Question about Samsung WF203ANW Front Load Washer
There is an E1 on the screen. what does it mean?
    President:
  • 1,430 Answers
* Generated Frequency Signal of WATER LEVEL (WIL) SIW (KHz)
Normal Level = Abnormal W/L Frequency
Low Level = 30.00 Khz
High Level = 15.00 Khz
If the same signal is detected for more than 5 seconds, it is a PRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 min. and the display will show 1 E indicating a pressure switch error.
Check the hose to the pressure switch for clogs, holes or a loose fit. Blow thru the hose to be sure it is clear. If all looks good replace the pressure switch.
Posted on Nov 05, 2010
What does E1 mean on power pressure cooker xl
E1 means there is an open circuit on the pressure sensor. There are not any repair instructions so its broke, if your unit is still in warranty, take it back to the store you purchased it.
Jun 17, 2016 | Crock Pots & Slow Cookers
What does E1 mean
E1 flashing means that the product's firmware/software needs to be flashed or repaired again in order to function properly, this generally occurs due to inadequate voltage supply or sudden power failure of the Oven.
Mar 19, 2015 | Ovens
Air conditioner rv fault code E1,how to clear?
youll have to look up the manual to see what E1 means.could need filters cleaning.lift up lid and slide out the filter screens
Sep 02, 2014 | Heating & Cooling
What does E1 mean in tadiran 250 R, it works then stops and screen shows E1 when it operates as a heater
h Air Conditioners
Nov 24, 2012 | Heating & Cooling
What does error code #e1 mean on Canon CLBP 460 PS mean?
Meaning of error code E1
The motor sensor or sensors, the DC controller on the main board DC controller.
I can not give solution to your problem, because possibility of damage main board.
I suggest you contact Canon Customer Support (e-mail, telephone, or repair contacts).
Nov 16, 2011 | Canon CLBP 460 PS Laser Printer
What does E1 on the screen mean? t happens when trying to check blood pressure.
The E1 Error symbol indicates an air circuit abnormality. Try measuring again.
If it continues contact HoMedics Customer Support 1-800-466-3342.
Hope this helped you and thanks for choosing FixYa.
Aug 19, 2011 | Homedics Automatic Arm Blood Pressure...
It run just in one speed and error message E1 on screen it.s a darby Silhouette DDR583R
Well E1 error code means dump water jacket. clean evap filter and check again.......
Good Luck!!
Thanks for using FixYa!!
Sep 10, 2010 | Dryers
Error E1 mean?
An E1 error message usually indicates that the thermistor (see the following link) is defective and needs to be replaced.
http://www.appliance411.com/data.php?rc=548392
pls rate my suggestion...
Jun 26, 2009 | Whirlpool Washing Machines
I keep getting the error "E1" & the dryer turns off ...what does that mean?
I've read in other forums that E1 means the thermistor has failed. As far as I understand, it monitors the temperature of the air that is leaving the dryer and entering the dryer vent. If you're not handy, a service call is in order.
Mar 24, 2008 | Kenmore Elite HE4 Electric Dryer
Samsung WF203ANW Front Load Washer Logo
102 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
