Question about Gateway 506GR PC Desktop
No beeps at all. Fan and HD sound like it is booting, but cannot enter bios and get absolutely no video. Monitor says "no signal". All cables firmly in place. Monitor works with other boxes.
  • 3 more comments
  • bharloff Nov 05, 2010
    Video is integrated into motherboard, but I tried a PCI video card anyway and got same results.
    Any oither ideas? I am not a novice.
    Add-on video card installed but still no video. I get no POST beeps, no hard drive noise or activity lights, but power light is on the motherboard. I changed out the power supply as well. Nothing helped. All drivers up to date (Win XP Home, SP3. Has been working up until this AM when a reboot was required because of an update. Never had video since.
    Computer was rebooted this morning after an update. Video never came back on. I installed an add-on video card, but still no results.
    I get no POST beeps, cannot enter BIOS, do not hear hard drive initializing. Changed the power supply, but got nothing. First expert was no help. I am not a novice. It appears that the motherboard or processor may be bad.
    I already did all of that and determined that the motherboard is bad.
    Thanks! I had suspected that but was looking for confirmation.
  • 656 Answers
Remove your cpu cabin remove the processor fan and the processor wipe the surface with a clean cloth also the processor fan apply a layer of heat sink solvent and insert the processor in to its socket then place the heat sink firmly to the socket remove all add on card remove the power to HDD CD drive the memory etc now restart the computer if you hear beeps then clean the memory prints with an eraser dont clean it with metal or rough metals it may damage the circuit if still you cant see display fix a add on VGA card to the slot and switch on the CPU if there is display the problem is with your display section in the motherboard if you dont hear any beeps while the memory is not inserted remove your cpu and change the CPU with your friend that is suitable to your socket and restart if you hear beeps you have problem with Ur processor if you still have problem there is problem with *********** board
Posted on Nov 06, 2010
  • rajesh raman
    rajesh raman Nov 07, 2010
    if so check the 4 pin atx connector connected properly to the motherboard if you have base in electronics check the FET s in the power supply section any FET damaged wont power up the processor check them with multimeter
  • Gateway Master
  • 13,433 Answers
Hey,
lets start real troubleshooting.
Take the computer to a bench, remove all the cables from the motherboard, only keep connected the needed devices such as Cpu, ram and powersupply.
Disconnect all hard drives etc.
Connect the computer to display and plug in the power, turn it on, noting on the screen?
Power off, remove all the ram from the computer, plug it back in, now you should be getting beeps, let it beep for a moment, unplug, Reconnect 1 ram module, plug in and power on.
Anything on the screen yet?
Posted on Nov 05, 2010
  • Ekse Nov 05, 2010
    either that or the cpu then. Thanks for visiting, bye. You will not be charged for anything.
  • 340 Answers
Sounds like your video card needs to be replaced. If your Gateway is still under warranty you can get a replacement at no charge. If its not under warranty you can purchase one at a computer shop in your area. You may want to contact Gateway to see if your system is under warranty
www.gateway.com/support
  • Lori Langley Nov 05, 2010
    Your drivers are all up to date, correct?
    Here is what I found..
    No Video on a 500 Series or E-4000 Computer
    Affected Products: Desktops
    Affected Operating Systems: Not OS Dependent
    ISSUE: After connecting the VGA cable to the monitor and powering the computer on, there is no video and only the Monitor Self Test information appears. The light on the monitor eventually turns amber because there is no VGA signal. This may happen on a new computer or it can happen to a computer just returned from service. For this specific issue, the configuration of the computer must have an add-in video card.
    RESOLUTION: Connect the VGA cable to the VGA port on the add-in video card.
    On-Screen Display
    Show Part Numbers
    This high-definition display features an on-screen display (OSD) that lets you adjust contrast, brightness, and other settings. The changes you make to the settings are saved even if you turn off the display.
    The display has two levels of menus, and the functionality of the touch buttons depends on which menu is currently open.
    • Use the VGA shortcut menu to quickly change some of the most commonly accessed settings.
    • Use the VGA main menu to precisely adjust all levels of settings.
    The OSD options and settings can vary depending on what type of cable connection (input source) is used. When your computer is first turned on, the input source, VGA, DVI, or HDMI, is detected and displayed for several seconds. If no signal is present the No Signal message is displayed.
    Click the following links to view OSD options and screens for each input type.
I have a Inspiron 530... The monitor reads "NO
Hello
You may try another graphic card, it is quite possible the card may not compatible with board, also push the RAM stick to place them properly may the RAM gone dislocated.
Hope it helps
Dec 30, 2010 | Dell desktop and monitor- Inspiron 530...
After power on my eMachines C6537, there is no beep sound and nothing shown on screen. The CPU fan and fan in the box are working. The HD drive spin sounds normal. No problem to open doors of DVD and CD...
Disconnect the power cable open the case and pull the CR 2032 battery out for a minute. That will reset the BIOS. If you have no Beep Codes at all the MoBo might be dead. If this were just a video issue there'd be Beep codes. If there's more than one stick of RAM Pull one try to boot then do same with second stick. if there's only one stick of RAM try reseating it.
Jun 27, 2017 | eMachines C6537 PC Desktop
E-machine t6212 won't boot. I actually have two e-machines that are not sending a signal to the monitor. One is a t6212. It is booting up because I can shut it down using the windows key + up arrow +...
If you get only one BEEP at boot then the computer is working..
Do you have a 2nd monitor to test with?
if it BEEPS more then once...
pull out your mem chips and test,,
If itt works them one of the mem chips are bad if not..
pull out all pci cards and test.. if it works its a bad card...
if not unplug all HD and CD roms and test.......
If not fixed yet it maybe a onboard video problem...
But IF you put a video card in b4 the problem started then your bios may have auto set it sellf to PCI/AGP mode.
Check bios setings,, look for onbord setings for the video
Feb 21, 2010 | E-Machines T6212 PC Desktop
Desktop will not boot into bios No Usb power;monitor ''No Signal''
Your problem is the memory . YOu have to put off the pc and remove the memory card in the slot. Then clean the silver pins in your memory with a rubber eraser. Put it back and see if the BIOS will be prompted on the screen , if not you have to replace the memory.
Feb 12, 2010 | Acer Aspire T160 (AST160UA3400) PC Desktop
HP Pavilion ZX8000 in constant reboot cycle
If you start tapping F8 after you turn the machine on, will it give you a boot preference? If so, boot to safe mode, then take the computer back in time.
Mar 17, 2009 | HP Pavilion zd8000 Notebook
661FX-M7 Problems
The fan running at 100% may be fine, depending on how you hooked it up. However, you seem to have a conflict with the video. The short beep you hear is usually the motherboard recognizing the boot drive. The long beep means something isn't configured correctly possibly the video card...?
Look in the owners manual for the keystroke to get into the bios settings. Then right when you turn it on, before the long beep, hit that keystroke and get into the bios and check settings.
NOTE: if you don't get any video when you enter the bios, there is clearly a compatibility issue with your video. All video cards should put out signal for the bios - even if the proper drivers aren't loaded for Windows.
Nov 03, 2008 | EliteGroup 661FX-M7 (661FXM7V11)...
No display at post
There are a few things that can cause no display on the monitor.
That single beep means POST = Power On Self Test. Post has tested everything on you're board to be good.
The cable between video card & monitor may be bad or not connected correctly (Swap out the cable as last resort).
2. You're monitor is defective, try swapping it with known working monitor.
3. You're video card is not functioning.
Lastly, when you reset the system cmos/bios everything went back to default. This means you're bios is now using the onboard PCI video graphics. Remove you're radeon 9600 video card. Try booting the system. You should see display again. The only way to test you're radeon would be to boot to the bios & set bios to boot using the AGP radeon. You need to change Init Display First to AGP & not PCI. If you loose video than you know you're AGP card is bad. Reset the cmos/bios before adding another AGP card or you will not get display. This setting is on pg 3-5. Integrated Peripherals. If you need you're manual you can download it from this link: http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=NF7-S2G&fMTYPE=Socket+A
Good Luck!
Mike
Jun 06, 2008 | Power Color RADEON 9600 (128 MB) Graphic...
Boot up problems
The beeps can be either video or memory. Most likely it is memory. Check the memory.
Thanks,
Lolita
Apr 09, 2008 | Mach Speed P4M800 (890552603480)...
Monitor not getting signal
Check your cables.
If the cables are fine then there is something
wrong with your comuter.
Do you hear any beeping sounds?
Mar 07, 2008 | HP Compaq d530 SFF PC Desktop
Gateway 506GR PC Desktop Logo
125 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Steve Allison
Steve Allison
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
