Question about Thomson LCDB 03B 27 in. Television
I have TCL T-21E16 with M28I X. chassis. My factory settings gone. Can any body help me to reset the value? sohel_hie@hotmail.com
I did a factory reset of my tcl roku 42" tv and all tiles were removed. How do i get them back?
When you do a factory reset it eliminates everything and restores unit to the way it came out the box.
You need to go through the set up procedure from scratch with passwords, etc so unit will then download the tiles from your roku account. Check under the settings section to see if you have a listing there for resetting up. If not contact support at TCL and they will tell you what to do.
Aug 30, 2015 | Televison & Video
Hie!i have an LG plasma TV 50 Inch when i switch it on it displays someting like japanis language then if i prees any button it displays Ext what can cause this please can you help
Try a reset to this set, and check. There are two types of reset to TVs. The first is simple to do; a Hard Reset; and the other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Jan 19, 2015 | LG Televison & Video
REQUIRE DETAILS FOR C806 TCL TV 21K77
try this web site for schematic with location & part values
http://www.eserviceinfo.com/index.php?what=search2&searchstring=tcl+21k77+crt+tv
if you can read the value & voltage rating of the cap this would be helpful for finding a part locally
May 03, 2014 | Televison & Video
Hotmail problem
Sign out of her account by clicking her avatar in the upper-right then clicking "Sign out." You can then sign in on your account.
Jan 27, 2014 | hotmail.com
How to hard reset or format samsung SGH-A777 since my screen has gone white and i cant see anything :(
To reset the handset, to the factory default settings, follow the steps below:
  1. While in standby mode, press the right soft key for Menu
  2. Select Settings (9)
  3. Select Reset Settings (8)
  4. Highlight, using the navigation keys, any of the following:
    • All: Sound Profile, Display, Phone, Alarm and Bluetooth settings will be returned to default values
    • Sound Profile Settings: Only sound profile settings will be returned to default values
    • Display Settings: Only display settings will be returned to default values
    • Phone Settings: Only phone settings will be returned to default values
    • Alarms: Only alarm settings will be returned to default values
    • Bluetooth: Only Bluetooth settings will be returned to default values
  5. Press the a737%20center%20key%5b2%5d.jpg key to check the box(es) of the desired Reset Settings
  6. Press the left soft key for OK to set the Reset
  7. Enter the password, using the keypad, default password is "0000"
  8. Press the left soft key for OK
  9. If prompted, Enter the password again to confirm, using the keypad
  10. Press the left soft key for OK
  11. Press the left soft key for Yes to reset the handset's settings to the factory defaults
Jun 03, 2011 | Cell Phones
MY PHONE IS LOCK AND I CANNOT UNLOCK IT. WHAT CAN I DO?
Check out this link below to download a PDF manual, software, and more for your phone. Just copy and paste into your browser.
http://www.samsung.com/us/consumer/mobile/mobile-phones/t-mobile-phones/SGH-T929ZKATMB/index.idx?pagetype=prd_detail&tab=support
Page 165 from your manual:
Reset Settings
From this menu you can reset your phone and sound settings to the default settings or perform a Master reset.
Reset settings
1. From Idle mode, touch Menu ➔ Settings ➔Reset settings ➔Reset settings.
2. Touch the check box next to each of the following that you want to reset
• All: Phone, Display, and Sound settings are returned to default values.
• Sound profiles: only sound settings are returned to default values.
• Display settings: only display settings are returned to default values.
• Phone settings: only phone settings are returned to default values.
3. Touch Reset.
Master reset
From this menu you can reset your phone and sound settings to the factory default settings.
1. From Idle mode, touch Menu ➔ Settings ➔ Reset settings.
2. Touch Master reset, enter your password, then select Yes to confirm.
The phone resets to the factory default settings automatically and when finished displays the Main menu.
Hope this helps, let me know if I can do anything else for you.
JimmyC
Oct 13, 2009 | Samsung Memoir SGH-T929 Cell Phone
I have errors for phzjrd 01.dll and TCL.dll. I
As ffor the first error. are you sure the file name is correct. for the secont error try this link
http://www.dll-files.com/dllindex/dll-files.shtml?tcl
May 15, 2009 | HP Computers & Internet
Akai PT5250A - I cannot converge correctly.
this fixed this problem
Plugs on the chassis coming from keyboard and side video input are switched (they have same plug)
redoo convergence save and auto focus in factory mode after switching plugs
Jan 13, 2009 | Akai PT5250A Television
Codes for TCL TV on the Chunghop universal remote
most universal remote would work like this... press butons tv and power on at same time till red light of remote lights still. then press 110. then presto, it works... i hope i help in a way.
Jan 30, 2008 | Universal Remote Control Remote Control
Thomson LCDB 03B 27 in. Television Logo
78 people viewed this question
Top Thomson Televison & Video Experts
 Grubhead
Grubhead
Are you a Thomson Televison and Video Expert? Answer questions, earn points and help others
