Question about Husqvarna 295cc Back Pack Blower HVH 130BT
Blower runs but will not throttle up.motor sounds like it chokes up
What can you spray it with to scrub out and clean the carbon? Carb cleaner, thinner?
Posted on Jul 18, 2013
  • Max P Jun 05, 2014
    I sprayed it with Carburetor Cleaner, and scrubbed it with a cheap wire brush, cleaned most it out and cleaned the Carb parts, Wash the Air Filter and check inside the gas Tank/container for to clean. There's a filter in the gas tank you can fish out the piece attached to the line in the tank and clean it with gas (this also helps) for all general maintenance. Also check the plastic basket between your back and motor for any stuck leaves interfering with suction
    Spark plug should be checked for replacement as well. You need to see if it's too burnt, but If you use it a lot change it regularly
  • 143 Answers
It sounds like the exhaust muffler is blocking up with carbon, you will have to remove it and try and clean it out. Stephen
Posted on Nov 05, 2010
Ryobi 9600 backpack blower. Starts great. Set to run, continues running. Upon attempt to use throttle, engine dies. Acts like choking out but removed carb cover an choke is no closing.
this sounds strangely like the high speed jet/pathway in the carb is clogged up with something ,
the best way to fix it is dissasmbly and cleaning of carb in solvent , but ive also had some limited sucess in past of using car fuel cleaner (says on bottle "cleans as you drive") too
Mar 09, 2015 | Ryobi Garden
How do I keep my Yardman bp2 leaf blower running? will idle but not come off of choke.
It sounds like a carb problem. You can buy a rebuild kit on line for cheap and rebuild it.Should run fine then.
Oct 11, 2014 | Garden
I have a CCR 3650 Snow Blower ,The engine is racing at idle. How do I adjust?
Try the spring on the governor. sounds like it's not hooked up, or extremely week. I rebuild and sell these all winter. I've had it happen a few times. Runs really good! but, will ruin the motor running over speed like that. There are adjustments- some have the spring on a long flange of metal so it can be bent backwards to add tension- it doesn't take much! If the motor starts to rev up and down and up and down, add a hair more tension. It there is too much tension it will stall out when you hit heavy snow.
Feb 01, 2011 | Toro Snow Blower Ccr 1000 Belt 715381...
Shindaiwa Blower - when throttle pushed, engine sounds flooded and it dies. any thoughts on how to fix?
Its not flooded- its lean.
Heres a way to test me. Try to give it throttle but keep it running. At the same time slowly close the choke. does it run better as you close the choke? Does it run pretty good on half choke?
Rebuild the carb, replace the fuel lines and fuel filter.
Dec 20, 2009 | Garden
Idles but stalls when throttled
If you have the TB2BP EC Troybilt backpack and it bogs down or begins to stall out at full throttle with choke in FULL OPEN try the following:
1. Do the simple stuff first, Check spark plug, air filter and clean or replace if necessary.
2. Remove air filter cover, open choke and spray out the carb with carb cleaner.
3. Inspect carb and look for a flat surfaced screw with a small V notch on the side of it. It will be on the top side just forward of where the fuel lines connect. If you find it don't waste any more time looking for the High and Low fuel adjustment screws (there aren't any) this is the only adjustment other than the throttle adjustment screw you'll find.
4. Start your blower allow time for it to warm up and advance choke as far open as you can without stalling motor (mine just suddenly wouldn't run in anything other than full choke).
5. With motor running, adjust the screw to improve operation. Depending on your initial choke setting you may have to adjust, open choke to next position and fine tune.
6. Note- clockwise reduces fuel to carb, while counter clockwise increases it (if it's stalling when you attempt to throttle up it's starved for fuel) I'm sure there's a tool designed so that some tech can charge you 100.00 to turn the adjustment screw 1/4 turn but I found that a pair of fine needle nose pliers did just fine. Pay attention to original position of the V notch and what adjustments you make ( I tend to make 1/4 turns and fine tune from there) so you can always go back to your starting point. Note I'm not a technician so I can't say this the fix for your machine but it worked on mine.
Aug 21, 2009 | Troy-Bilt Garden
Craftsman blower stalls when choke is disengaged
You need to play with the timing adjustment, either on the spark plug, or the gap between the contact and the magneto.
That'll do it ;)
Don't forget to rate, thanks
Jul 31, 2009 | Craftsman 4 Cycle Blower/Vac
Blower wont run at full throttle
Start with the spark plug it is the easiest.
But sounds like the carbourator is dirty, Probably fouled with old gas varnish. When it is idling give it a little throttle, flip the choke on and then full throttle. If it goes full throttle and doesn't conk out, it is a fuel issue.
Good Luck
Dec 07, 2008 | Troy Bilt Backpack Blower, 25cc, 160 Mph,...
Husqvarna 295cc Back Pack Blower HVH 130BT Logo
597 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
