Question about Sharp Office Equipment & Supplies
Error code H 4 on Sharp AL 1041 copier - Sharp Office Equipment & Supplies
    Problem Solver:
  • 9 Answers
Hi , the problem is with the fuser unit in the machine but it may be possible to reset.Try this : enter buttons "clear" , "exposure" , "clear" , "exposure" ( in that sequence ) the display will then blink. Enter numbers 1,4 and then press "print" button , followed by the "clear" button several times to get out. power off/on machine from main switch and problem should reset so long as heating element within fuser is not blown. hope this helps.
John
Posted on Jun 14, 2008
  • 134 Answers
H4 is a fuser error. It sometimes can be cleared out. But sometimes it is the fuser lamp or one of the heat sensors.
Try to clear the error in service mode by hitting. clear, auto(exposure), clear, auto. The display will go blank, enter 14 and hit start key, turn power off/on, if problem is gone then you overheated, if not then you need a tech. Good luck.
What does an L6 error code on Sharp AL-1041 Digital Laser Copier mean?
Polygon mirror motor problem. Call or take the copier to your local dealer for repairs
Apr 14, 2017 | Sharp Office Equipment & Supplies
Sharp AL-1041 Printer/ Copier will not power on
make sure you are not plugged in to an outlet controlled by a wall switch. Bypass any power strips.
Aug 07, 2012 | Sharp AL-1041 Laser Printer
Error code H 4 Sharp model AL 1540CS
This is a critical issue which needs constant monitoring of the device and continuous chat / email exchange.
Thus it is advised to please avail paid fixya services for better support and quick solution.
Thanks
Oct 24, 2011 | Sharp AL-1540CS All-In-One Laser Printer
Flashing L then 6
Hello
The error L6 has to do with the lazer unit.
The lock signal[specified rpm signal] does not return within a certain time[about 20 seconds] from starting the polygon motor rotation.
Unfortunately in my experience the lazer unit needs to be replaced. There is no quick fix to this error. (to my knowledge)
Regards
Apr 18, 2011 | Sharp AL 1041 Grayscale Copier
Meaning H 4 appear alternative Sharp Al-1641 CS
H4 is nothing but an error code that appears due to power fluctation(in absence of a stabilizer). You please enter # interrupt-C interrupt -14-start to clear to clear the error
Jan 12, 2011 | Sharp AL-1641CS Laser Digital Copier
Sharp al 1631 copier has a H 4 code on I reset it and it seams to work but for how long will it last
A H-4 error code means that there is aproblem with the fuser unit. It could be that the thermister is dirty and not reading the correct temp. of the upper fuser roller. How long will it last for? Your guess is as good as mine... There are to many things that may cause it to fail... Good Luck
Jul 23, 2010 | Sharp AL 1631 Copier
H 4 code flashing
The H4 code indicates the fuser may have blown the thermistor. It also could be a false error code. Try this series to clear the error and if it returns, then you'll know for sure the fuser is the culprit. To reset press the following buttons:
  1. Press this sequence: CLR-Exposure-CLR-Exposure
  2. The display will go blank
  3. enter "14", press "PRNT"
  4. Press "CLR" several times to exit.
Give that a try and good luck.
Feb 18, 2010 | Sharp AL 1631 Copier
Sharp AL- 1540cs
On my SHARP AL-1540CS printer 4 and H blinks alternately and none of the buttons except power is working.
Oct 19, 2007 | Sharp AL 1215 Black and White Copier
176 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
