Question about Kenmore Elite 45986 Front Load Washer
I recently purchased a home which this washer was included. It has a moldy odor. I cleaned it out under rubber ring but seems to keep coming back. What can I do?
    President:
  • 1,430 Answers
The door seal will need to be replaced. Once the mold sets in deep it will keep reappearing every couple weeks or so. Here is a link that will help with the door seal. It's a different model but a similar procedure would be used. Replacing a door seal
Posted on Nov 05, 2010
Mildew odor in the machine....can't get rid of it and makes clothes STINK!
If you have a smelly front loading clothes washing machine, toss in a Finish Geltabs (the ones that are all liquid) and run the machine on a hot wash cycle, medium to heavy load (to get more water in the tub) with no clothes in the machine. You don't need to use much of a spin cycle so set it on low. The washing machine will come clean and even the moldy spots on the rubber gaskets will disappear. A second treatment may be needed if the smell is not completely gone. We tried everything from vineger to bleach to baking soda to borax to commercially available odor removers from Whirlpool and Tide. Nothing worked until I hit on this idea. It's cheap, easy and can be done anytime your machine needs a refreshing. I used the orange Geltabs but any fragrance would be fine. Keep the door on your washer open a bit when possible to air out to help preclude those nasty smells.
Oct 21, 2012 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
I have the front load washing machine wm2010cw. The washer just has a foul odor and I can not seem to get rid of it. I have tried using Affresh and had a tech come to see what the problem was but all I got...
Aug 23, 2011 | LG Washing Machines
Washer Odors of Mildew
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$$$$
Apr 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Our LG washer has moldy odors
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!&*%#
Jan 28, 2010 | LG WM-2277HW Front Load Washer
LG washing machine has AWFUL mildew smell
Same problem and I was told to only use detergents with "HE" on the front of them for high energy. the soap without HE is too foamy and hence never truly drains out and causes a mildew smell. I also purchased something called "A" Fresh that I run in the washer every 6 weeks to keep the smell out. I got it at an appliance store for about $11.00 for 3 tablets
Sep 04, 2008 | LG WM-2277HW Front Load Washer
Foul odor
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*&^%4
Aug 26, 2008 | Kenmore Elite 45986 Front Load Washer
Model No. 22632
Okay
Seams like this washers has the same problem lets try to fixya. check the
Moldy at the front-loading washing machine these where it is,
look for mold inside the large rubber ring (the seal) at the opening of the washer and it's hard to scrub off, even with bleach.
Try this then used Affresh at list for 2 or 3 weeks,
good luck
Was this helpful?"
Aug 25, 2008 | Kenmore 22622 Top Load Washer
Front load wash smells moldy
A few ideas to try but understand that these will not solve your problem 100%,.. To begin with. make sure you are using HE type detergent and use ONLY a few drops per load..any more than that will just end up damaging the front door hinge hardware and you will have to replace that... As for the mold problem.. that has plagued this type of washer for a while.. to my knowledge.. there is no known cure but you can buy Afresh tablets from ( home depot carries them) .. and run them thru a wash cycle about once a month ( more if necessary) .. they do seem to help a little,...I too have the same washer and have been most disappointed by the degree of problems it has had.. Also.. keeping the door open and wiping the gray gasket ( including the area that where water exits the washer..) may help a little too,...
Hope that helps...
Aug 08, 2008 | LG WM-2277HW Front Load Washer
Moldy smell
Turn it off, unplug it. Remove filter and check if filter and/or filter and pump housing are clogged with something "smelly". When you're at it check the drain pipe for too.
May 08, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
168 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
