Question about Eljer Toilet Onepiece Canterbury 081162047
I have a eljer one piece low flow toilet. I have a valve problem and the water keeps running. I am usinf a 1.9 flush valve replacement from Home Depot. It has worked in the past but now it won't.?????
  • 21 Answers
Replace with power flush tank insert
Posted on Nov 06, 2010
A small intermittent water leak in the flapper flush valve unit which also causes "water hammer" in the copper piping in the basement. New flapper valves did not solve the problem Sanding...
Older Eljer toilets are good for this and yes you need to replace the complete flush valve assembly. I would recommend putting in a fluid master system as they in my opinion are the best. Their kits come complete with everything you need to do the job and provide excellent instructions and if that is not good they have videos on their web site. The site is slow to load but worth waiting for.
http://www.fluidmaster.com/
Mar 08, 2011 | Eljer Home
Occasionally after flushing ,water continues to trickle slightly in toilet bowl. Have changed flapper twice. Wondering if the seat that the flapper sits on is worn or something. It looks ok. Have a one...
Make sure the flush valve is closing properly and that the water level is not set too high causing water to enter the overflow tube. If the flapper seat is damaged and cannot just be be cleaned, you can add a new seat right over the old one. Fluidmaster sells them for just a few dollars. Most hardware stores have them - Home Depot and Lowes stock them.
Feb 27, 2011 | Eljer Toilet Onepiece Canterbury ...
The flow of water into the bowl does not stop after the toilet is flushed.
This usually indicates one of two things: (1) a poorly seated flush valve ball, which can be easily adjustedor replaced, or (2) a flush handle chain that is too long and is getting caught between the flush valve ball and the seat, which is easily remedied by shortening the chain between the flush handle and the flush ball.
One other possibilty is that the fill valve is not shutting off the bowl wash function. There is a small adjustment screw for regulating the flow.
Nov 23, 2010 | Eljer Home
Hello.I live in an older mobile home. We just moved it on the property this past september. Our problem is our toilets rarely fill so that we can flush them. We usually have to fill a bucket with water and...
you have debris in the flush valves. if they are older toilets, I would replace the flush valves. you can get the eljer fill valves from your local plumbing wholesaler.
Aug 07, 2010 | Eljer Toilet Onepiece Canterbury ...
On my eljer toilet, I get continuous running of the water. If I shut valve off and pump the tank, the running stops (but only for a week or so). Suggestions? model 150-403 power flush pf/2
I don't know what you mean by "pumping" the tank. If the toilet runs, then either the fill valve is defective or the seal on the flush valve is defective. First, check to see that when you move the float, the toilet stops running. If it does not, then replace the fill valve. If it does, then inspect/replace the seal on the flush mechanism at the bottom of the tank. If this seal is bad, you can usually see water continuously flowing (slowly) into the bowl. You will see ripples on the surface of the water in the bowl.
Jun 01, 2010 | Eljer Home
My Eljer toilet does not always flush completely. It is approximately 20 years old. I don't believe that it is a venting problem. I have dismounted, inspected and remounted the toilet and found nothing...
Not being a plumber by trade I don't want to bad mouth what your plumber had to say but there may be other things to consider.
If the toilet does not flush directly into the main drain there is the possibilty that the coupling between the main drain and the toilet drain is under-sized which could cause reduced water flow and your toilet not flushing completely.
Feb 26, 2010 | Eljer & Elongated Toilet Bowl
Eljer Canterbury one piece remove flush valve
I had the same problem and contacted Eljer and they sent me the above instructions to make a tool to remove the flush valve.
Sep 09, 2009 | Eljer Toilet Onepiece Canterbury ...
Slow water leak past flapper seal.
Replace flapper, it is worn out.Turn off water valve. Flush toilet, remove flapper. Then replace flapper, adjust chain to same size as old one, then turn water back on.
Aug 19, 2009 | Eljer Toilet Onepiece Canterbury ...
The water continue to run for a long time
You are probably going to have to replace the fill valve.
There is a chance that adjusting it may work, but it has most likely become worn and partially clogged with hard watrer deposits, dirt, etc.
This will cause it to fill slower, and cause the fill level valve to close slower resulting in higher water level. Eventually it would simply overflow the flush valve tube.
Try adjusting the fill level, but plan on the likelyhood of replacing the fill valve.
Jan 21, 2009 | Eljer Aqua-Saver 12" Two-Piece...
No back flush pressure
increase the tank water level half inch at a time till you have the back flush pressure.
seems like the water in the bowl is too low to create any wirlpool.
Oct 30, 2008 | Eljer Aqua-Saver 12" Two-Piece...
Eljer Toilet  Onepiece  Canterbury  081162047 Logo
514 people viewed this question
Top Eljer Home Experts
john h
Mike
Donni Steen
Are you an Eljer Home Expert? Answer questions, earn points and help others
