Question about Whirlpool Kitchen Ranges
I have a whirlpool super capacity 465 electric range. I was not living in the house for about 8 months, and when I just moved back in the range doesn't work. The indicator light comes on for the surface coils when I turn one on but the element doesn't heat up. Since it is an older range I went to lowes and bought coils, pigtails and pans to replaced the old ones. Still no working range. I checked the outlet for power and the results-red wire, 125 volts black wire-16 volts Both toether was 16 volts. I was told that the breaker maybe bad. The breaker is a GTE/Sylvania 50/50 2 pole I replaced it with a zinsco model rc38-50 which identical to the old one. still no working range. any suggestions?
  • 2,299 Answers
If the voltage at the plug is still only 125 volts on the black and 16 volts on the red. There is still a problem with the power. And has nothing to do with the stove. You should have 240 volts when you measure from red to black. You can check the power at the breaker to make sure that you have 240 volts on the new breaker. If you have the right voltage there, then you either have a bad connection in the range plug or a broken wire somewhere between the breaker panel and the plug in.
Posted on Nov 05, 2010
I have a whirlpool 465 super capacity stove. the top burners seem to have a mind of their own. 1 in the back doesnt come on at all and the other go to high heat even if i set them on low settings
No solution, just that you are not alone. We have had our Whirlpool super capacity 465 for 10 years, and about a year ago that large burner started to randomly go to high, even though the control is set to simmer. Ruined a few meals by not being right there watching.
Apr 21, 2011 | Whirlpool RBS305PDS Electric Single Oven
Whirlpool Super Capacity 465 Electric. Left Front
there are 3 screws under the front of the top with the oven door open actually there are 6 screws but only 3 you need to remove to raise the glass top up!! to service the burners
Jan 20, 2010 | Whirlpool GR465LXLS Electric Kitchen Range
Whirlpool super capacity 465 - Oven won't light
This is your gas valve that is bad on this unit. Please contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
with your complete model number and we will get the correct part out to you asap.
We are available from 7 AM until 9 PM CST Monday through Saturday.
Nov 10, 2009 | Whirlpool GS460 Gas Kitchen Range
Can't get door back on- 465 super capacity
I use 2 screwdriver handles between the hinges and the cabinet to hold them out. Then slide the door on part way and pull out the screwdrivers. Voila! Hope this helps!
Jun 16, 2009 | Whirlpool GS460 Gas Kitchen Range
Heating elements
I have a Whirlpool super capacity 465, the surface light for the burners comes on, the burners don't heat up, nor does the oven,(the light that says oven is on does not light up). I checked the main circuit breaker, that works. Are there any fuses in the range that would need to be replaced?
Thank-You,maddie
Feb 01, 2009 | Whirlpool GR460 Electric Kitchen Range
Whirlpool 465 super capacity burner not working
I am having a Whirpool 465 gas stove for 8 years with 3 top burners do not work - burn but with very low flame. Please provide suggestion to repair - remove the burners and replace them?
May 02, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Whirlpool Accubake oven super capacity series 465
Press and hold the Broil button for 5 seconds. You will see the c change to f. THen change the temp to what you need.
Dec 21, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Kitchen Ranges Logo
78 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
