Question about Kenmore Dishwashers
Kenmore Ultra Wash Dishwasher does not drain
My dishwasher will not drain. The motor runs ok and the drain lines to the garbage disposal are clear.
  • 413 Answers
Some Kenmore DW have a check valve attached to the sump that may have a blockage. Remove toe panel, look for a long, white, plastic fitting attached the front, right side of the sump. Remove the drain hose from the valve. Unscrew the valve from the sump and inspect for debris inside the valve.
Posted on Jun 14, 2008
Kenmore ultra wash dishwasher odor
Is the drain line going over an upper edge before connecting to the sink drain line? Also try to make a rinse with white vinegar.
Jul 06, 2015 | Kenmore Dishwashers
Doesn't drain
If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
H Drain impeller. The drain impeller is attached to the pump and pushes the water out of the dishwasher through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit. The drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve. The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced.
Clogged or Improperly Installed Garbage Disposer. If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug needs to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve. The check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball. The check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Dec 17, 2013 | Kenmore 15129 Built-in Dishwasher
Kenmore ultra wash II dishwasher has standing water in bottom of washer Where can i pour drano
no drano but a lot of tomes the drain hose under the sink where it drain into the garbage disposal needs to be looped up when you use the sink where the disposal is it drains back down into your dishwasher
Dec 15, 2013 | Dishwashers
My dishwasher isn't draining. The garbage disposal is hooked up separately.
Is sink drain line clogged?
Disconnect drain line at sink tailpiece and lower down to see if water inside dishwasher drains.
Call serviceman to clear clog in dishwasher hose, or repair dishwasher pump motor.
Oct 13, 2012 | Whirlpool Gold Dishwasher with Quiet...
Dishwasher won't run. Worked yesterday, checked curcuit breaker, ok. water is in the bottem of washer but below the float level.
First, check the dishwasher filter and make sure it isn't clogged. Your owner's manual will have simple instructions on how to access and clean your dishwasher's filter.
Next, check the drain hose. Does it look flattened or kinked? Do you see any sharp bends? If so, straighten out the hose with your hands and manipulate it so that it regains its rounded shape.
If your dishwasher drains through the garbage disposal, try running the garbage disposal for a bit to process and clear any food. If that does not get the machine draining, you may have a deeper clog. However, most drain hoses clog either at the main household sink drain line connection or the garbage disposal connection.
Does your dishwasher spray your dishes, but it does not advance to the next stage and drain the dirty water? The timer controls the start of the draining process, so you may need an entirely new timer or a new motor for the timer. Repair service is recommended.
In some dishwashers, standing water is caused by a valve that fails to open and allow the water to drain out. This valve is controlled a solenoid that the timer controls. A malfunctioning solenoid could be the problem.
For more troubleshooting tips and solutions, see Dishwasher not draining. I hope this helps!
Sep 27, 2012 | Kenmore 665
Kenmore dishwasher 15791 wont drain
There's a few things you can look into that won't cost you any money.
First, manually remove as much water as possible and then check the sump area for paper or any other large object clogging the drain. A cup or so of water in the sump area of your dishwasher is normal and it is there to prevent the seals from drying out. The dishwasher will pump this old water out before beginning to wash.
Make sure the door is properly latched as the pump will not drain if the door is not latched properly.
Check the belt, drain line, air gap, drain valve and solenoid assembly, the motor, and the pump. If your dishwasher uses a belt to drive the pump, and it has broken or come off the pulley, replace it.
If you have recently installed a garbage disposer in your home, make sure that the drain plug on the disposer has been removed. It's just a little plastic piece that blocks the hole where you hook the dishwasher drain hose. If your dishwasher drains through the garbage disposer, you need to run the garbage disposer before you run the dishwasher to make sure that the drain is clear.
There is a drain hose between the drain valve or pump and the garbage disposal or drain line. If an obstruction has blocked this, then your dishwasher won't drain. The drain hose is connected by clamps to the drain valve and the disposer or drain pipe. Remove it and visually inspect it for a clog or a kink. Try to remove any debris. If it is in good condition, just put it back on, and if not, purchase a new one to install.
If you don't have an air gap in the drain line, at least use a high drain loop. Making a large loop about 18" off the ground with the drain line can prevent any back flow into the dishwasher from the sink.
If you have one, the air gap will be located on top of the sink. The air gap is there to prevent any siphoning of standing water from the sink. When your dishwasher drains, the air gap diaphragm will form a seal and allow the water to drain properly. If the diaphragm in the air gap is faulty, it’s possible that water can leak onto the cabinet and into the sink area. When this happens, then the air gap must be replaced.
Like the inlet valve, there is also a drain valve on most models. When no power goes to the drain valve it remains closed and prevents water from leaving the machine. When the valve receives power during the drain cycle, the solenoid opens and allows the water to leave the machine. If your drain hose is attached directly to the pump, you don't have a drain valve. The motor simply reverses and the pump sends the water in the opposite direction, which is out of the machine.
If the motor doesn’t turn or work properly, the dishwasher may not drain. Make sure you have power to the unit. If you notice that the motor hums but won't turn, it could be seized, and you probably need to replace it.
if you need to buy any parts, I have had alot of help from
Small objects can sometimes get stuck in the pump. When this occurs, you’ll need to open the pump and remove any debris buildup. The dishwasher pump is usually mounted directly to the motor and runs off the motor as well. The pump is also attached to the bottom of your dishwasher and pushes the water from the dishwasher.
Apr 19, 2010 | Kenmore PRO 24 in BuiltIn Dishwasher with...
Kenmore Ultra Wash III Dishwasher will not drain properly
Fixerfailure, is the knock-out plug still inside if the garbage disposal inlet?
Stick a screwdriver in there to make sure.
spazmo1969, could be the rubber flapper is broken off in the pump discharge outlet.
Dec 27, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
From the sound of things, your dishwasher drains faster than your sink drain ( via the garbage disposal) can drain it off.. You may have a problem with the way your sink drain/trap is vented and there is too much back pressure to drain down quickly.. When you run water from your sink, does it take a long time to drain down or if you fill your sink up and drain it, does it drain slowly ? That may be your problem.. Hope that helps.
Aug 26, 2008 | Dishwashers
Kenmore Built In Dishwasher
the obstruction they talk about in the disposer, its where the connection for the d/w drain is made, there is a "knockout" plug within the drain line connector( in case you dont have a d/w) that would need to be removed before the d/w will drain. can be popped out with a good smack with a screw driver, the plastic knockout will land within the disposer. disconnect power and remove the plug, it will not break up and wash away
Mar 25, 2008 | Kenmore 15121 Built-in Dishwasher
Leaking dishwasher
It sound like while the assembly of the garbage disposal, you placed the end of the drain line pipe in a lower position than it was before. Good luck!
Aug 06, 2007 | Kenmore 15129 Built-in Dishwasher
Dishwashers Logo
650 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
