Question about Hoover Vacuums
Can not get the DAMN replacement belt on - Hoover Vacuums
  • 1 more comment
  • cbuggababy Aug 19, 2008
    I can't get the DOUBLE DAMN belt on either. I'm no 1/4 wit, so I think this is harder than it should be (maybe so I'll upgrade?). I'm getting past annoyed.
  • cbuggababy May 11, 2010
    hoover model# u4 263-930. thank you
  • Lauren Junge
    Lauren Junge May 11, 2010
    What do you have???
    President:
  • 1,673 Answers
Take the bottom plate off, the top needs to come off also, if you don't see any screws, then on each side edge, from the bottom, use a flat blade screw driver, pry up on each spot and the top will come off. Put the belt over the brush roll, put the bottom plate back on, turn it back over and stretch the belt to go around the motor shaft, turn it by hand to make sure it moves freely, then put the top cover and knob back on. Just push down hard until it snaps into place.
Posted on Sep 01, 2008
What is the replacement belt number?
Shop for Eureka Vacuums What is... on Google
Eureka® Replacement...
$2.89
Staples Eureka Upright Vacuum Clea...
$5.99
Eureka Eureka Hand Vac Belt
$2.49
Eureka Eureka R Type Replacement...
$5.99
Bed Bath & B...
(4) Eureka AS1104 Drive Belt
$3.49
Google Trusted StoreeVacuum... Search Results
    Belts - Eureka
    www.eureka.com/en-US/Vacuums/Accessories/Belts/
    EurekaWith high-quality vacuum cleaner belts from Eureka, you can get better performance from your ... For optimum performance replace belts every 12 months.
    Eureka Replacement Belt for Upright Vacuum ... - Walmar
Jan 19, 2016 | Eureka Vacuums
Dyson DC17, front roller motor stopped
Are you sure it's dead? The motor will turn off if there's too much resistance. Unplug the vacuum, remove the obstruction, plug it back in and then firmly press the beater brush on/off button which is located next to the main on/off button.
Apr 04, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
Seems like the belt may be getting old and not picking up as much as it used to.
Belts need to be replaced periodically. If the belt is worn it will not pick up the way it should. You can get DC07 replacement belts here:
Replacement belts for DC07 w/ clutch system
Replacement belts for DC07 w/out clutch system
Oct 30, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Roomba dirt in filter but NOT in bin
possibly the vacuum fan is plugged up or not spinning fast enough to pick up heavier items. disassemble the back canister and clean the fan chamber.(THis is one area of regular maintenance). if it is all clean then try to replace the motor. The other possiblity... You have one damn clean house. :)
Sep 03, 2009 | iRobot Roomba Discovery SE Bagless Robotic...
Installing belt
here are the step by step instructions from the owners manual for your machine.
Disconnect cleaner from electrical outlet. WARNING: Agitator brush roll can start suddenly. Unplug cleaner before turning it over. Replacing Flat Belt Place handle in low position and turn cleaner over so bottom side is facing up. Remove the 6 screws as shown with a Phillips screwdriver. Lift off bottom plate. Replace belt if it is stretched, cut or broken. To check the flat belt. Removing Bottom Plate Removing Belt Positioning Belt Remove used belt from large pulley and discard. Reposition bottom plate and 6 Phillips head screws. Tighten screws securely. Insert agitator brush roll through belt and position belt in groove (A) on agitator brush roll. Inspecting V-Belt The V-belt is designed to last for a long time and is not normally replaced. However, if the V-belt is cracked, gouged or broken, it should be replaced. Slide flat belt off large pulley. To remove V-belt, slide back of belt over pulley (A). Then firmly pull on belt and “snap” it out. Discard used belt. To install new belt (with lettering on outside of belt), slide back of belt over pulley and pull front of belt toward groove next to pulley. Belt will “pop” into place. Flat Belt: What to Buy Use only genuine HOOVER belts with your cleaner. When purchasing a new belt, ask for Flat belt - HOOVER part No. 40201-271. V-Belt: What to Buy Use only genuine HOOVER belts with your cleaner. When purchasing a new belt, ask for V belt - HOOVER part No. 40201-200.
If you can't get the answer from this post, send me a message and I will try to walk you through this. I hope it helps.
Jan 19, 2009 | Hoover Windtunnel Supreme U5280-900...
Need to replace vacuum belt
how do i change belt on morphy richards ultralight cyclone cleaner?
Jan 04, 2009 | Vacuums
Kirby g4 belt replacement
Facing vacuum,turn belt lifter knob counterclockwise till it stops.Lift headlight hood,and unlatch brushead,and remove.Looking thru the hole in back,turn belt lifter knob clockwise to release belt.Remove bottom plate,and bend one end of bracket to remove end of brush roll.Slip new belt on and replace brushroll back into bracket,and replace bottom rug plate.Looking thru hole in back,turn belt lifter knob until the hook inside picks up belt.Replace brushead,and again,turn belt lifter knob clockwise to drop belt onto shaft.
Dec 18, 2008 | Vacuums
Dc17 -too much pet hair around the belt gears
I was having the same trouble and it was driving me nuts.  I tried cleaning and it did not work.  Then I tore the brush assembly off and looked up into where the little tooth gear is.  I saw something that did not look right.  There was a silver roller bearing laying down below the assembly.  I got some tweezers and found it was not attached to any thing.  I then cleaned out the pet hair and saw a spot where this roller goes that takes the slack out of the brush. It is a pain and takes alot of trying with pliers and prodding  with a screw driver, but I got the roller back where it goes.  It does not attach very solidly, but I put every thing back together and it works great so far.  It is a definite design flaw.  I found that you have to keep the main unit on  the floor when the brush is running.  Do not do stairs or pick it up and do couch cushions, that is when the bearing breaks loose.  Dyson needs to figure out a better design for this.  I was lucky to figure it out, but it is very hard to get to.  Again never pick up the unit when the brushes are engaged.
Jun 05, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
1800 vacuum cleaner belt replacement
Generic problem for all Vacuums
How do you get into the belt to replace it?
Not knowing the brand name of the vacuum other than the 1800 vacuum cleaner belt replacement, normally the belt is located @ the bottom the vacuum attached to the brushroll and is held on by either screws, clips, or some even snap on – but mostly they use some type of screws to open the area to replace the belt, if needed contact the company website, include the brand name and the model number and request a schematic of the vacuum and that will give you an exploded view of how the vacuum assm goes together and also shows the belt replacement and how that is connected.
http://www.dooyoo.co.uk/vacuum-cleaner/typhoon-1800-upright-vacuum-cleaner/1021772/
Apr 07, 2008 | Vacuums
Hoover self-propelled windtunnel belt pops off
The correct belt is a 38528035. If the belt does not have this number printed on it, it is a generic belt and probably the wrong one. The pulley on the transmission is "convex" because this pulley design keeps the belt running in the middle. (a belt will always try to "climb up a hill") If the motor shaft and the pulley are not aligned properly, the belt will constantly throw off. This can be a result of a bad motor mount (located inside the motor compartment.) The motor shaft end has a rubber cover that absorbs vibration and keeps the motor positioned squarely. The handle could also be loose on the pivot. It is held down by two metal clamps that screw securely to the bottom, holding the handle on to the base and allowing for the handle to pivot backwards. This problem can be difficult to diagnose and I have had many in my shop for repair. It takes a seasoned and experienced repairman to find a solution to this problem, in most cases. The disadvantage I have here is that I cannot see your machines to inspect all the various things that effect the belt alignment. I hope that some of this information will help.
Oct 15, 2007 | Hoover U6630-900 WindTunnel Bagless...
Vacuums Logo
213 people viewed this question
Top Hoover Vacuums Experts
Roger Potts
Mike Cairns
Mike Cairns
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
