Question about Canon Office Equipment & Supplies
I have a canon irc 4080i all colors are coming out really light and if there is a photo its blurry. I can manually darken up copy quality and it looks better but photos are still blurry. Looking for ideas.
    Scholar:
  • 79 Answers
Inside the copier, there is a rather large, 6-10 inch diameter photosensitive, green drum that is used to transfer the toner to the paper. It sounds like the drum has lost the ability to charge properly, and thus it is not picking up the proper amount of toner to transfer to the page.
Suggestion: check the drum for any marks, scratches, or bands. Also, if drum appears good, the issue may be related to the developer power not being able to charge up to its full potential.
-David.
Posted on Nov 05, 2010
  • tlopez38 Nov 05, 2010
    do the drum and developer come as together in one unit and is there any sort of mechanical or electrical adjust that can be made
  • redmond_davi Nov 05, 2010
    If I'm remembering correctly, then I believe that they are separate assemblies that fit in with the drum unit on top of the developer assembly. As far as color adjustments, they are meant for small calibration errors and not dramatic changes. You most likely have a faulty drum.
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
How do I adjust the setting to lighten copies?
Canon : PIXMA Manuals : Print Studio Pro : Settings Area ...
ugp01.c-ij.com/ij/webmanual/PrintStudioPro/W/1.3/EN/.../psp-406.html
figure: Settings area (Correction). (1) Black and White Tone Adjustment Area ... Move the slider to the right to darken and left to lighten the color. ... the XPS printer driver (Canon series XPS) for Printer in the Settings area (Print Settings).
Canon : PIXMA Manuals : MX920 series : Adjusting Intensity
ugp01.c-ij.com/ij/webmanual/PrinterDriver/W/.../Dg-c_intensity.html
You can dilute (brighten) or intensify (darken) the colors of the overall image data ...Used Settings, and then choosing Color/Intensity Manual Adjustment under ...
Canon : PIXMA Manuals : Image Settings
ugp01.c-ij.com/ij/webmanual/ScanGear/M/MFP/19.1/.../Sg-930.html
When Image Adjustment is set, the brightness of the specified portion of the ... Use this function to reduce show-through in duplex documents or lighten the base ...
Oct 20, 2015 | Canon PIXMA MG3222 Wireless Inkjet Photo...
Poor print quality .... Canon Pixma MP140 ...
Paper quality does make a difference in the quality of print, but it's usually in the areas of blurriness and vibrance. If your prints are coming out faded, the quality for your prints might be set to 'economy', which doesn't use very much ink. If you have it set for 'quality' prints, I would try replacing the ink cartridges.
May 08, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Darkening the copies
Here's information from the HP manual:
Use the copy features
The HP All-in-One enables you to produce high-quality color and black-and-white copies on a variety of paper types, including transparencies. You can enlarge or reduce the size of an original to fit a specific paper size, adjust the darkness of the copy, and use special features to make high-quality copies of photos, including
borderless copies.
Press Copy repeatedly to display the appropriate menu. The following menus are available:
– Number of copies
– Reduce/Enlarge
– Copy Quality
– Copy Paper Size
– Paper Type
– Lighter/Darker
– Enhancements
– Set New Defaults
2. Press the until the appropriate setting appears.
3. Do one of the following:
– To change more settings, press Copy.
This selects the current setting and displays the next menu.
– To start the copy job, press Start Color or Start Black.
To save the current settings as defaults for future jobs
1. Make any needed changes to the settings in the Copy Menu.
2. Press Copy repeatedly until Set New Defaults appears.
3. Press until Yes appears and then press OK.
This should help you.
Feb 20, 2009 | HP Officejet 5610 All-In-One InkJet...
Canon MF3110 - Copy problems When we try to copy a document it comes our blurry, yet if we send a document from computer software it comes out fine.
Try reinstalling the driver first. If that does not work, the issue is with the scanning hardware, which will have to be calibrated. Try doing a calibration of your scanner from the tool box first. If that doesnt work either, then it is definitely scanner hardware defect.
If your all in one is under warranty, I'd recommend you contact the point of sale of the manufacturer. Unfortunately, if your warranty has run out, you will either have to get it serviced or buy a new machine (whichever works out cheaper)
Hope that helps!
May 26, 2008 | Canon Office Equipment & Supplies
Pictures are blurry; quality of photos seem compromised
As simple as this may sound, have you cleaned the lens lately? A lot of image quality deterioration comes from a finger print or other smudge on the lens. Digital cameras are succeptable to even the smallest gunk on the lens. Because the lens element is very tiny, use a cotton swab with a drop of lens cleaner (or isopropyl alcohol) to thouroughly clean and dry the lens. If it isn't a dirty lens, check your file-size and flash settings.
May 06, 2008 | Canon PowerShot A95 Digital Camera
Lexmark 3 in 1 x1270 scanner does lousy with certain colors ----blurry
Scanners (or copiers) can't improve on the image they are seeing.
If you view the labels under a bright light, you will see what the scanner is seeing too.
The only thing you can do is as you already have, use a photo editor to correct those cosmetic flaws before printing.
Apr 15, 2008 | Lexmark X1270 All-In-One InkJet Printer
Poor color when printing in high qualitiy - fine when in standard quality
go to preferences then clock on manual
slide pink slider 100%left
give a litle bit black to right
print light
Manual is the printers dark room
Feb 27, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Bad quality printing from the black cartridge
Select the correct Media Type setting (Windows)Print an image from another source
Change the Print Quality Settings (Windows)
try these if they dont work time for print head replacement.,
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=257&modelid=10236
Nov 30, 2007 | Canon PIXMA iP1500 InkJet Photo Printer
Light copies on canon imageRunner 3170i
No, but if you put a yellow plastic sheet under your document you will be surprised by the improved copy quality.
Sep 24, 2007 | Office Equipment & Supplies
203 people viewed this question
old marine
old marine
