Question about Uniden DWX207 1.9 GHz 1-Line Cordless Expansion Handset
MY DWX207 WILL NOT CHARGE, THE CHARGER LIGHTS UP BUT THE HAND SET DOES NOT CHARGE, I DID PRESS THE BUTTON ON THE BOTTON AND CHARGED FOR 24 HR. PER INSTRUCTIONS, THE HAND SET WORKED WHEN I BOUGHT IT BECAUSE I USED IT AFTER 24 HR OF CHARGING. I SET THE CHARGER UP IN MY SHOP WITH THE HAND SET CHARGING AND DID NOT USE IT FOR SEVERAL DAYS, AND WHEN I DID GO TO USE IT THE BATTERY WAS DEAD.
SOURCE: bought phone EX18560 Series yesterday.
I have two older (2002) model cordless Uniden phones that require the handsets to return to their original factory bases. If they have rested on another Uniden base, even of the same model, there is no dialup tone. Replace to the original base and you should be back in service.
Posted on Aug 16, 2008
SOURCE: Uniden DSS7955 Cordless phone problems
I had the same problem!
What you need to do is hold the "end" and "#" key for 5 sec, which will deregister the headset then all you would have to do is place it back in the base for it to registered again.
Posted on May 06, 2009
  • 5 Answers
SOURCE: handsets won't charge even with new battery
they may need new batteries
Posted on Aug 15, 2009
kalamazoo222
  • 285 Answers
SOURCE: My phone sits in it's charger when not in use, and
Your phone may need a new battery, but it could be as easy as cleaning the charging contacts! Look at the little metal wires/pads on the phone and in the charging cradle. If it is not shiny, then clean them. It is safe to use a little rubbing alcohol on a cotton swab and rub them until they become shiny.
Good luck and thank you for using FixYa! We would sure appreciate a 4 "thumbs-up" rating for this FREE answer. Happy holidays!
Posted on Dec 08, 2010
SOURCE: Uniden DECT 1580-4WXT waterproof unit appears to
This phone uses inductive charging because of the waterproof feature. I suggest that you remove the
battery cover from the back of the handset, unplug
the battery, and then plug it back into the handset.
This solution worked for me.
Posted on Dec 10, 2010
24 volt, 172-743240
Sometimes, the charger will overheat and fail. Try unplugging the charger overnight, plug it back in the next morning, then place the battery in the charger after waiting a few moments. Normally, this will correct the charging discrepancy.
May 24, 2014 | Garden
Kindle does not charge properly
Let's try to reset the charger system.
Step 1: Unplug from the charger, press and hold the Power button for 30 seconds
Step 2: Plug into the charger. Press and hold the power button for 30 seconds
Step 3: Let charge for 12 hours
Step 4: Unplug form the Charger, run the Kindle until totally dead.
Step 5: When DEAD. Press and hold the power button for 60 seconds.
Step 6: Plug into the charger, let charge normally
If this does not reset the charging system you have either a faulty Kindle or a faulty charger, contact Amazon for replacement.
Apr 01, 2013 | Amazon Kindle Fire HD
My sony xperia T will not charge
Success story. Disclaimer I haven't notice any damage or
loss of data, However I take no responsibility for any damage or loss of data
that may occur.
My girlfriend has a xperia T and did let it go flat, since
then it didn't appear to charge or switched on.
I had tried allsorts suggested on various websites such as
plugging charger in and out a few times, leaving in charger for 24 hr, plugging
into laptop, and trying to power up with power button and volume up. Red light
sometimes lighting up or flashing but not staying lit.
After playing around with all of the above methods, I
noticed if I kept my finger on power while plugging into the charger or laptop
the red led stayed on until I let go. So I tied an elastic band around the
phone on the power button, then I plugged in the charger, unplugging it,
plugging in again with volume up pressed until I had the red led lit. Not sure
of which combination I did but just when the led was lit (not flashing). I left
it for a few hours while it was plugged in with the elastic band keeping
pressure on the power button. Came back to it and found the phone on and
battery at 100%.
Hope this helps some of you
Mar 29, 2013 | Cell Phones
How to program a woods TD1000 indoor timer
Here's how to set Woods TD1000 timer
This is older timer with backup battery. Plug in timer to see if battery will work. Display shows when battery is charged. No display, then timer is no good.
TD-1000 timer has 8 on-off functions per 24-hour day ...newer timers each offer 7 day function with choices of each-day, week-day, or week-end programming. The wider choices with newer timers may explain why TD1000 instructions are hard to find
Timer has 5 buttons + reset:
TIME MODE PROG HOUR MIN
Set time
Press and hold TIME > use Hour to set hour, Min to set minute
Release Time button ... correct time should show
Program: Capacity for 8 on-off times per day
Press PROG to set first ON time
ON and number 1 are displayed on left
Use hour and minute button to set ON time
Press PROG to confirm
Now, OFF and number 1 are displayed
Use hour and min key to set OFF time
When 8 programs are set, Press MODE key.
Choose Manual OFF. Manual ON, Auto ON, Auto Off
To use programs, select Auto ON
DST daylight savings time has to be done manually.
Press HOUR MIN button simultaneously > timer set up one hour
Repeat again and timer goes back one hour
Do not plug timer into extension cord > must be plugged into wall
Oct 04, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
"Cyber" brand wireless rechargable mouse
Okay i got the same problem i did everything press the big blue botton and the one on the bottom of mouse and still nothing....
ITS THE BATTERYS!!!! the ones that come with it are shiet i put some tranisonic ones into and it worked instantly the moment i put "good" ones in the red light came on instantly
Aug 23, 2008 | Computers & Internet
Setting model number jr3060-59f
1. set mode to CHR with the bezel fully in.
2. pull bezel out 2 notches. This will set all (or most) hands to 12.
3.press A (top button) repeatedly until you get MIN in the left window
4.turn the bezel to move the min hand forward.
4a. turn the bezel several clicks in quick sucession to get the minute hand to continue to move in the forward direction. This will "drag" the 24 hr UTC hour hand froward 1 hour per 1 revolution of the minute hand. if the minute hand stops before you want it to repeat step 4a. continue till the 24 hr UTC hour hand points to 24.
5. to stop the minute hand turn the bezel backwards 1 click. remember however to approach the 12 position with the minute hand in a clockwise direction.
Mar 25, 2008 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
S-750DD
Not sure if this will help... however an altmeter will allow you to test along your electrics for any faults. You can check at the lights for example and throught the system.
Oct 11, 2007 | Transport Schwinn Rechargeable Portable ...
Uniden DWX207 1.9 GHz 1-Line Cordless Expansion Handset Logo
410 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
