Question about HP LaserJet P4015N Printer
After firmware upgrade the HP 4015x will not boot up with the duplex unit installed. Boots up ok without the duplex. We even reapplied the firmware upgrade.
I had the same problem. HP Pro Support advised me to
deinstall the additional paper tray and the toner.
and reapply the firmware update 3 times.
It sounded stupid to me but it worked!!!
Be sure to use usb connection and wait 30 min between progress.
1 st time - no paper tray, toner, wait 30 minutes
2 nd time - no paper tray, wait 30 minutes,
3 rd time - all together now, wait 30 minutes
I hope this will help you and others,
Arthur
Posted on Nov 30, 2010
I have a hp laserjet 4240n and we installed the duplexer. But it gives error 49.2 F05 and also a jam error 13.12. Does anyone know the solution?
49.2c05 is a communication error. the 13.12 is a jam error. try upgrading the firmware with the duplexer not installed. firmware can be found at www.hp.com
Nov 21, 2016 | HP Office Equipment & Supplies
How do i fix RFU LOAD ERROR
RFU is a remote firmware upgrade. Usually that error will occur when somebody messes with the printer while the firmware is downloading. Try doing the upgrade again. If it works great. But personally, I don't think that it will work. You probably have to replace the formatter. C9661-69002 for a duplex model. and C9660-69011 for the simplex(non-duplex)printer.
Mar 17, 2016 | HP Color LaserJet 5500 Printer
Garmin 1340T boot loop issue. The unit
Unfortunately, there isn't an easy solution for the Nuvi owner as it requires a custom piece of firmware to flash the unit to make it at least boot. This problem is often caused during a failed firmware and/or map update.
It sounds like a file was corrupted. Sometimes it is better to connect the unit up to a PC, delete the old map and then proceed to install the new one. There are so many issues with memory space causing failed downloads and corrupted files.
If the map file is missing, the unit will boot-up OK, it will just say "Map data unavailable" but if the map file or associated map files are corrupted, it can cause the unit to crash. Your PC won't recognize the Nuvi because you have the reach the main screen before the data communication mode routines are accessed.
We've had some success in restoring some of these units by flashing a "fix" firmware in "pre-boot mode" that doesn't try to load the map or map associated files. This should then allow the unit to boot. Once the unit boots, Windows will recognize it and then you can copy a map over to it from the PC. Reboot the unit and then flash it with the standard firmware.
- Jim
Feb 23, 2012 | GPS
I try update Firmware for Hp 4015n, but unsusscess. Now LCD display 6/6 A/F. pls, help me
I had the same problem with a 4015x. HP Support advised me to deinstall the additional paper tray and the toner and reapply the firmware update 3 times.
Make sure to use usb connection and wait 30 min between progress.
Arthur
Oct 12, 2010 | HP LaserJet P4015N Printer
We recently upgraded our server to windows 2007 from 2003. I was able to duplex print on my laserjet 4600dn before, but now the properties menu has changed and the duplex unit option under device settings...
Make sure the printer and driver indicate HP 4600 and not 4650. I have seen these 2 get confused before and the 4650 does not have a duplex option.
Sep 14, 2010 | HP LaserJet 4600 Printer
Have a network hp 4015x printer and for the life of me I can't stop it from wanting to print to tray one. I have installed the lastest firmware and driver from HP. Any ideas?
unless in your printer preferences it's set to tray 1 -(manual feed), the problem could be that a clip or something is broken in tray 2 - seen that many times.
Jun 14, 2010 | HP LaserJet P4015 Printer
HP 520 Notebook. Shuts down before installing new OS.
I agree a clean install is always the better, fresh start J
OK it sounds like missing drivers, what you have to do is create a new installation CD that will load the drivers for your laptop as it boots. I haven’t try this method with windows 7, but I know it works well with Windows XP. Try and create a new Windows XP CD with the drivers see: http://unattended.msfn.org/unattended.xp/view/web/35/
The start a new installation with this Windows XP CD and reformat you computer, after that you can do a new upgrade to windows 7
Nov 25, 2009 | Office Equipment & Supplies
BIOS self-set Password after upgrade/HD Install
http://sodoityourself.com/hacking-ibm-thinkpad-bios-password/
try this if you can do  but i am not sure.  i am good on electronic things but its hard to do that. its only way.
May 28, 2009 | IBM ThinkPad T43 Notebook
LYRA X3030 FIRMWARE UPGRADE RENDERED UNIT USELESS
I had a problem getting mine to boot but got it working by removing battery and removing AC, then pressing power button. Then plugged in AC and pressed power again. It boots. Then replace battery and cover.
As far as manuals, the official site is below. I'd download a new firmware upgrade and install is from another computer. Sometimes the computer downloading and running an install is
compromised and the virus scanner is not aware downloads are getting damaged upon arrival to your local hard drive.
http://support.rcaaudiovideo.com/manual.aspx?product=203
Nov 27, 2007 | Electronics - Others
HP LaserJet P4015N Printer Logo
685 people viewed this question
Seeker5211
Seeker5211
