Question about Hitachi SuperScan 776 Monitor
Hello, I am having some problems getting my question answered. I have a Hitachi SuperScan 776 CRT monitor. I would like the display on this monitor to have a vertical refresh rate of 100Hz. Currently, my computer (running Windows XP SP3) just recognizes my monitor as "Plug and Play" and I am maxing out at an 85Hz vertical refresh rate. I was told that if I could get my computer to recognize the actual monitor (by installing the driver(s) for the monitor), then I could achieve this higher refresh rate.
4 Suggested Answers
  • 36 Answers
SOURCE: syncmaster 710N resolution problem
no,
the LCD display don't harm the eyes cause don't spreed radiation.
preferred resolution 1280x1024 at refresh rate of 60Hz is not optimal.
the samsung 710N can easy handle 75Hz at 1280x1024 so just change it.
Posted on Apr 14, 2009
  • 109 Answers
SOURCE: Too much screen flickering @ 1024x768 (60hz)
setup your monitor driver supplied with the monitor, you will get more options. Thanks
Posted on Oct 29, 2009
  • 2567 Answers
SOURCE: I need a driver for
What is your operating system?
Posted on Nov 04, 2010
Why does Image on tv screen sags in top left
buy a new monitor its a problem with the photon beam
May 08, 2010 | Hitachi SuperScan Elite 802 21" CRT...
Took it apart, reassembled, stopped working. Hitachi superscan elite 751
All fixed. Discovered 3 setting screws. 2 for focus, one for picture. Monitor must be running with plastic casing removed to access set screws and adjust till perfect.
Jan 28, 2010 | Computers & Internet
Need a driver for superscan pro 800
the monitor doesn't need a driver, you are most likely missing display adapter drivers from your computer or can you explain why do you need a driver for your monitor? I've never installed drivers for my monitors in the last 10 years.
May 21, 2009 | Hitachi SuperScan Pro 800 Monitor
The task bar along the bottom of the screen, I can't see it
Adjust controls on the monitor. There a double box that lays on top of the other. Adjust that option... You may also want to adjust the setting that shows a box with arrows pointing up and down. adjust it as well.. Experiment on the settings. You'll get it right.
Mar 14, 2009 | Hitachi SuperScan Elite 802 21" CRT...
Connecting PC to television
Hi and welcome to FixYa,
Initially, try the lowest possible Screen Resolution in the PC's Display Properties. You could also try lowering the Screen refresh Rates. This is especially so if the PC connects to the TV using composite (yellow) video out or S-Video. In some video cards/settings, it may be necessary to enable twin/dual view in the display properties.
Good luck and Thank you for using FixYa. Happy New Year.
Jan 01, 2009 | Hitachi SuperScan Elite 802 21" CRT...
My moniter is a CM 2111MU
The invalid sync indicates there is no video signal getting to the monitor. Have you checked the connections and video driver card? IF you haven't, you might try a different monitor on the video card to verify that the cabling and card are okay. If both test out as good, the next step would be to remove the cover and check the monitor's connector but that has to be done very carefully with the unit off and given time for voltages to neutralize inside. Even then there might be lethal voltages on capacitors...if you're not experienced, this would be something I'd turn over to someone who is.
Hope this helps.
Jun 27, 2008 | Hitachi SuperScan Elite 802 21" CRT...
Whats the solution
at the vertical stage of the tv there is a capacitor that is weaken and need to be replaced.
do this by testing all the capacitors on that stage.isolate it and replace it with the same type
Apr 10, 2008 | Hitachi SuperScan Elite 802 21" CRT...
I need a remote Code
The comcast remote control code for Superscan VCR/DVD combo is 11963
Dec 27, 2007 | Televison & Video
Bright,thin line, in the middle of the screen, then...
1. I turn on the monitor, I hear a 'cracklin' sound
Reply: In a CRT Monitor there is a component called EHT which generates High voltage which is connected to the anode of the CRT, If there is any leakage due to moisture can cause this crackiling sound, You need to clean this high tension wire or replace the EHT ( CAUTION : BE AWARE OF HIGH VOLTAGES )
2. The screen only shows a bright, thin line.
Reply: The vertical Drive section of the monitor is faulty.
Dec 21, 2007 | Hitachi SuperScan Elite 802 21" CRT...
The monitor would not turn on. Only the orange LED does.
1. Make sure the monitor cable is fully plugged into the computer. 2. If the new monitor works fine, The connection between the previous monitor and the PC was bad. Reconnect the original monitor to the PC and make sure that the connection is snug. Tighten down the video connectors until they are snug. Try again. good luck..
Jan 06, 2006 | Hitachi CM772 19 in.CRT Conventional...
Hitachi SuperScan 776 Monitor Logo
29 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Marvin
Marvin
AJMAL KHAN
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
