Question about GE JVM1630 Microwave Oven
Loud humming Two seconds after starting a cooking cycle the microwave begins to hum louder than usual, it seems to be getting louder. I have check the mounting to make sure it is tight. What other options do I have?
  • Anonymous Oct 06, 2008
    I have the same loud humm problem and the unit does not heat anymore. I believe it is the magnetron.
    I want to replace the magnetron myself, is it an easy repair? Does anyone have instructions (or an online link to them) for taking the unit apart so that I can do it myself?
    Problem Solver:
  • 15 Answers
Ouch. Magnetron check performed with multi meter.
1) Disconnect power to unit
2)Allow to stand for minimum 5minutes
3)Remove cover
4)Find large insulted screwdriver
5)short terminals of capacitor to dissapate charge. (If no pop or crackle its possbly already bled through resistor.
Right. Magnetron check both terminals for short to casing if shorted, replace. Check reading between terminals low resistance or direct short is not a problem. Open circuit, replace.
For non heating, this is usually barrel fuse, typically HV 5Kv or more, faults in an overcurrent situation.
Check the capacitor for shorts to casing, a short will indicate a failure. Check the diode in the capactior if fitted by reverese continuity check accross the terminals. MUST DISCHARGE FIRST, else you'll blow the meter up and likely recieve a SEVERE burn.
The most common cause would have to be a problem with the capacitor next the transformer for loud humming. Three basic checks for the transformer.
Probe the low voltage side first, open circuit? replace. a low reading is normal, high voltage side is a two part process, take a reading between the two terminals one goes to the magnetron the second to the capacitor directly. this should be approx the same reading as the LV coil. The last and most important coil is to check the coil side ofthe barrel fuse to ground, this will measure between 80 - 150 on a digital meter, around 90 to 100 for a 900w is in the normal range.
Loud humming is created primarily by having a working transformer with no wher to send the voltage out.
It will only be one or more of these three items, which will cause this, the rest is safety and control gear.
Posted on Dec 10, 2008
I have a "continuous" humming sounding when units are heating. The sound is very loud
The humming sound that occurs may be similar to the annoying buzzing my GE microwave produces at random. It could be mechanical vibration. Doesn't seem to affect cooking.
Nov 16, 2016 | Microwave Ovens
GE microwave JE1660WB001 does not heat makes humming sound
The magnetron has gone and is the heart of the microwave oven, this part is the most expensive to replace, cheaper to buy new in the long run.
Apr 19, 2012 | GE JE1660 Microwave Oven
My microwave made a loud "pop"and now hums loudly
Since the microwave is humming, that tells me that the diode is bad and needs to be replaced.
Feb 04, 2011 | Whirlpool MH3184XP Microwave Oven
When you start the microwave it starts normally with a low hum, then a couple of seconds into it the hum gets louder. After the cook time has expired the food is still frozen. Is there something I can do...
Replace the magnetron by the sounds of it. The hum gets louder a second or so into "Cooking", that would comply with the magnetron heaters coming on and working into a dead magnetron. It could be capacitor or diode of course.
Dec 27, 2010 | GE JVM1540SMSS Microwave Oven
...have Danby 1.0 cu. ft.
When talking about "Power Level", there is a misconception that the cooking power is being adjusted. This is not the case. The user is actually adjusting the duty cycle of the Magnetron. For instance at 30%, the Magnetron will be turned on for 20 sec. and off for 40 sec. A loud 60 cycle hum is usually caused by a shorted Magnetron. Thus the unit is not economically repairable.
Sep 30, 2017 | Danby Microwave Ovens
Whirlpool Microwave
I would suspect the high-voltage transformer in this case, but the capacitor may be failing.
The high voltage section uses and generates voltages that can be instantly lethal.
So I don't recommend that anyone work in this area unless he has either a lot of experience or at the minimum, a good understanding of the safety issues and procedures involved.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Also, there should also be a very helpful "mini-manual" hidden inside the unit behind the control panel. It's very helpful when troubleshooting.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Here are some links you or a friend can use for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
We're happy to help and we appreciate your thoughtful rating of our answer.
Feb 02, 2008 | Microwave Ovens
Makes a loud humming noise while operating
Almost certainly, the component called the "magnetron" has died. This is the valve (tube in the US) which actually generates the microwaves. The loud humming is the transformer that supplies the magnetron being overloaded and/or the magnetron itself. If the rest of the appliance is OK and not too old, the magnetron can be replaced. If you aren't familiar with these appliances, you *must* get this done by someone who understands the dangers of messing with them - if you get it wrong, they can bite! In some countries, only qualified engineers can buy the spare parts. In the UK, the part costs around £40 - £80, depending on the model. If the appliance is more than around three years old, it may be a false economy to repair it as other parts may fail soon after the repair.
Sep 24, 2007 | Whirlpool MT1110SKQ 1100 Watts Microwave...
Maytag Rangehood Microwave Loud Humming
Sounds like you just fried your magnetron. Normally when they go bad, they make a very loud noise like what you described. The smell concerns me because you may have ruined the waveguide as well. If the magnetron burns through the protective painted surface of the waveguide, the waveguide is ruined. In most microwave ovens this means replacing the entire unit because the waveguide is not replaceable. Putting a new magnetron in a damaged waveguide will result in the same arcing and eventual failure. In addition to the magnetron, the following components are part of the same high voltage network: HV Transformer HV Diode HV Capacitor Magnetron Thermal Cut-Out Any one of these components could have also been damaged. I DO NOT recommend taking any voltage measurements inside the HV network. Potentials of over 4000 volts can be reached and make it very dangerous for the do-it-yourselfer. Taking resistance readings with the unit unplugged is strongly encouraged. If you decide to pursue a repair, inspect the magnetron tip and inside of the waveguide first. If the magnetron is melted and/or there are burn marks inside the waveguide, a new microwave may be a in order. This actually may be a better option than an expensive repair. I hope you find this advice helpful.
Jul 31, 2007 | Whirlpool GH4155XP Microwave Oven
Constant Humm / Buzz but Works OK
I was going to suggest the low voltage transformer, but when you said it sounded like it was coming from the left side, that seemed odd. I have a stock transformer here I keep for test that is loud, but it works. Odd, eh?
Dec 21, 2006 | KitchenAid KHMS155LSS 1000 Watts Microwave...
GE JVM1630 Microwave Oven Logo
114 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
