice:1. unplug the frig and let it defrose over night, or unplug the frig and empty the freezer to remove the back cover to look for ice, a frozen fan and if so get your hair dryer out and melt the ice so you can test the fan and the defrost element (you will need a volt/ohm meter to do the element check. You can do it.
Oct 27, 2009 | Refrigerators
Mr.
When the heater comes on for defrost behind the rear freezer panel , it gets red hot . The defrost thermostat ( bimetal ) , cuts the heater off , when it reaches 140 degrees for new (2000 - 2009 ) and 55 degrees for older refrigs . When this temp is reached at the top of the coils , the lower portion will be hotter due to being closer to the heater . The frozen food in the freezer , is what keeps the temp down in front of the rear freezer panel . No food in freezer , the hotter the freezer section will be .
Oct 03, 2009 | GE Hotpoint® HTR17BBSL Top Freezer...
Samsung RS253BAVQ freezer Keeps defrosting, and wont dump ice
One posibility is that it is not defrosting a all and that the ice is building up on the evaporator coil behind the rear cover inside the freezer. This condition will block the flow of cold air. Remove the back panel to see what your have. Either no ice , light frost, partial icing or heavy icing blocking the fins. Complete light frosting is normal.
Sep 09, 2009 | Samsung 24.8 Cu. Ft. Side-by-Side...
Panel is hot and freezer does not work!
Check the condenser fan underneath the unit accessable form the back behind the cardboard cover. It should be running when the compressor runs. OR Check the evaporator behind the rear cover inside the freezer. Check for ice build up. . Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control
Sep 09, 2009 | Freezers
Hotpoint refrigerator freezer(top) mod ctx18bacerww not cooling/freezing correctly. removed inside back panel in freezer compartment,found coils partially covered in frost, fan not blowing.. flicked fan...
Hi, fan may have stuck, but you could have a defrost problem, check defrost heater, thermodisc(defrost thermostat) and defrost timer. or excessive moisture, if your days are hot, or if you put hot foods in ref. could result in excessive ice build up. you can manually defrost it, by unpluging ref. for couple of hrs, until all ice melted. then restart. you make get excessive water on floor. be prepared.
Aug 02, 2009 | Refrigerators
Ice cubes made by ice maker become large fused chunks over time.
Ice cubes will deteriorate over time if not used. They shrink due to defrosting of the freezer and will become stale.
Once the ice bin is full, turn the ice maker off until you use the cubes and or dump the cubes every 3 or 4 days and start over.
Mar 03, 2009 | GE Refrigerators
Ice Tray Freezes & ice builds up around internal workings of ice cube holder
Check and make sure you door seal is tight. Take a dollar bill and place it between the door jam and gasket, close the door and then pull the bill slowly out. It should be rather tight all the way around. So you will have to do several checks all the way around the door. If you have a bad spot call and have them either replace the gasket or adjust the door.The other thing you can do (I have found most if not all manufacturers require this) empty your ice maker once a week. The problem comes from your refer being a self defrost. There is a heater coil that gets as hot as a range element to defrost the evap coil. It is the defrost cycle that causes the ice to melt down a bit. And the defrost cycles every 12 to 24 hours causing the cubes on top to melt down some. So as your bucket fills whatever was on top melts a bit and by the time you are ready to use several layers may be melted causing them to stick together.
Jun 07, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
50 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
