Question about Roxio Easy VHS to DVD for PC
I have windows 7 os and the install for the roxio vhs to dvd went fine but when the video is playing on my PC, and I select to record, the following message appears: Can't burn to DVD error HRESULT E_FAIL has been returned from a call to a com component. Thank you for any help that you can offer.
2 Suggested Answers
SOURCE:
SOURCE: Roxio Cine Player Decoder Pack instalation package
Roxio software is an absolute nightmare. Stay clear from it as it completely ruins your computer. Impossible to uninstall.
Posted on Jul 14, 2011
How do you make it work in windows7
I found this on a forum....I hope it helps!
This review is from: VHS To DVD 4.0 Deluxe [OLD VERSION] (CD-ROM)
I needed a way to connect my PS3 to my PC so I can take some screenshots and I only had 2 days to do this so I searched Amazon for VHS to DVD's and this was the one the best rated products. Next I went to Honestech to make sure Honestech VHS to DVD 4.0 Deluxe was compatible with Windows 7, and it was. So I rushed down to my local Fry's Electronics to pick one up, price was about the same so no problem there.
Problem:
Once everything was installed hardware/software/drivers, I ran the Honestech software and after a few minutes of running my PC just locks up. So I rebooted and tried again, but again my PC locked up, now I am confused since they said it was Windows 7 compatible and I did get the latest software from Honestech site. I first thought it was my PC but after some testing I did discover that it was Honestech software that was locking up my PC.
Solution:
OK so here is what I did to make it all work, forget the Honestech software you don't need it. Go to Honestech site and get the drivers for "HT VIDBOX NW03" this is what comes with the Honestech VHS to DVD 4.0 Deluxe. Download and install the drivers and restart, go into Device Manager and make sure you are not getting any device conflict and that everything is installed right. On Windows 7 the only thing I saw that Windows 7 didn't have drivers for was the audio, so installing these drivers fixed that problem. Now Google Virtualdub, it's a free video editing tool, Open Virtualdub go to File and select Capture AVI. Now under Device go select your USB2.0 VIDBOX NW03 (DirectShow), you should now see video coming from your HT VIDBOX NW03 go to File and select Set Capture File, enter the file name you want your video file to be and where you want to save it and hit save. Now go to Capture and hit Capture Video to start recording, and it Capture Video again to stop recording, that's it you are done.
Jan 02, 2015 | Televison & Video
Roxio vhs to dvd not receiving video signal
this is because some VHS players have copy protection. for example some VHS manufactured by disney has copyright protection and is imposible to be compied to a DVD format.
Feb 06, 2012 | Roxio Easy VHS to DVD for PC
I have the roxio easy vhs to dvd program. windows 7 compatible. i have been able to capture and burn satifactorily from my hi8 cam. i am having problems with the vhs capture. no constant video signal. ...
Not compatible or not working well with windows 7?
(make your program/application run with windows 7)
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:))
Sep 26, 2010 | Roxio Easy VHS to DVD for PC
Roxio Easy VHS to DVD will not install
Probably your version does not support your OS. Get the lates version from Roxio.
Jul 14, 2010 | Roxio Easy VHS to DVD for PC
Roxio 9 compatibility with windows 7
Roxio 9, Roxio Creator 9 and Roxio Creator 10 are different animals. Roxio 9 is 3 years old +. It likely will not handle 64bit or Windows 7.
Roxio Creater 9 is not listed as compatible with Windows 7
The following are from the Roxio site:
The following products have been designed to be Window 7 compatible (as of January 2010):
  • Roxio Creator 2010
  • Roxio Creator 2010 Plus
  • Roxio Creator 2010 Special Edition
  • Roxio Creator 2010 PRO
  • Roxio Easy LP to MP3
  • Roxio Burn
  • Roxio CinePlayer BD
The following products have been UPDATED to be Windows 7 compatible (as of January 2010):
  • Roxio Easy VHS to DVD
  • Roxio MyDVD 10 Premier
  • Roxio My DVD Video Lab 10
  • Roxio RecordNow Music Lab 10 Premier
  • Roxio Easy DVD Copy 4 Premier
  • Roxio Easy CD & DVD Burning
  • Roxio BackOnTrack 3 Suite
  • Roxio CinePlayer
Apr 04, 2010 | Roxio Easy Media Creator 9 Suite (227100)...
Remove any older versions of Roxio or Sonic from the computer and do a clean install (uninstall then reinstall).
Mar 30, 2009 | Roxio Easy VHS to DVD for PC
Roxio Easy VHS to DVD install causes PC to hang up.
Do you have any other conflicting software or any other Roxio software? Any other Roxio or Sonic software will cause errors with Easy VHS to DVD.
It's also recommended to download the Service Pack from the Roxio.com site.
Mar 28, 2009 | Roxio Easy VHS to DVD for PC
I have recorded (on to dvd-rw) my old VHS tapes. They won't play on computer
The PC requires a compatible DVD player software! What are you trying to play the DVD with?
Sep 28, 2017 | Hitachi DV-RX5000U DVD Recorder
Roxio Easy VHS to DVD for PC Logo
240 people viewed this question
Top Roxio Computers & Internet Experts
Peter Dragonetti
Thomas F. Schneider
Are you a Roxio Computer and Internet Expert? Answer questions, earn points and help others
